How to Solve the Lotka-Volterra System of Differential Equations?
  • Context: MHB
  • Thread starter Thread starter charlottewill
    System
The discussion focuses on solving the Lotka-Volterra system of differential equations, specifically the equations dW/dt = αW - βV and dV/dt = -γV + δW, where W represents the predator population (wolves) and V represents the prey population (voles). Participants explore the periodic solutions of the system, proposing solutions of the form W(t) = A sin(ωt) + B cos(ωt) and V(t) = C sin(ωt) + D cos(ωt). The challenge lies in determining the constants A, B, C, and D in terms of the parameters α, β, γ, and δ, with some participants noting the need for additional equations to solve for these constants.
  • Understanding of differential equations, specifically first-order linear ODEs.
  • Familiarity with the Lotka-Volterra model and its application in predator-prey dynamics.
  • Knowledge of trigonometric functions and their role in periodic solutions.
  • Basic skills in algebraic manipulation to solve systems of equations.
  • Study the derivation of periodic solutions in first-order linear ODEs.
  • Learn about the application of Laplace transforms in solving differential equations.
  • Explore numerical methods for solving systems of differential equations.
  • Investigate the implications of the Lotka-Volterra equations in ecological modeling.
Students in mathematics or biology, particularly those studying ecological modeling, differential equations, or mathematical biology, will benefit from this discussion.
charlottewill
've been given the Lotka-Volterra system of differential equations
dW/dt= αW−βV,
dV/dt= −γV+δW
and the question is as follows:
a) Suppose we have two species interacting on the same environment. After observations we find that the size of their population obey the above set of differential equations where α,β,γ,δ are positive constants.
Determine what variables represents the predators and what variables represent the prey and WHY
b) Solve the system by proposing
W (t) = A sin(ωt) + B cos(ωt)
V (t) = C sin(ωt) + D cos(ωt).
Find the value of the constants A,B,C,D in terms of the parameters α,β,γ,δ ω
There obviously must be a relationship between the equations given in part b) with the main dW/dt dV/dt equations above but how would you answer these questions?
Re: 3rd Year Tutorial Task which I'm having really trouble solving!
dW/dt= αW−βV,
dV/dt= −γV+δW
Find the value of the constants A,B,C,D in terms of the parameters α,β,γ,δ ω...
It seems that there is something wrong: we have a system of linear ODE of order 1 and You can have periodic solutions only if the system of linear ODE is at least of order 2...
Kind regards
$\chi$ $\sigma$
For a), just look at the equations. I think you are supposed to assume alpha, beta, etc. are positive. Wolves eat the prey, so if there are more wolves you should expect to see what happen to the prey?
As to chisigma's remark, I think you can see periodic behavior in a system of first-degree equations.
Kind regards
$\chi$ $\sigma$
Any ODE can be reduced to a first order system.
Consider:
\[y''+y=0\]
which we know has oscillatory solutions.
Putting \(u=y\), and \(v=y'\) reduces the second order ODE to the system:
\[ \begin{aligned} v' & =- u \\ u' & = \phantom{-} v \end{aligned} \]
In fact it is standard practice when numerically integrating ODEs to reduce a higher order ODE to a system of first order ODEs.
CB
Consider:
\[y''+y=0\]
CB
Yesterday evening I was tired and it was better of me to do some else, for example to read a roman...
The system of linear ODE...
$\displaystyle \frac{d W}{d t}= \alpha\ W - \beta\ V$
$\displaystyle \frac{ d V}{d t}=\delta\ W - \gamma\ V$ (1)
... written in terms of Laplace Transform with 'initial conditions' $\displaystyle W(0)=V(0)=0$ is...
$\displaystyle w(s)\ (s-\alpha) - \beta\ v(s)=0$
$\displaystyle w(s) - (s+\gamma)\ v(s)=0$ (2)
The linear system (2) has solution different from the 'trivial' $\displaystyle w(s)=v(s)=0$ only if the determinant vanishes and that means that it must be...
$\displaystyle s^{2} + (\alpha-\gamma)\ s -\alpha\ \gamma - \beta=0$ (3)
Condition of periodic solution is that (3) has roots $\displaystyle s= \pm i\ \omega$ and that is true for...
