Film Thickness for Minimum Reflection of Monochromatic Light: How to Calculate?
The discussion centers on calculating the minimum film thickness for a thin film with an index of refraction n1, coated on a material with a higher index n2, to achieve minimum reflection of monochromatic light with wavelength λ. The correct formula for minimum thickness is derived from the equation 2t = (m + 0.5)λ/n1, where m is any positive integer. The phase shifts at the boundaries are crucial for determining the conditions for destructive interference, confirming that n2 does not factor into the thickness calculation beyond introducing a phase shift.
  • Understanding of thin film interference principles
  • Familiarity with optical path length concepts
  • Knowledge of phase shifts in wave optics
  • Basic algebra for manipulating equations
  • Study the derivation of the thin film interference equations
  • Learn about phase shifts at boundaries between different media
  • Explore applications of thin films in optics and coatings
  • Investigate the impact of varying indices of refraction on reflection and transmission
Students studying optics, physics educators, and professionals in optical engineering who require a deeper understanding of thin film interference and its applications in minimizing reflection.
Erickly
Monochromatic light of wavelength, λ is traveling in air. The light then strikes a thin film having an index of refraction n1 that is coating a material having an index of refraction n2. If n2 is larger than n1, what minimum film thickness will result in minimum reflection of this light?
Multiple choice:
A λ/n1
B λ/(4n1)
C λ/n2
D λ/2
E λ
F λ/(4n2)
G λ/(2n1)
H λ/4
I λ/(2n2)
J The correct response is not shown above.
2t = m*λ/n
2t = (m+0.5)*λ/n
where m is an integer, n is the refraction index of light, and t is thickness.
So I believe the wave is destructive because there are 2 phase changes. One when light enters it and the second when it hits passes the coating. Therefore the equation is the second one. I reasoned M must be zero because otherwise I would get a number in the numerator when there is not one in the multiple choice. So if we dived the 2 we get t = λ/4n(something) I don't know if the n is supposed to be 1 or 2.
Any help is greatly appreciated!
Multiple choice:
A λ/n1
B λ/(4n1)
C λ/n2
D λ/2
E λ
F λ/(4n2)
G λ/(2n1)
H λ/4
I λ/(2n2)
2t = m*λ/n
2t = (m+0.5)*λ/n
You are on the right track. The second equation is the right one. What is wrong with m=0?
As for whether the denominator should be n1 or n2: What is the optical path length for a ray that goes through n1, reflects at the n1-n2 boundary, then passes through n1 again? That should answer if it's n1 or n2 ...
So I guess since it goes through a phase change m cannot be zero (maybe m = 2?)? Also would the n be n1 because it never enters n2? (assuming it has 1 phase change when entering n1 and then bounces off n2 without entering it)
Answer to second question - yes.
Again - why not m=0? You say there's a "phase shift" (meaning a phase shift of pi) between n1 and n2, which is correct. But what about a phase shift between the air and n1? What if both beams get a phase shift of pi each, what would that say about the net phase shift between the two beams due to reflection alone? And what does the total shift between the two beams have to be to get destructive interference?
If you're going to understand what's going on you need to understand why you picked the second equation. As it is you just lucked out. ( I really shouldn't have confirmed that it's the right one in the first place.)
Again - why not m=0? You say there a "phase shift" (meaning a phase shift of pi) between n1 and n2, which is correct. But what about a phase shift between the air and n1? What if both beams get a phase shift of pi each, what would that say about the net phase shift between the two beams due to reflection alone? And what does the total shift between the two beams have to be to get destructive interference?
So I guess my problem is I don't really understand what m is. I know its an integer and thought is it the number of times light passes through a medium that causes part of the ray to reflect. That is why I thought it is 2.
As for destructive, I know what it means ( the waves, when added together cancel parts of each other out). I thought this is destructive because n1 < n2 (similar to another example problem I had in lecture ).
Do I have the right idea here?
m is any positive integer including zero. It's the number of wavelengths of total optical path difference, corrected if necessary by reflection of half a wavelength. But you should not worry about that. To you m is just any positive integer. Any positive integer value of m makes the equation correct.
They don't cancel parts of each other out, they cancel all of each other out.
Yes, going from n1 to n2 means destructive interference by itself. But there is more to the problem than that. There is the phase shift due to travel inside n1 and there may be a second pi phase shift between the air and n1 which you have to decide is the case or not.
Ohhh the first part makes more sense now, its like a unit circle and adding 2pi correct? if you take the sin of 60deg and sin of 60+360deg its the same value. Is that the correct way of thinking about m?
As for the second part I believe there is a phase change between air and n1 because n_air =/= n1. If that is true then what do I do with that information?
Most definitely, yes.
How about combining that with the other reflection (n1 to n2) and the optical path length difference to come up with destructive interference between the two beams?
Well would it give me this relationship: 2t = ( m + 0.5 ) λi / n where lambda i is wave length in air and therefore n must be n1? That way I relate air to n1. Since n1 < n2 perhaps it bounces off n2 but doesn't pass it, therefore I do not use it in the equation?
Is that what you meant? I'm sorry its taking me so long to understand this.
That's not all I meant but yes, the rays don't penetrtate into n2 so the only thing to worry about there is the phase shift at the n1 - n2 interface. n2 does not enter into the calculations other than the pi phase shift.
Okay so if we plug in values, ( m = 0 // N = n1 ) t will be Lambda over (4*n1)?
I'd put my money on that! :smile:
Congrats for not letting go!
Thank you so much for all your help! I'm very grateful, hopefully I can pass it forward someday!
9K
