Was bored today and searched for a puzzle. Came across this one....
  • Context: High School
  • Thread starter Thread starter haynewp
    Puzzle
The discussion revolves around a puzzle involving the rate of gift-wrapping in a department store, specifically focusing on the calculation of how many gifts were wrapped per hour during a specified period. Participants explore the implications of the information provided and the necessary calculations to arrive at an answer, engaging in a mix of reasoning and debate regarding the interpretation of the problem.
  • One participant states the answer is 8 and seeks an explanation for the puzzle.
  • Another participant challenges the first by asking for calculations and suggesting that the problem is trivial.
  • Some participants propose that the aggregate rate of gifts wrapped rose to seven per hour over the full 60 hours, indicating a misunderstanding of how to interpret the problem.
  • Several participants argue that the colleague's contribution is irrelevant to the final answer, suggesting that the problem can be solved by focusing solely on the aggregate rate.
  • Others contend that the initial 15 hours of wrapping by one girl is necessary to understand the overall context of the problem.
  • There is a discussion about the ambiguity of the problem statement, particularly regarding whether the rate of 7 gifts per hour applies to the last 45 hours or the entire duration.
  • Some participants express confusion about the structure of the problem and whether the information provided is necessary for solving it.
  • One participant emphasizes that the problem is a constant rates exercise, while another suggests that the narrative serves a purpose in contextualizing the math.
  • Disagreement exists regarding whether the first 15 hours of work should be included in the calculations or if they can be disregarded.
  • Participants highlight the need for clarity in the problem statement and express differing interpretations of the information given.
Participants do not reach a consensus on the correct interpretation of the problem or the necessary calculations. Multiple competing views remain regarding the relevance of the initial 15 hours and the role of the colleague in determining the final answer.
The discussion reveals limitations in the clarity of the problem statement, as participants express uncertainty about the time periods involved and the application of the rates mentioned. The ambiguity surrounding the interpretation of the rates and the overall context of the problem contributes to the ongoing debate.
  • #31
DaveC426913 said:
Here is my solution.
Note that it results in the given answer exactly - requiring neither rounding of decimals nor fractions - integers only (which, of it weren't contrived to be so, would be astronomically unlikely).
  • In session 1, (4x15=) 60 gifts were wrapped in 15 hours.
  • In the final tally, a total rate of 7 gifts per hour was achieved over a total of 60 hours.
  • That means a total of (7x60=) 420 gifts were wrapped.
  • But 60 of those occurred in session 1 (15h).
  • Which means the all the rest (420-60=) 360 were wrapped in session 2 (45h).
  • Which makes for a session 2 rate of (360/45=) 8.
Only very, very, very, very slowly, I am beginning to understand. The original problem is badly composed. It may even be said to be ambiguous.
Mathematics news on Phys.org
  • #32
With help from a colleague for the next 45 hours, the amount of gifts wrapped rose to seven per hour. How many gifts were wrapped each hour in the last 45 hours only?
Asking for the last 45 hours "only" makes no sense if the 7 per hour are referring to the same time frame. And who would ask a homework problem that answers itself? Have you ever seen this in homework?
Borg said:
Agree 100%. The statement "for the next 45 hours, the amount of gifts wrapped rose to seven per hour" does not state that seven per hour refers to an average for the entire time that gifts were being wrapped. Reverse the sentence and tell me what you think - "the amount of gifts wrapped rose to seven per hour for the next 45 hours". The problem is at best, very poorly worded and isn't clear in its references.
You changed the sentence. The correct inversion would be "the amount of gifts wrapped rose to seven per hour because a colleague helped for the next 45 hours".
  • #33
It's not a homework question though. If you google it, you'll find it was posted by someone on a puzzle site, with the tag "brain teaser". And the poster posts other questions with tags, "tricky" and "riddle", etc. The answer, 8, is one user's answer, and isn't necessarily correct. It is the top ranked answer out of 1. So who is to say really if the answer is meant to be 7 or 8, or whether it has a correct answer at all? It might just have a subjectively best answer, and it is left to the audience to interpret and vote/debate what the correct answer should be?
