Very strange copy-paste bug in PDF document
  • Thread starter Thread starter DaveC426913
    Bug Pdf
36 replies · 6K views
DaveC426913
2025 Award
TL;DR
I have encountered a very strange bug in a PDF document that is corrupting the contents of copy-paste function.
I am trying to copy the contents of this PDF into another document (it doesn't seem to matter which document type).
No matter how much or how little I copy into the clipboard, no matter whether I paste it into a text editing field - an email, or notepad - I get the same thing:
The text I'm copying reads "... affordable!"
But what gets pasted is "... aJordable!"
At first I wondered if it was some sort of real-time OCR interpretation thing happening. I have tried this six ways from Sunday. In fact, all I need copy is the "ff" and I still get "J".
I'd like sanity check and a second pair of eyes. If someone is willing, I'll PM the PDF to you directly (it's like 29kb).
(It's a coworker's document, and it's just some marketing text copy so it's harmless).
Anyone game?
(To be clear: of course I can just write out myself that's not the point. Our department lives and dies on marketing text. If PDFs can't be retrusted that's a heck of an apple cart to be upset.)
Does that include vanilla *.txt files?
Is this on Windows or on a Mac/Linux?
It looks like that really is a word after all. Can you delete it from your dictionary to see if that helps? Is affordable in your dictionary at the moment?
You are pasting what is there. PDF has replaced a system font with one of its own that looks better for some combinations. ff is a common one. However, its system representation is not ff, but Alt-K or something, so that's what goes on the clipboard.
This can be fixed at PDF creation.
I'll try that too.
Mac. But I'll test it on my PC.
I dont see how that's relevant. I am literally copying and pasting text. It sure better not be auto-corrupting when I'm doing that.
It looks like V50 has figured out the problem. Can you look at the hex source for this using a hex editor?
Same thing on my PC.
That is ... alarming.
It means we cannot trust that what we copy from a client's document will be published faithfully.
If we don't find a solution, we'll have to proof every single word in all our content. Or we'll have to stop using PDF format.
Hopefully, there is a setting or simple method that can defeat this feature across-the-board, otherwise, moving forward the creators will never even know they've made this mistake.
That is correct. And you never could. What goes on the clipboard is what the application says to put on the clipboard. Full stop. Usually that is what you just selected, but not always. It's been this way since before PDF.
The same thing can happen with Word. I don't know if and when it does, bit the OS does not prevent it, No OS does.
I have seen some other weirdness when copying from certain PDF files made with my OCR reader namely reversed text as an example "affordable" would be pasted as "e l b a d r o f f a"
My feeling was that the Chinese OCR software had some I18N NLS setting for right-to-left instead of left to right but I was never able to find it and their support was non-existent.
Sounds like it's time to contact Adobe customer support, right?
To be clear, this was not a scanned doc.
jedishrfu said:
Change Fonts: Before copying the text, change the font in the source document to something more standard like Arial or Times New Roman, which avoids using complex ligatures.
I think this is going to become the company policy: use standard fonts only.
Then scan it into text, not PDF,
To swep away the cruft, Dave is doing OCR, While OCR ts getting pretty good, expecting perfection is unrealistic.
Going through PDF just adds an unnecessary complication and point of failure.
Not sure what you mean; it's not scanned at all.
The designer has typed this in (to what, I'm not sure) and saved it out as PDF. (Presumably, as part of their prefered routine, for a number of useful reasons.) The point being I can select the text as text (i.e. with text select tools) in the PDF.
I don't really have a say over what the designers use to work in. But I think I can make a case for insisting that they don't mess with the font when delivering text assets.
OK, so we got stuck down an OCR rabbit hole. Without it, the story is still sample - the document was printed with (possibly tacit) instructions to make it look pretty, and to adjust what it needed to to make that happen. This is a side effect.
If you print in Lucida Console, this is less likely to happen, and your documents will be butt-ugly. Take your pick.
Sorry, I am becoming aware that lack of context is spinning this off in unexpected directions.
This is a doc that a designer colleague has passed to me to be implemented on a page. It's entirely internal use, and it is straight up text.
The choice of PDF as a transfer medium is likely merely a professional habit on his part. (There are good reasons for it, but here is one of the downsides).
It does help, in that he us able to show me how he wants it laid out - bolding, paragraphs, etc.
But his choice of font is irrelevant, since I am stripping everything out and using the site's CSS styling anyway.
I have asked him to resend it in Word, which does not deign to know better than the user about what the user wants. If I'm lucky, this doesn't have to be a department-wide mandate; I think other designers use Word.
Does your work use some kind of formal document control system? In my previous work, we used various systems over the years (like Arena and Agile) for document control and revision control. One of the requirements for releasing a document was to attach the source file (in whatever format like Word or the format of the designing tool), and to attach a PDF copy that anybody could open even if they did not have the design tool software.