$\displaystyle \alpha= \gamma$
$\displaystyle -\beta- \alpha^{2}= -\beta - \gamma^{2}= \omega^{2}$ (4)
Kind regards
$\chi$ $\sigma$
dW/dt= αW−βV,
dV/dt= −γV+δW
Just to be precise let's assume "W" is wolves and "V" is voles.
dW/dt= \alpha W- \beta V
dV/dt= -\gamma V+ \delta W
Now suppose W increases. What effect will that have on dV/dt? Will V increase or decrease? Suppose V increases. What effect will that have on dW/dt? Will W increase or decrease? Wow, those voles are really eating up the wolves, aren't they!
There is a minor not well clear detail in this discussion. As far as I remember the Volterra-Lotka equations were non linear equation and that is confirmed in...
http://mathworld.wolfram.com/Lotka-VolterraEquations.html
... where, setting x the prey population and y the predator population, it is written...
$\displaystyle \frac{dx}{dt}= A\ x - B\ x\ y$
$\displaystyle \frac{dy}{dt}= -C\ y + D\ x\ y$ (1)
Kind regards
$\chi$ $\sigma$
I've got a bit of progress but can somebody please help:
We've been asked to solve this system of equations
dW/dt = = αW−βV
dV dt = −γV+δW
by proposing that
so I've differentiated both W(t) and V(t) to give W'(t) = ωA cos(ωt) - ωB sin(wt) and V'(t) = ωC cos(ωt) - ωD sin(wt) and replaced with the dW/dt and dV/dt in the system to give the expressions
ωA cos(ωt) - ωB sin(wt) = αW−βV
ωC cos(ωt) - ωD sin(wt) = −γV+δWand now I've replaced the W and V's on the RHS with W (t) = A sin(ωt) + B cos(ωt)
V (t) = C sin(ωt) + D cos(ωt) (originally given in the question) and I've factored out the constant and the parameters of cos(ωt) and sin (ωt) to give two simultaneous equations equal to zero which are
(ωA-αB+βD) cos(ωt) + (βC-αA-ωB) sin(ωt) = 0
(ωC+γD-δB) cos(ωt) + (γC-ωD-δA) sin(ωt) = 0
So how do I find the value of the constants A,B,C and D in terms of the parameters α,β,γ,δ ω?
Please can somebody help me :(
Thanks,
Charlotte
dW/dt = = αW−βV
dV dt = −γV+δW
by proposing that
Thanks,
Charlotte
what You have done till now is probably correct. You have two equations and four unknown variables A,B,C,D so that you need two more equations... what are these 'missing' equations?...
Kind regards
$\chi$ $\sigma$
I don't know about the two missing equations because that is all the information I have given in the question so unless I do
ωA-αB+βD = 0
βC-αA-ωB = 0
ωC+γD-δB = 0
γC-ωD-δA = 0
because sin AND cos can never = 0 so that makes sense but now how do I solve these so that I have A,B,C,D in terms of the 4 parameters?
Kind Regards,
Charlotte
Hey
i am having the exactly the same problem with this question.
Did you ever discover how to like the parameters to A B C D?
If you did do you mind exampling it to me?
dW/dt= αW−βV,
dV/dt= −γV+δW
If these are predator prey equations and supposedly are realistic both B and D must be independent of the birth death coefficients since they are the initial populations.
Then trivially from the set of equations in charlotte's last post (assuming correct algebra):
\[A=\frac{\alpha B-\beta D}{\omega}\]
\[C=\frac{\delta B-\omega D}{\omega}\]CB
ok that helps a little but my question is a bit different and it doesn't really help me solve it
i have a system of:
dW/dt= αW−βVW,
dV/dt= −γV+δWV
I then have
W (t) = A +B sin(ωt)
V (t) = C + D cos(ωt).
I know the values of ABCD and ω but i am trying to find the parameters α,β,γ,δ ω.
When i rearrange to let them equal zero i keep on getting them to cancel out and simplify. when i solve for let's say alpha, when i substitute back in i get them to cancel out.
