Visualising rotation in 3-D space
  • Context: Undergrad
  • Thread starter Thread starter brotherbobby
    Axes Rotation
The discussion revolves around visualizing rotations in 3-D space, particularly how the axes and vectors behave during such transformations. Participants explore methods to conceptualize these rotations, including the use of diagrams and online tools, and discuss the implications of rotating around a specified axis.
  • Some participants express difficulty in visualizing the rotation of the axes and vectors in 3-D space, particularly when rotating about a specific axis.
  • There are suggestions to use online tools like GeoGebra and Desmos to aid in visualization, with some participants noting that these tools can help illustrate the concept of rotation more intuitively.
  • One participant mentions the idea of drawing a cone around the axis of rotation to understand how vectors maintain a fixed angle and length during rotation.
  • Another participant shares a personal visualization technique involving imagining a globe, suggesting that physical manipulation of a model can aid understanding.
  • Some participants discuss the importance of understanding how vectors decompose into components parallel and perpendicular to the axis of rotation, and how this affects their behavior during rotation.
  • There are repeated references to the utility of drawing disks centered at the origin to represent the rotation visually, particularly when the axis of rotation is aligned with one of the coordinate axes.
Participants generally agree that visualizing rotations in 3-D space is challenging and that various methods can aid in understanding. However, there is no consensus on a single effective method, and multiple approaches are discussed without resolution.
Some limitations in the discussion include the dependence on individual interpretations of rotation, the potential for confusion regarding the effects of different axes of rotation, and the varying levels of familiarity with 3-D visualization tools among participants.
This discussion may be useful for students and enthusiasts of physics and mathematics who are trying to understand the concept of rotation in three-dimensional space, as well as those interested in visualization techniques for complex geometric transformations.
brotherbobby
TL;DR
How do you visualise a rotation of the ##x,y,z## axes via an angle ##\theta## about an axis passing through the origin and a point, say ##\text{P}(a,b,c)\quad(a<b<c)##? Let's assume the rotation is anti-clockwise as seen from the origin towards the point ##\text{P}##. Assume ##\theta<\dfrac{\pi}{2}##.
My question is - what would the ##x,y,z## axes look like following the rotation?
I am just not able to do it.
I have very little clue as to how to imagine (visualise) the rotation and how the axes will look.
All I can do is to draw the image of what I mean by the task. Of course, this is before the rotation takes place.
In the diagram, ##\mathbf{OP}## is the axis of rotation.
For simplicity, we may give a value like ##30^{\circ}## to the amount of rotation.
I'd be grateful for any help.
There are free online tools for this, like GeoGebra.
If you want to draw it by hand, note that every rotated vector has a fixed length and fixed angle to the rotation axis. So each rotated vector stays within a certain cone mantle, centered around the rotation axis. Drawing the base of that cone might help.
brotherbobby said:
TL;DR Summary: How do you visualise a rotation of the ##x,y,z## axes via an angle ##\theta## about an axis passing through the origin and a point, say ##\text{P}(a,b,c)\quad(a<b<c)##? Let's assume the rotation is anti-clockwise as seen from the origin towards the point ##\text{P}##. Assume ##\theta<\dfrac{\pi}{2}##.
View attachment 362717I have very little clue as to how to imagine (visualise) the rotation and how the axes will look.
Read about Euler angles here.
Euler's angles are useful in that they help you find the answer. But you don't get a feel of "how" in real time.
I'd like a way to visualise directly; what happens to a point (or several points on a line) as one effects a rotation about a given axis.
I could visualise what you mean. So thank you for that. Indeed, the ##x## axis starts with a precise angle to the axis of rotation and, if we take any point on the ##x## axis, the line would continue having a fixed length throughout the rotation. The angle would remain the same too.
In my problem above, clearly the rotation is not taking along any of the coordinate planes. I cannot visualise how the ##x## axis would look after a rotation of ##30^{\circ}## about the axis given. 😌
I think playing around in 3D software will give you an intuition for that.
I used to hold a child's toy globe in my hands, now I imagine an Earth globe and rotate it in my head and hands.
Null Island in the Atlantic Ocean is +x, the Indian Ocean contains +y, while the North Pole is +z.
https://en.wikipedia.org/wiki/Null_Island
robphy said:
It might help to draw a disk centered at the origin whose normal is along the axis of rotation.
www.desmos.com/3d/gflyvyyuoh
That looks extremely good. I am still struggling with the problem and, despite your efforts, I might continue to do so.
Still, thank you very much. Not only do I want to understand how vectors (and co-ordinate axes) rotate under arbitrary transformations about an axis, I am also eager to learn the 3-D drawing on ##\verb|Desmos.com|##
If your axis of rotation is along the z-axis, the disk represents the unit-disk on the xy-plane.
Vectors parallel to the axis of rotation don't change.
Vectors parallel to the disk surface keep their magnitudes but change their directions.
A general vector can be decomposed into the sum of a vector-parallel and a vector-perpendicular to the axis of rotation. (Thus, for a general vector, we draw an associated right-triangle.)
Now, as you change your axis of rotation (away from the z-axis),
you can see the change of the associated disk (off the xy-plane).
Upon rotation about that axis, a general vector decomposed with the associated right-triangle
will show the height of the triangle (parallel to the axis of rotation) unchanged and
the projection (the shadow) onto the disk have a constant size, but different direction according to the rotation.
I learned tools like desmos by modifying examples.
Try turning off various features by long-clicking the colored-circles.
Try modifying the expressions. (You can always undo or reload. You can also save your own copy.)
  • · Replies 16 ·
