Harveyf
- 22
- 0
John; now I understand you completely.
The discussion revolves around the nature of space in relation to the Big Bang, specifically whether space existed prior to the Big Bang or was created as the universe expanded. Participants explore theoretical implications, philosophical questions, and the conceptual challenges of understanding space, time, and matter in this context.
Participants express a range of views on the relationship between space and matter, with no consensus reached. Some agree on the simultaneous creation of space and matter, while others challenge this notion, leading to ongoing debate and exploration of the topic.
The discussion reflects various assumptions about the nature of space, time, and matter, with participants acknowledging the limitations of current scientific understanding and the challenges of conceptualizing these fundamental aspects of the universe.
Those ideas were never part of science.4Newton said:Science has been unable to recognize simple solutions many time in the past. Does the sun go around the Earth or is the Earth flat?
4Newton said:The Big Bang (BB) theory states that the universe ... expanded outward in all directions.
All the contents of the universe are transitioning outward at the same rate and form a sphere with a hollow core.
The speed of light is the only known limit of the rate of the expansion outward from the BB. This rate is the maximum rate of transition of all things in the universe.
Because the universe is expanding outward at a transition rate equal to the speed of light
Harveyf said:My goodness, but the forum has suddenly erupted with dialectic on ideas in the expansion of space and hyperspheres. I am humbled by the profundity of thought. Then, too, I almost feel grateful that I cannot visualize the mathematical formulae as applied to the quantum physics required to dialogue on these theorum. I trust you will forgive my limited capacity for comprehending the exactitude of the science behind your ruminations, but I would appreciate continuing in this forum, if only to attempt receiving a glimpse of the far-flung territory you are covering in these debates.
BBT does not speak of an outward expansion. It's more like the points in the universe are getting farther apart from each other.
description of this other dimension as Time sounds better.
It's the maximum rate of motion through space, not the maximum rate of the expansion of space. (e.g., the early inflationary period)
Are you referring to the Hubble Constant (our observed expansion of space) or the expansion of the hypersphere you describe away from its center?
If you stay around for many of the ideas you may need to change you mind.I've been able to exclude such (religious interpretation) mythology from the reality of existence, and time and space.
Yes your thought is a possibility, but because the number of possibilities are infinite without some thread of connection to reality it will lead no where.if there ever was a BB [like it appears there was], cannot the universal space accommodating it be created simultaneously?
Because of the direction you are coming from it may help if you think of the process in this manner.If, as you intimate, the "red shift" is indicative of material within the universe increasing its velocity away from the "core" of where a BB might have originated [for whatever reason], what might be the ultimate destiny of matter within this reality
I think you have much more to contribute then you realize. You already have my respect and I do extend my friendship.who is to say that even this mind might not succeed in contributing something new to the equation of the why and wherefore of creation? With respect, and in friendship.
If you consider the concept in its simple form you may eliminate all but two dimensions and look at a circle. An expanding circle has a radius that is increasing as the circumference is also increasing. Two points on the circle one-radian apart are increasing their distance at the same rate as the radius is increasing.The one-radian idea was murky. I didn’t bother to understand it. I did ACCEPT IT and pursued a model where light can only travel 60 degrees (or so) around the surface of the expanding bubble. It never really worked in my head, but I didn’t get uptight.
If the transition outward from the BB is at a rate equal to the speed of light, as stated above, then the light from distant objects can only be seen up to one-radian. Observation indicates that redshift for distant objects are in the range close to the speed of light and the z for the background radiation is equal to about 1100. Also if light could go around and around many times you would see the background radiation repeat at a lower frequency each time it went around.As for red shift going to 0 at one radian: I believe light has the ability to go around and around the expanding bubble. But we see light that was given off at an earlier time, which means the bubble was smaller then, so the light has followed a spiral path to get to us. It doesn’t matter how many times it has spiraled around.
Strings and super strings are only a question of dimensional view of matter, forces, and energy and I don’t think they warrant being extended to branes and the construct of the universe. I think this should be a topic of (mass, gravity, and charge) and belongs in the physics area.universe trapped between a leading edge brane and a trailing edge brane thus resembling a universe embedded in a bubble skin 13.7 billion light years thick...ie, seemingly the time it takes for a photon to travel in a straight line between the two branes
