Is It Possible to Solve This Diffusion Equation via Separation of Variables?
The diffusion equation $$\frac{\partial U}{\partial t}=\nu \frac{\partial^{2} U}{\partial y^{2}}$$ cannot be solved using the separation of variables method due to the nature of the boundary conditions. The boundary condition $$U(0,t)=U_0$$ and the requirement that $$U(y,t) \rightarrow 0$$ as $$y \rightarrow \infty$$ complicate the separation approach. Instead, the Laplace transform method is recommended, leading to the differential equation $$\nu W_{yy}(y,s) = s W(y,s)$$, where $$W(y,s)$$ is the Laplace transform of $$U(y,t)$$. The inverse Laplace transform of $$W(y,s)$$ provides the solution for $$U(y,t)$$.
  • Understanding of diffusion equations in fluid mechanics
  • Familiarity with boundary value problems
  • Knowledge of Laplace transforms and their properties
  • Experience with differential equations and separation of variables
  • Study the properties of Laplace transforms in solving differential equations
  • Learn about boundary value problems and their solutions
  • Explore the similarity method for solving diffusion equations
  • Investigate the error function (erf) and its applications in diffusion problems
Mathematicians, physicists, and engineering students focusing on fluid mechanics and differential equations, particularly those seeking to solve complex boundary value problems.
Remixex
$$U(0,t)=U_0 \quad for \quad t>0$$
$$U(y,0)=0 \quad for \quad y>0$$
$$U(y,t) \rightarrow {0} \quad \forall t \quad and \quad y \rightarrow \infty$$
This is a diffusion problem on fluid mechanics, but it's more of a math problem so i posted it here.
I'm trying to solve this via separation of variables (the textbook uses a "similarity" method I've never seen before, and concludes the function U must be erf) is it even possible to reach an analytic result via SV?
The first boundary condition is what gets me, I tried
$$U_{0} e^{{k^{2}t}} e^{{-\frac{k}{\sqrt{\nu}}y}}$$
But it clearly doesn't work for any boundary condition except the last.
I don't think sinusoidal is the answer here either because it must eventually converge to zero, for every t.
Is there really no analytic answer?
Please show your separation of variables and the resulting differential equations.
Use Laplace transforms with respect to ##t##. Let
$$W(y,s) = \int_0^{\infty} e^{-st} U(y,t) \, dt $$
be the Laplace transform. Then, using standard properties of Laplace transforms, we get the DE
$$\nu W_{yy}(y,s) = s W(y,s) - U(y,0) = s W(y,s),$$
where ##W_{yy} = \partial^2 W / \partial y^2##.
Also: ##U(0,t) = U_0## implies that
$$W(0,s) = \frac{U_0}{s} $$
Finally, the initial value theorem requires that ##\lim_{s \to \infty} s W(y,s) = 0## for ##y > 0##.
These are enough to determine ##W(y,s)##. Then it is just a matter of taking the inverse Laplace transform of ##W(y,s)## to get ##U(y,t)##.
Separation of variables will never work in this example, simply because it leads to the wrong kind of function.
THANK YOU :D
  • · Replies 0 ·
