Voltage Across Resistors In Parallel
The discussion focuses on the behavior of voltage across resistors in parallel, specifically addressing a circuit with a 31.0 Ω resistor, a 10.0 Ω resistor, and a 5.00 Ω resistor connected to a 9V battery. It is established that resistors in parallel share the same voltage drop due to their connection between the same two nodes, as illustrated in the provided diagrams. The analogy of climbers ascending a mountain is used to clarify that while the paths may differ, the voltage (or altitude) remains consistent across parallel resistors.
  • Understanding of Ohm's Law (V = IR)
  • Knowledge of electrical circuits and resistor configurations
  • Familiarity with the concept of voltage in parallel circuits
  • Basic principles of circuit analysis
  • Study the characteristics of series vs. parallel circuits
  • Learn about Kirchhoff's Voltage Law and its applications
  • Explore practical applications of voltage dividers in circuits
  • Investigate the impact of resistor values on current distribution in parallel circuits
Students studying electrical engineering, educators teaching circuit theory, and hobbyists building electronic circuits who wish to deepen their understanding of voltage behavior in parallel resistor configurations.
Bashyboy
Consider the circuit shown in the figure below. (R = 31.0 Ω.)
(a) Find the current in the 31.0 Ω resistor.
(b) Find the potential difference between points a and b.
I am reading the solution of this problem given by the author, and for the most part I understand it, except for this one critical part:
"In diagram (iii), the current above goes through the equivalent resistor R_{iii} to give a voltage drop across this resistor of ΔV = IR_{iii}. n diagram (ii), we see that this voltage drop is ΔV_{ab} and is the same across the 10.0-Ω resistor and the 5.00-Ω resistor."
Why is the voltage drop the same across the two resistors in parallel?
By definition two resistors in parallel are both connected to the same nodes. In capture.jpg these nodes are a and b.
If you connect two resistors in parallel to an ideal 9V battery they will both have 9V across them.
So, it simply follows from definition, and there isn't any other reason?
No you missunderstood what I said. The definition of parallel is that the resistors are connected between the same two nodes. They have the same voltage drop because they are both connected to the same nodes.
Imagine two climbers go up a mountain. They start at the same point at the bottom and reach the same point at top. They might take different routes but both will measure the same change in altitude because they started and finished at the same places.