ωB cos(ωt) - (α(A + B sin(ωt))+β[(A + B sin(ωt))( C + D cos(ωt))[ = 0
- ωD sin(wt) + γ( C + D cos(ωt))-δ[(A + B sin(ωt)) (C + D cos(ωt))] = 0
I just need to know how to find the values of α,β,γ,δ ω?
If you can help me establish the link i will be highly grateful !
i have a system of:
dW/dt= αW−βVW,
dV/dt= −γV+δWV
I then have
Please post the question as asked
CB
I don't have a specific question. i am making a mathematic model on turtles and algae in a dam. i am given that there is 200 tutrles that fluctuate by 10% and that there is 1-2 micrograms/litre of algae in the dam for an oscillation of a 6 month period.
using W=1.5+0.5sin(pi/3*t) and V=200*10 cos(pi/3t) and substituting into the volterra lotka system as stated above i ahould be able to solve for the unknown parameters the problem is that they keep on cancelling out
so i basically need help with finding by two main predator-prey equations with the unknown parameters known so i can actually get my assignment going as this is like a "pre-assignment" thing. I have decided to model it this way but i still need to code it up and actually answer the assignment but i can't do that until i have these equations
Then I can tell you that your proposed solution is not a solution except for degenerated situations that are unlikely to be of interest.
Plug the suggested solution into the DE and you get an expressions for the derivatives with 3 Fourier components corresponding to angular frequencies \(0\), \(\omega\) and \(2 \omega\) while the suggested solution when differentiated give expressions with only the first two Fourier components.
(I am pretty sure from other sources that those coupled non-linear ODEs do not have sinusoidal solutions)
CB
I apologize for having for long time not written posts in this [old] thread and I will try to repair now...
Let's write again the pair of linear differential equations...
$\displaystyle \frac{d W}{dt}= \alpha\ W - \beta\ V$
$\displaystyle \frac{d V}{dt}= \delta\ W - \gamma\ V$ (1)
... and search if there is a periodic solution of (1) like that...
$\displaystyle W= A\ \sin \omega t + B\ \cos \omega\ t$
$\displaystyle V = C\ \sin \omega t + D\ \cos \omega\ t$ (2)
Writing (1) in terms of Laplace Transform we have...
$\displaystyle (s-\alpha)\ w(s)+\beta\ v(s)= W(0)$
$\displaystyle (s+\gamma)\ v(s)- \delta\ w(s)= V(0)$ (3)
... where W(0) and V(0) are the so called 'initial values'. The (3) is a pair on linear algebraic equation the solution of which is...
$\displaystyle w(s)= \frac{(s+\gamma)\ W(0) -\beta\ V(0)}{s^{2}+ (\gamma - \alpha)\ s - \alpha\ \gamma + \beta\ \delta}$
$\displaystyle v(s)= \frac{(s-\alpha)\ V(0) + \delta\ W(0)}{s^{2}+ (\gamma - \alpha)\ s - \alpha\ \gamma + \beta\ \delta}$ (4)
Observing (4) we note that we have periodic solutions of (1) only if is $\gamma=\alpha$ and in this case is...
$\displaystyle \omega= \frac{2\ \pi}{T}= \sqrt{\beta\ \delta - \alpha^{2}}$ (5)
... and the constants A,B,C and D are...
$\displaystyle A= \frac{\alpha\ W(0) -\beta\ V(0)}{\omega}$
$B=W(0)$
$\displaystyle C= \frac{\delta\ W(0) -\alpha\ V(0)}{\omega}$
$D=V(0)$ (6)
Kind regards
$\chi$ $\sigma$
Sorry I know that this is an old post, but has anyone been able to estimate the values of the parameters W(0), V(0), A, C, and T using curve fitting? I have come close, with W(0)= 0.00548, V(0)= -0.00507, A=-0.00725, C=-0.00365 and T=100 but I am sure that a better fit is possible.
Fit according to what? Those are initial values given by a certain real-world (or modeled) instance. They cannot be computed.
It is also unlikely that any participant in that old thread will answer. Please create a new thread if you have questions about predator-prey systems.
9K
