Volume when rotating triangle (-1,0), (0,1), (1,0) around x=2
  • Context: Undergrad
  • Thread starter Thread starter Little Dump
    Revolution Volume
16 replies · 5K views
Little Dump
Included is my attempt at the following question. I get an answer of 10pi, whereas the right answer is (10pi)/3 from my textbook. Here is the question:
Rotate the triangle described by (-1,0),(0,1),(1,0) around the axis x=2 and calculate the volume of the solid.
I basically changed the problem to the following and continued as it is the same
Rotate the triangle described by (1,0),(2,1),(3,0) around the y-axis and calculate the volume of the solid
Thanks for the help
It is so small to understand the pic u quoted so I'm giving u my solution
I hope u will take it from here
http://in.geocities.com/mathsforjee/index.htm
I don't quite understand it and I don't understand why mines wrong :(
I'll keep trying to figure it out.
You may not have had it yet but this looks like an exercise in using Pappus' theorem: the volume of a solid of revolution is the area of a cross section times the circumference of the circle generated by the centroid of that cross section.
In this case, the cross section is a triangle with base of length 2 and height 1: area= (1/2)(2)(1)= 1.
The centroid (for a triangle only) is the "average" of the vertices:
((-1+0+1)//3,(0+1+0)/3)= (0, 1/3). The distance from (0, 1/3) to the line x= 2 is 2- 1/3= 5/3. The centroid "travels in" (generates) a circle of radius 5/3 and so circumference (10/3)pi.
The volume of the figure is (1)(10/3)pi= (10/3)pi.
Is this true for all kind of figure I never came across that theorem is there any link where i can go for reference
Pappus' theorem is true of any "solid of revolution". You should be able to find it in any calculus textbook (that includes multiple integrals.)
I haven't learned that theorem so I don't really think I should use it.
I'm trying to use horizontal rectangles for my area so I formulated the following integral which is how I was taught how to do questions like this.
[tex] \int \pi r_o^2 - \pi r_i^2 dr[/tex]
where
[tex]r_o=(-y+3)[/tex]
[tex]r_i=(y+1)[/tex]
and the limits of integration are from y=0 to y=1
so we have this
[tex] \int_0^1 \pi (-y+3)^2 - \pi (y+1)^2 dy[/tex]
it makes perfect sense to me but then once you work it out you get 10 pi. which is wrong
So can someone point out what I did wrong and how to fix it so I don't do it again.
Thanks very much.
[tex] \int_0^1 \pi r_o^2 - \pi r_i^2[/tex]
fjsjf
Here is the general formula
http://in.geocities.com/mathsforjee/GM.html
does mine not make sense for some reason
i am calculating the area of the circle when the farthest line is rotated and then subtracting the area of the circle when the closest line is rotated
Yes it do makes sense don't you have gone to the previous post.
Thats what u have to do and its general too
Your way do make sense
When you rotate a point about a line u get a circle
Not
When you rotate a line
It would be somewhat like a truncated cone
but i get the wrong answer so can you point out what's wrong with my formulation?
keep in mind i moved the triangle to (1,0),(2,1),(3,0) because its the same problem correct?
Not
I'm rotating horizontal rectangles around the y-axis therefore each rectangle will make a circle
Ok It would form rings as of saturn
U can also do it analytically With no integration
I still want to know what's wrong with this answer because it does not yield 10pi/3
[tex]\int_0^1 \pi (-y+3)^2 - \pi (y+1)^2 dy[/tex]
