Wave interference, finding amplitude in certain situations
The discussion focuses on calculating the amplitude of sound waves emitted by two loudspeakers positioned along the x-axis. When the speakers are 10 cm apart, the sound intensity is at a minimum, while it reaches a maximum amplitude of 2a when one speaker is 30 cm ahead of the other. The phase difference is calculated as -0.7854 radians, leading to the conclusion that the amplitude when the speakers are side by side is given by the formula A = 2a*cos(ΔΦ/2), where ΔΦ is the phase difference.
  • Understanding of wave equations, specifically y = A cos(kx) and y = A cos(kx + φ).
  • Knowledge of phase difference calculations in wave interference.
  • Familiarity with trigonometric identities, particularly the sum of cosines identity.
  • Basic principles of constructive and destructive interference in sound waves.
  • Study the derivation of the wave equation for two interfering waves.
  • Learn about phase difference and its impact on wave interference.
  • Explore the application of trigonometric identities in wave mechanics.
  • Investigate the effects of varying distances between sound sources on amplitude and intensity.
Students studying physics, particularly those focusing on wave mechanics, sound engineers, and anyone interested in understanding sound wave interference and amplitude calculations.
aliaze1
Two loudspeakers emit sound waves of the same frequency along the x-axis. The amplitude of each wave is a. The sound intensity is minimum when speaker 2 is 10 cm behind speaker 1. The intensity increases as speaker 2a is moved forward and first reaches maximum, with amplitude 2 a, when it is 30 cm in front of speaker 1.
What is the amplitude of the sound if the speakers are placed side by side?
ΔΦ = 2π[(Δx)/λ] = 2mπ , m = 0,1,2,3...
I found the following:
λ = 80cm
Phase difference = ¾π (0.75π) =~ 2.36radians
I tried drawing it but I am not getting the correct answer, and I don't know what to do...
You have the amplitude... so try to write the wave equation for the two waves... Use the equation:
y = A cos (kx) for speaker 1
y = A cos (kx + phi) for speaker 2
you know k = 2pi/wavelength. you know A = 80. Try to use the fact that when speaker two is moved 30m in front of speaker 1, then there is constructive interference... hint a motion of 30m, is a shift in the positive x direction.
Once you know the equations for both waves, add them and find the amplitude for the sum.
Excuse me but why would A= 80?
wouldnt x =80
I'm sorry. A is not 80... amplitude is unknown variable a. I should have written wavelength is 80cm.
I'm getting a phase difference of -0.7854 radians
Using these and adding
y = a cos (kx) to
y = a cos (kx + phi)
where phi = -0.7854 and k = 2pi/0.80 = 7.854
you can get the amplitude of the sum in terms of a... you can either use trig identites to get the amplitude of the sum... or use phasors...
what about x?
y = a cos ( (2pi/.80)(0)
y = a cos ( (2pi/.80)(0.30) -0.7854)
is that correct?
Draco said:
what about x?
is that correct?
No. don't substitute in an x.
2pi/.80 = 7.854
You need the function:
y = acos(7.854x) + acos(7.854x - 0.7854)
don't substitute in an x... you need to find the amplitude of this function... you can write this sum of two cosines as a single cosine...
try to use this identity. cosA + cosB = 2*(cos[(A+B)/2])*(cos[(A-B)/2]), where A = 7.854x and B = 7.854x - 0.7854
you should get something of the form:
y = (unknownamplitude)*cos(7.854x + unknownphase)
What is The amplitude of the sound if the speakers are placed side by side?
A = 2*a*cos(\Delta\Phi/ 2)
The amplitude has its max value A=2a if cos(\Delta\Phi/2) = +/- 1.
This is not the case so take a out.
2*cos(\Delta\Phi/2)=.765
Something a friend told me that's a little clearer to me and perhaps others.
  • · Replies 19 ·
