Viewing Particle P in a Cylindrical Vessel - 40 cm Height Needed
The problem involves a cylindrical vessel with a diameter and height of 30 cm, containing a particle placed 5 cm from the center. The objective is to determine the minimum height of water required for the particle to be visible from a specific viewpoint.
  • Participants discuss the application of the formula for apparent depth and question its validity when viewing from different angles. Some suggest using Snell's Law instead of the apparent depth formula.
The discussion is ongoing, with participants exploring different interpretations of the problem and questioning the assumptions behind the equations used. There is no explicit consensus on the correct approach yet, but guidance has been offered regarding the application of Snell's Law and the behavior of light rays at the water's surface.
Some participants express confusion about the bending of light rays and the assumptions made in the calculations, indicating a need for further clarification on the underlying principles of optics involved in the problem.
Rightwrong
I1. Homework Statement
A cylindrical vessel whose diameter and height both are equal to 30 cm is placed on a horizontal surface and a small particle p is placed in it at a distance of 5 cm from the centre. An eye is placed at a position such that the edge of the bottom is in the plane of drawing. Upto what minimum height should water be filled in the vessel to make particle p visible?
Apparent depth (d’) = real depth (d) / refractive index
My answer is 40 cm which is wrong.
[/B]
That formula is for looking straight down, i.e. the line of vision is normal to the surface,
Apply Snell's Law instead.
But why do the rays bend if it’s for looking straight down? Because their Sin 0 *4/3 = sin r
And r would have to be 0 so the rays wouldn’t bent then why does it appear to be raised?
sorry. I mean sin i *4/3 = sin 0
Sin i = 0
Could you please explain why that equation is used for when an object is viewed from straight above.
I'm having a problem with that equation in pther questions also.
Your pupil has diameter. Consider, from a point object, one ray to each side of the iris. These are not quite vertical, so as they emerge will be bent just a little away from each other. Project the emerging rays back down to the point where they intersect. This will be where the object appears to be.
The calculation of apparent depth assumes these angles are small. In the problem you are given the angles are much larger.
But the lens in our eyes is convex and it converges the rays. So why will the rays bend away from each other?
Sorry I didn't get what you said earlier. The rays bend away from each otherat the surface of the liquid. Thanks for helping me out.
How do you get the answer for this question?
https://ibb.co/k0zFv8
Draw a ray from the object that is a small angle θ above the horizontal. (You can draw it large for legibility but bear in mind that is in principle small.)
Show how it deviates at each interface before reaching the eye.
We can take the horizontal line as a second ray, not deviating.
Project back the final section of the first until it meets the horizontal one. That is where the object will appear to be.
Now use some geometry to relate the apparent distance to the other distances and the angles.
16K
24K
