Voltage divider using capacitor question
The discussion revolves around calculating the required capacitance to drop voltage for a tube filament, yielding different results using two methods. The first method, treating the tube's heater as a resistance, correctly calculates the needed capacitance as approximately 16 µF. The second method, which incorrectly assumes the resistance can be used directly in a voltage divider equation, results in a capacitance of about 18 µF. The error in the second method is attributed to not considering the phase angle between the resistance and capacitive reactance. The conclusion emphasizes the importance of treating the reactance as part of a complex number for accurate calculations.
bitrex
I'm calculating the size of a capacitance I need to drop a certain voltage at a certain current for a tube filament, and doing it two different ways gives two different answers. For example:
Tube needs 13 volts across it at 0.725 amps current. I pretend that the tube's heater is a resistance with an equivalent resistance of 17.93 Ohms. I then do a calculation to see what size capacitor I need to give the required current from the 120 volt line.
120 V = 0.725 A * 165.5 Ohms
I want the vector sum of the capacitive reactance and resistance of the tube heater to equal this..
\sqrt{17.93^2 + X_c^2} = 165.5
X_c = 164.5
\frac{1}{2\pi (60)(C)} = 164.5
So C is equal to about 16 uF.
Now I do it this way: I assume the resistance of the filament is the same at 17.93 Ohms, and I calculate the capacitance I need for a voltage divider to give 13 volts from the 120 volt line across the tube.
\frac{17.93}{X_c + 17.93}*120 = 13
When I do it this way, the capacitive reactance is equal to about 148 ohms, and I get about 18 microfarads as the size of the capacitor needed. I'm wondering if anyone can tell me what the reason for the difference is and where I've gone wrong in my thinking? Or maybe there's just roundoff error?
Yes. The second method is invalid. You can't add vectors like that unless they at the same phase angle and these are at right angles to each other.
Your first method shows you know how to do it. Much better :)
I see my mistake now. I think the second method would work also if I made sure to treat the reactance of the capacitor as the imaginary part of a complex number and then took the magnitude of the equation to get the voltage division ratio. I should know better! :D
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 78 ·
  • · Replies 27 ·
