Volume of solid x=1+y^2 using shell method
8 replies · 3K views
Painguy
Volume of solid rotated about x-axis x=1+y^2, y=1, y=0, x=0 using shell method
so i set up the integral with
∫2pi(y)(1+y^2)dy from 1 to 2
which is apparently wrong, but i don't know why.
Oh right. My bad I did mean y=2. Well here is my professors solution. If evaluate his answer I get 14. If I evaluate mine I get around 32.
Here is his solution. He seems to be using the washer method.
Your work via the shell method is correct. The result computes to the same value using the disc method that your professor used and the shell method you used.. But it's easier to do it using shells because you only have to deal with 1 integral. Go back and check your computation. You should be getting the same result via both methods. Neither of the final results you got seem to be correct despite the fact that the integrals are correct.
I tried again. This time my professor's answer came out to be around 80.11. My answer however remained at 32, and wolfram alpha and my calculator give the same answer. here is my work.
haruspex said:
80 is obviously too much. The whole solid fits inside a rectangular block 4x4x5. I agree with approx 32 (21 pi/2).
Did I evaluate my professors integral incorrectly?
I get the result
[tex]\frac{21 \pi}{2}[/tex]
via both shell (cylinder) and disc methods)
As I said, the integral you wrote down is correct but somewhere you must have messed up your computation.