  • Skeptical
  • #34
The meaning of a sentence like that one shouldn't change if you reverse it. If you have to modify the reversal in order for it to make sense, then the original sentence wasn't clear. When your modified phrase is reversed, it makes more sense as to its intent.
because a colleague helped for the next 45 hours, the amount of gifts wrapped rose to seven per hour
  • #35
Because, again, the answer works out to 8 exactly, no rounding, no fractions. It would be a fabulous coincidence if that happened by accident due to a misinterpretation. The riddle author has chosen the numbers carefully to arrive at the answer without any math more complicated than 3-digit arithmetic.
  • #36
It appears that you are stating this, correctly I believe, to deaf ears. For reasons I don't understand, some people just don't seem to want to believe it.
  • #37
In their defense, it's not a black and white issue. In our opinions "it's dark grey enough that I think it was meant to be black".
And others are of the opinion that "Dark grey is just a mix of black and white, and opinions are cheap." which is not, technically, wrong. :wink:
  • Haha
  • #38
True. I DO understand the logic behind their point of view but I firmly believe that you have it right. As I posted in post #2 I consider the problem to be trivial. I immediately rejected the, in my view, incorrect interpretation and solved the problem in my head almost immediately, so it did not occur to me to take the alternate interpretation seriously and I still can't take it seriously.
Part of the reason for all that is that, as you have pointed out, the math is trivial using the, to me, obvious interpretation.
  • #39
My reversal was keeping the sentence the same, yours wasn't. The ability to change a sentence by changing it isn't telling us anything.
  • #40
OK, let's try it another way.
In a department store, with only one girl working on the gift-wrapping service, four gifts per hour were wrapped in the first 15 hours. With help from a colleague for the next 45 hours, the amount of gifts wrapped rose to seven per hour. How many gifts were wrapped each hour in the last 45 hours only?
I still find the problem to be highly misleading given the stated answer. As I read through the paragraph, the first sentence states a gift wrapping rate that is an hourly rate and also happens to be the total average hourly rate. The second sentence refers to a time period of 45 hours and a rate of seven per hour. However, it does not specify whether that rate was an hourly rate for the 45 hour period or was a total average hourly rate for the entire (or per @phinds an OVERALL) 60 hour period. With the way that it's written, "the next 45 hours", can easily be construed as being the object of the stated seven per hour rate and would therefore be an average for that time period.
To me, this looks like a trick question that's asking for an answer that they give in the second sentence. If I change the question being asked in the third sentence, the meaning of the information given in the first two sentences should not change (I hope everyone agrees on that at least). How would everyone solve this question given no change in the first two sentences?
What was the average number of gifts wrapped per hour for the entire 60 hours?
Would people assume that this one was the trick question because the 7/hour rate given in the second sentence was an overall rate as many are stating about the original question? Or would the assumption now be that the reader should perform a different calculation because the question is different?
  • #41
I totally did not expect to contribute to this thread, but here we go.
Long story short, the ambiguity is whether we interpret the given rates ("four gifts per hour were wrapped in the first 15 hours," and "the amount of gifts wrapped rose to seven per hour") as instantaneous rates, or average rates. Do we have enough information to tell? I think we do. Let's break it down.
Assumptions:
We should assume that the actual instantaneous rates (given or not) are uniform. Sure it could happen that the girl or girls slowly and gradually improved their gift wrapping skills over the course of the 60 hours. But let's rule that out; there's not enough information in the puzzle statement to justify continuously variable, instantaneous rates. Instead, let's assume that for the first 15 hours, there is a constant, uniform instantaneous rate, and for the next 45 hours there is a separate, but constant, uniform, instantaneous rate.
So the real question is, does the "seven per hour" figure in the "for the next 45 hours, the amount of gifts wrapped rose to seven per hour" statement refer to the instantaneous rate or average rate?
Instantaneous hypothesis:
If we assume that the "seven per hour" figure refers to the instantaneous rate, then the puzzle makes no sense as a puzzle at all. The crux of the riddle -- its final question -- is clearly asking for the instantaneous rate during the last 45 hours only. So if the "seven per hour" refers to that, it's not much of a riddle at all. It just gave you the answer in the preceding sentence.
Average hypothesis:
The key wording leading to this hypothesis is "rose to." The verb is ambiguous in that the change can happen instantaneously, but there is a connotation in "rose to" that the change happens gradually; that's the connotation. Accordingly, this leads to reader to surmise that the "seven per hour" figure is the average rate, and true (i.e., true to be "seven per hour") only after considering the entire 60 hour timeframe.
