Voltage or current in solenoid?
The discussion centers on the relationship between voltage (V) and current (I) in solenoids, specifically regarding which factor contributes more to the force generated. It is established that the induced magnetic field, which directly correlates to the force of the solenoid, depends solely on the current, as described by the equation B = μ n I. Voltage is necessary to maintain current flow, but it does not directly influence the magnetic field strength. The number of turns per unit length (n) also plays a critical role in determining the required voltage to achieve a desired current.
  • Understanding of Faraday's laws of electromagnetic induction
  • Familiarity with Ohm's law and its implications
  • Knowledge of magnetic field concepts and equations
  • Basic principles of electrical circuits and solenoid construction
  • Study the equation B = μ n I in detail to understand magnetic field generation
  • Explore the impact of wire resistance on current flow in solenoids
  • Investigate different solenoid designs and their efficiency in generating force
  • Learn about the role of inductance in solenoid operation and its effects on current
Engineers, hobbyists, and students interested in electromagnetism, solenoid design, and electrical circuit analysis will benefit from this discussion.
falling cat
Hi everyone,
I'm having some fun building solenoids for a project. I can't just leave "well enough" alone... I want to know how these things really work! I understand the concepts behind Faraday's laws, current in a wire, etc...
What I would like to find out is which gives more force to the solenoid, V or I? I know Ohm's law says I can't raise one without the other... But does the force depend on the voltage or current, assuming the number turns remains constant?
Thanks!
What "force" are you asking about? If you are asking about the induced magnetic field through the solenoid, then it depends solely on current. The equation is given by: B = μ n I, where μ is the magnetic constant (permeability of free space), n is the number of turns per unit length (turn density), and finally I is the current. Think of it like this: Movement of charges (current) induces the magnetic field, not the energy carried per charges (voltage). Hopefully this was the question you were asking, if it were not, then you might want to consider rephrasing the question.
The current is directly related to the magnetic field but, to cause a current to flow, a Voltage is needed.
It's a matter of considering all the variables. n, the number of turns will affect the Voltage that's required to pass a given amount of current because the resistance of the length of wire affects the current. There isn't a 'heirarchy' of variables; they are all relevant.
Thanks for your insight guys!
The way both of you put it makes sense- current makes the field stronger, but the voltage is necessary to keep the current constant for a certain length.
Thanks again!
  • · Replies 25 ·
  • · Replies 23 ·
  • · Replies 16 ·