Does your work use some kind of formal document control system? .
Our department is small enough that we don't have such policies yet. But this incident has occurred because we are growing.
It makes me aware I've come from much bigger companies. I suspect implementation of standard policies are going to be something I will be harping on.
I think there is some confusion here. Some elements of this have been touched on by others, but I think you are still missing the full picture.
The problem does not lie with Windows, Word, Adobe or the PDF format - all of these are doing exactly what they are supposed to.
The problem lies with the software that your designer is using to create the content: I would guess that this is some professional layout software such as InDesign or Quark Express. This sort of software is not designed for creating content, it is designed to prepare a document for presentation, perhaps electronically or more often in print. In order to do this it follows some common printing conventions which have been used for hundreds of years including the use of ligatures, where some letter combinations (in this case 'ff') are replaced with a special glyph (in this case 'ff'). When the document is rendered as a PDF, it is the code for this glyph (Unicode U+FB00 'Latin Small Ligature Ff') that is inserted into the text and so this code is what is copied across to your Word document.
What happens next depends on what version of Word you are using and what fonts you have installed*, but I won't go into this now as it is not going to help you.
What is going to help is asking the 'designer' (although here they are simply a content creator) to turn off ligatures (and kerning and any other layout features) in the copy they send you. If you still need them to provide a fully laid out page to see what the intended layout is then they can do this as well, in an additional copy.
* in particular it seems that the font you are using does not implement this glyph correctly: I am pretty confident however that the 'ff' will render properly in your web browser here because this is part of modern web standards.
Yes. This.
You are certainly right that I need their deliverables that show layout. In this case, it was straight copy, and copy should really be sent under separate cover - as you point out.
I have spoken with the designer (who, it turns out, got this from a third party stakeholder) and we are in agreement that Word is the proper tool. Jury is still out on whether we can start telling third party stakeholders what tools they're allowed to communicate with.
A first-pass approach, it would need polishing before decreeing anything, especially the phrases in <...>:
"Since we do not have every text layout program in existence, <would you> kindly supply a copy in PDF <Word/plain text> format in addition to your layout requirements? This will expedite <the/our> <processing of your project>."
Hope this helps!
Cheers,
Tom
Let's not lose focus. Fixing this takes 5 or 10 seconds. To avoid wasting 5 or 10 seconds in the future, we will have meetings, rules, standards, meetings about riles and srandards and thus ensure we will never waste 5 or 10 seconds again!
Vanadium 50 said:
Let's not lose focus. Fixing this takes 5 or 10 seconds. To avoid wasting 5 or 10 seconds in the future, we will have meetings, rules, standards, meetings about riles and standards and thus ensure we will never waste 5 or 10 seconds again!
I know (hope) you're kidding around but it isn't a 5 or 10 second fix.
Unless everybody in the chain is schooled on not using PDFs to pass copy around, there is no way someone down the line can even know if there's a corruption in the copy - not without proofing the entire document every time, for every revision that comes down the pipe. And even if we did, we can't be sure what the copy was supposed to be (what if it occurred in a date or dollar value?).
By the time it gets to me, I've got a compressed timeline and cannot afford to proof every word. Chasing down the original copy writer for a change causes ripples that travel up and down the line of approvers and stakeholders, which results in delays and missed deadlines.
It's not the time, it's the consequences: missed publish deadlines or errors in the product. Both are unprofessional and new-one tearing-worthy.
Yes it is. Two letters, "ff" was replaced by the "ff" ligature. To fix, replace the ligature with ff.
You can also fix this with a phone call - "The PDF got mungled. Can you send me the Word or other parent document?"
You speak out-of-turn. Please re-read my post as to why it is not nearly this simple, particularly this:
"...there is no way someone down the line can even know if there's a corruption in the copy - not without proofing the entire document every time.." (and even then one can't know if there are any other ligatures lurking in there that aren't even visible - I only caught this one by sheer luck because it happened to be the very last word in the entire copy).
Thanks but I'm pretty sure you don't know the processes in a given department in an unknown business or how many people are involved or how approvals travel up and down the chain.
One doesn't necessarily know who the originator is, or how to reach them right before the deadline - what one does is establish policies i.e. anticipate problems rather than react to them in crunch time - which is what I'm doing here by figuring out exactly what the problem is, so I can justify why the entire department has to take on a new policy.
It's your time. Spend it however you want.
As someone who is just coming in and reading this thread, I agree with the OP: he has already explained why it isn't that simple, and why he is approaching it the way he is.
The fundamental problem is that copy-and-patse provides no gurantee of accuracy. What goes on the clipboard is what one program chooses to write, and what comes back is what another chooses to read. I could, if I were inclined to be perverse, wrire a program that, no matter what was copied to the clipboard, put "Tim Horton's has stale donuts" there. (Likewise with the paste)
If this is viewed as too risky or inaccurate, you need to drop cut and paste entirely.
