Water Mass Calculation for Vessel Under Different Conditions
1 reply · 3K views
xzibition8612
Calculate the mass of water contained in a 0.6 ft^3 vessel under the following conditions:
a) 15 psia, 300 F
b) 100 psia, 500 F
c) 20 psia, 210 F
d) 60 psia, saturated vapor
e) 60 psia, saturated liquid
f) at the critical state
PV=mRT
I suppose the ideal gas equation is valid? Can someone explain to me why or why not?
Assuming it's valid, for a,b the temperature is above the saturation (boiling) temperature, so R would be the water gas constant? For c, d, e, and f, I don't know what values to plug in for R. Any help would be appreciated. Thanks.
I think you are to determine if the vessel contains watwr as a vapour, as a liquid, or some combination of both for the cases. Water vapour doesn't follow the ideal as law so I suspect you have to use your steam tables.
saturation temperature and saturation pressure go hand in hand, so your comment that for a, b the temperature is above saturation temperature is invalid ( the boiling temperature you are thinking of is valid for atmospheric pressure )
do you know what the terms saturated vapour, saturated liquid and critical state mean - you should familiarize yourself with these terms. ( Use wikepedia if you like, or your textbook should have them defined )
