Water found on potentially habitable exoplanet
  • Context: High School
  • Thread starter Thread starter phinds
    Exoplanet Water
8 replies · 5K views
Insights Author
Dearly Missed
TL;DR
water found on potentially habitable exoplanet
Summary: water found on potentially habitable exoplanet
from the BBC
https://www.bbc.com/news/science-environment-49648746
Astronomy news on Phys.org
That planet probably has a higher air pressure than Earth, and has no oxygen in the atmosphere (it was mentioned somewhere that there are significant amounts of hydrogen there, so no oxygen, except trace amounts, is possible at same time).
Actually it is yet unknown. Water+Hydrogen models had better fit than Water+Nitrogen, but the difference is not significant.
Sounds neat, but as the article in the OP mentions, this one is not a good candidate for finding extraterrestrial life.
Even if it did have a rocky surface and relatively thin atmosphere (as opposed to the Neptune-like planet many scientists apparently think it is), 50% water vapor in the atmosphere sounds to me like the result of a runaway greenhouse effect, which would also make the planet utterly uninhabitable.
I find this mostly interesting for demonstrating potential in detecting water around other planets. Hopefully over time the sensitivity will increase significantly to the point that even small amounts of water vapor are detectable.
If Hubble can do this, imagine what JWST and the next generation of Earth-based telescopes will be able to do (although water is difficult for Earth-based telescopes).
Water contains oxygen. :)
Free oxygen gas is not likely to be mixed with hydrogen gas. Oxygen is hostile to the early life that evolved on Earth. The planets located in habitable zones get attention because researchers are looking for life.
My impression from the article was that they detected water vapor. They said they assumed water would condense into clouds. They also did not specify if the gas was hydrogen or helium. They used the term H/He. The planet's mass is close to the range where hydrogen could escape faster than helium.
Can't wait till we hear about discoveries made with the James Webb telescope :o
