What Determines the Speed of Waves?
Wave speed is primarily determined by the properties of the medium, specifically its elasticity and mass density, as indicated by the equation v = √(τ/μ). While the relationship v = λƒ shows that wave speed is also connected to wavelength and frequency, this equation holds true regardless of the medium's characteristics. In most cases, the medium's properties dictate wave speed independently of wavelength and frequency, except in phenomena known as dispersion. This principle is particularly relevant for waves in stretched strings and three-dimensional compressible media, but does not apply to two-dimensional waves like surface water waves. Understanding these distinctions is crucial for grasping wave behavior in different contexts.
duran9987
A bit confused here as to what wave speed is dependent on. At first I learned that v = λƒ, and a couple of pages later in my textbook I find that v = √(τ/μ). Also, I found that speed is only dependent on the properties of the medium, specifically its elasticity and mass. Where does wavelength and frequency come into play if the medium is the only dependent?
none
In many contexts, the properties of the medium determine the speed of waves in it independently of their wavelengths. This is (mostly) true of waves in a stretched string and waves in a 3 dimensional compressible medium. Any deviation from this is known as dispersion. In particular, it does not apply to 2 dimensional waves, such as surface waves on water. See http://en.wikipedia.org/wiki/Dispersion_(water_waves).
Regardless of what determines the speed of a wave, its frequency and wavelength are always related by v = λƒ.
  • · Replies 29 ·
18K