Conclusion:
So (in my opinion) there is enough information in the riddle to conclude that @DaveC426913's analysis in post #29 is correct. Although there is some ambiguity in the riddle, I believe the puzzle's wording sufficiently addresses the ambiguity such that there is only one, clear interpretation. Thus the clear answer is 8 gifts per hour.
  • Skeptical
  • #42
  • Wow
  • #43
It was an informative discussion and they all clearly agreed that the wording was a mess. However, I am now changing my opinion of what the wording meant.
One post pointed out this pair of options for the placement of the comma in the second sentence:
With help from a colleague, for the next 45 hours the amount of gifts wrapped rose to seven per hour.
The original question is written like the first sentence which places the emphasis for the rate away from the colleague's help. It's still a linguistic mess but if I had to pick two meanings for the rates in those two sentences, it's pretty clear which one goes with each sentence.
  • #44
Dunno, I'm kinda partial to this:
Jarvis323 said:
2) Author intended it to be ambiguous and the real problem is meant to be about understanding/guessing intended meaning from inaccurate and imprecise language based on context.
Remember, this was an online riddle - not necessarily strictly a math problem.
  • #45
I mentally translated it to this:
"I stopped to fill up with gas, and reset my trip odometer and mileage. At 15 miles the average mileage showed 4 miles per gallon. At 60 miles, the average read 7 miles per gallon. What was my average mileage for the last 45 miles?"
But I have recently been on a long driving trip and have been thinking of such calculations. Plus (confirmation bias?) this works out to the given answer, 8 (as mentioned several times, above).
  • #46
This is further less clear than the originally given giftwrappers girl & colleague example.
  • #47
Maybe because I do a lot of driving, and I am used to grappling with the concept of a running average of gas mileage.
But the way gmax phased it removes the ambiguity in the original problem:
- reset my trip odometer
- At 15 miles the average mileage showed 4 miles per gallon
- At 60 miles, the average read 7 miles per gallon.
Since the reset was explicitly mentioned at the start, we can logically conclude that it was not reset anywhere else - (such as: at the 15 mile mark).
Which means the average of 7mpg must needs apply to the entire 60 miles.
  • #48
Hmmm...appears to have turned out that the question actually wasn't trivial at over 40 replies later. This is because of the question's poor wording. It is a trivial question if it is worded correctly. Thanks for the solution that was posted which cleared up the confusion for me. And no it wasn't a homework problem.
  • #49
@haynewp
Where did the original question come from or where did you find it?
  • #52
haynewp said:
"...rose to..."
Now this would be along the lines of NOT instantaneous change, but been a gradual change. More credit for some who argued against our purely constant rates all-at-once interpretation.
  • #53
symbolipoint said:
"...rose to..."
The text is the same as in the OP. 🤔
  • #54
Yes, and only now after all the discussion & explanation here that "rose to" is carrying its meaning so that even I might understand the problem description a little better.
  • #55
haynewp said:
So I am missing something in this one. The answr is 8. Can someone explain?
The answer seems to be 7. It says that for time 15 < T < 60, the rate of gift-wrapping was 7, and if the final time is assumed to be 60 hours, then the last 45 hours was completely within that rate of 7 per hour. The rate for T < 15 is thus completely irrelevant.
  • #56
No it doesn't.
Reread the OP, and then follow the thread, which has addressed the same mistake you've made.
  • #57
DaveC426913 said:
No it doesn't.
Uh, yes it does, at least for the original wording.
  • #58
It is a somewhat natural reading, yes. But it is a reading that makes the subsequent question pointless. So it is a reading that would normally be ignored in favor of the somewhat more strained reading that results in a mildly interesting calculation.
It has been persuasively argued that the resulting ambiguity in the question is intentional. Which would make any disagreement about the true and correct reading pointless. There is no true and correct reading of an intentionally ambiguous statement.
  • #59
I agree that the original wording makes it pointless question, other than to be a trick question. The thing is, what part of the question shall be presumed mistaken? I didn't a single logical conclusion.
  • #60
Is this horse dead yet?
  • · Replies 31 ·
  • · Replies 21 ·
  • · Replies 19 ·
10K
  • · Replies 67 ·
17K
  • · Replies 18 ·
9K
