Very basic current direction question
  • Thread starter Thread starter Jacob87411
    Current Direction
The discussion centers on calculating the equivalent capacitance of a circuit with multiple capacitors. The user initially calculates the capacitance as 500 microfarads based on two sets of parallel plates, each with a capacitance of 500 microfarads, leading to a series configuration of 1000 microfarads. However, the conversation reveals that with four capacitors in parallel, the equivalent capacitance should be recalculated, emphasizing the importance of understanding series and parallel configurations in capacitor circuits. The final conclusion is that the current can flow through either capacitor in the parallel arrangement, necessitating the calculation of an equivalent capacitance.
  • Understanding of capacitor configurations (series and parallel)
  • Familiarity with capacitance calculations (C=Q/V)
  • Basic knowledge of electrical circuits and current flow
  • Ability to interpret circuit diagrams and connections
  • Study the principles of series and parallel capacitor combinations
  • Learn how to calculate equivalent capacitance in complex circuits
  • Explore the impact of voltage sources on capacitor behavior
  • Investigate the concept of current paths in electrical circuits
Electrical engineering students, hobbyists working with capacitors, and anyone interested in understanding capacitor circuits and their configurations.
Jacob87411
I attached a picture..Im just curious, if your calculating the capacitance on each plate why is the answer .5 if the V=1000 and each capacitor plate is 500 microfarads..
If C=500 for each plate then first you have two sets of parallel plates so it simples to a series with two plates of 1000 microfarads..which simplifies to 1/1000+1/1000=2/1000, so the capacitance is 500. C=Q/V,
5x10^-6=Q/1000, shouldn't Q=5? Thanks
Sorry now I attached it
Your attachment appears to be missing a connection to the rightmost part of the two right caps.
But assuming that there is meant to be a connection there, then you have basically 4 caps in parallel, with the way the voltage source is shown connected.
Yes they are supposed to be connected...so once you combine the parallel sets on either side and reduce it to two capacitors are those capacitors in parallel or series
The current has a choice of where to go
So it only flows through one pair of the capacitors, not both?
It can flow to both. Its just the matter of finding one equivalent capacitance now. Since you reduced the four parallel caps to two equivalent caps (one on each side), the current can go to either cap. When a current has more than one path to go, those components are in...?
  • · Replies 16 ·
  • · Replies 18 ·
