Visualising an alternative formulation of Planck's Radiation Law
This discussion centers on an alternative formulation of Planck's Radiation Law, specifically the equation n(E) = (2π/c²h³)(E²/(exp((E-μ)/(k_BT))-1)). Participants clarify that this formulation is a generalized version applicable to complex systems, particularly photon gases in equilibrium with electronic transitions. The original reference for this formulation is P. Wurfel's 1982 paper in the Journal of Physics C, which discusses luminescence intensity in GaAs LEDs but does not provide a direct graph of the distribution. The conversation emphasizes the importance of understanding the role of chemical potential in this context.
  • Understanding of Planck's Radiation Law
  • Familiarity with photon gas behavior and electronic transitions
  • Knowledge of statistical mechanics concepts, including chemical potential
  • Basic proficiency in interpreting scientific literature, particularly in physics
  • Read P. Wurfel's 1982 paper in the Journal of Physics C for foundational knowledge on the generalized Planck's Law.
  • Explore the concept of chemical potential in non-thermal distributions and its implications in quantum physics.
  • Investigate the relationship between luminescence intensity and chemical potential in GaAs LEDs.
  • Study the physics of photon gases in equilibrium and their applications in modern photonics.
Physicists, researchers in quantum mechanics, and students studying advanced thermodynamics and statistical mechanics will benefit from this discussion, particularly those interested in the nuances of Planck's Law and its extensions.
TheBigDig
TL;DR
Unable to find graph of alternate formulation of Planck's Law
I've come across this alternative formulation of Planck's Law which links the number density to energy gap
n(E) = \frac{2\pi}{c^2 h^3} \frac{E^2}{exp\big(\frac{E-\mu}{k_BT})-1}
I've tried visualising this relation and I imagine it will look similar to the spectral density relation but I'm just wondering if anyone has ever come across a graph of this.
Where? Please give a reference.
This is not Planck's Law. Since photons are massless bosons and also because there's no conservation law for photon number there cannot be a non-zero chemical potential for photons.
That is the generalized version of Planck's law extended towards more complex systems and non-thermal distribtions, which is valid e.g. for a photon gas in equilibrium with a set of electronic transitions, which are in turn in equilibrium with each other. To the best of my knowledge it was first given in:
P. Wurfel, Journal of Physics C, 15 (1982) ( https://iopscience.iop.org/article/10.1088/0022-3719/15/18/012 ).
In that article, he does not directly show a graph of the distribution, but figure 5 shows the luminescence intensity of a GaAs LED for a certain choice of chemical potentials, which is at least closely connected to the initial distribution. If you really need a plot of the initial distribution, it might help to check the papers, which cite the manuscript above.
I see. It's about photons in a cavity. Then at least a chemical potential is not mathematical suicide. I've to read the paper to make sense of it though, because which physical sense does it have if there's not a conservation law of some charge-like quantity (a "photon number" in some sense)?
Well, the focus is more on the emitter side. If you put some material with a band gap in a cavity, have it emit light and wait for equilibrium between photon emission and absorption to arise, the band gap energy will play an important role. If you pump the material somewhat more strongly, the lowest unoccupied state in the conduction band will not be exactly at the band gap energy but somewhat higher as more states become occupied. A similar thing goes on in the valence band. The difference between these two chemical potentials is the one that enters in this equation.
Yes, but all this is not an alternative formulation of Planck's law but entirely different physics. E.g., a laser can be seen as a material with "negative temperature", describing population inversion.
Sure, I fully agree. If I remember correctly, the author himself describes it as an "extension", which reduces to the real Planck's law in the limit of zero chemical potential. Adding any finite value there certainly means that one does not discuss a standard black body.
Sorry, it was from notes given by my lecturer. I looked up the reference material for the course but couldn't find any reference to it.
Thanks for this discussion and explanation guys, really improved my understanding. I will take a look at this paper.
  • · Replies 18 ·
  • · Replies 23 ·
9K
