Wavefunctions that don't satisfy Schrödinger equation
The discussion revolves around the implications of having a normalized wavefunction that does not satisfy the Schrödinger equation in one dimension. Participants explore the potential information such a wavefunction might provide about a particle's state, its probability distribution, and the relationship between wavefunctions and observables in quantum mechanics.
  • Some participants propose that a normalized wavefunction not satisfying the Schrödinger equation can describe the particle's state at a specific time (t=0) but cannot predict its evolution over time.
  • Others argue that if a wavefunction does not satisfy the Schrödinger equation, it does not correspond to any actual physical situation, likening it to a classical object that does not obey Newton's laws.
  • A participant highlights the importance of normalization and the properties of the vector space of square-integrable functions, suggesting that any normalized wavefunction must be expressible as a linear combination of solutions to the Schrödinger equation.
  • Some participants question which version of the Schrödinger equation is being referenced, noting the distinction between the time-dependent and time-independent forms.
  • There is a discussion about the role of observables in quantum mechanics, with some asserting that observables are primary, while others emphasize the significance of the wavefunction itself.
Participants express differing views on the implications of having a normalized wavefunction that does not satisfy the Schrödinger equation. There is no consensus on the nature of such wavefunctions or their relevance to physical systems.
Participants note the importance of specifying the type of Schrödinger equation being discussed and the potential limitations of their arguments regarding the mathematical properties of wavefunctions and observables.
plazprestige
If there exists some normalized wavefunction ##\psi## that is not a solution to the Schrödinger equation (1D), what does this mean? You can still presumably use the square of the wave function to ascertain the probability it exists at some interval in space, but does it provide any other useful information about the state of the particle? Why or why not?
Note: I am learning about QM in a physical chemistry course, so I am not familiar with the mathematical nuances of the physics.
It can still describe the particle at t=0, but can not tell you how the wave-function will evolve. Consider what happens when a particle encounters a change in potential and the wavefunction changes. The old wavefunction applies at the boundary, but only the new wavefunction can describe what happens on the other side of the boundary.
So when you find the probability of finding the particle by integrating the square of the wave function in such a case, you are only getting the probability at t=0? Whereas if the wave function satisfied the Schrödinger equation, it would allow you to find the probability (as well as other attributes) at all times?
What matters is the dynamical algebra of observables that characterize a particular (class of) physical system(s). The only purpose of the Hilbert space and the wave functions therein is to be a framework for constructing a unitary representation of that algebra of observables.
Consider a similar question in classical mechanics: one has a phase space (positions and momenta), and observables are functions on that phase space. The equation(s) of motion for a particular classical system define a solution space which is subspace of the larger phase space. Dynamical symmetries of that system map solutions into solutions, hence they leave the solution space invariant. The point here is that the larger phase space is just a mathematical framework. To describe a particular class of systems, we must specify equations of motion, and the observables of that system then corresponding to generators of the symmetries which preserve that equation of motion.
The QM case follows similarly, except that instead of representing observables as functions on phase space, we represent them as operators on a particular Hilbert space of wavefunctions which satisfy a particular Schrödinger equation. I.e., you can think of the Hilbert space analogously to the classical solution space: we're only interested in wave functions which are relevant to a particular physical situation. In general, the Hilbert spaces of wave functions relevant to distinct physical situations are different. Compare, e.g., free motion with the bound motion in a (subthreshold) Kepler/Hydrogen problem.
So... if you have a normalized wave function, but no Schrödinger equation, you're not describing any actual physics.
Thanks strangerep,
Some of that went over my head, but this is what I gathered from your explanation
Having a wave function that is not a solution to Schrödinger's equation is like having a classical object that doesn't obey Newton's second law: in both cases, you cannot predict the future state (or, in other words, how the particle will evolve over time).
Is this correct?
Yeah, I became a bit worried by that possibility halfway into my post.
I was really just trying to counter the common misconception that it's the wavefunction that's primary. In fact, it's the observables characterizing a (class of) systems which are primary.
("Observables" are things like: energy, momentum, angular momentum/spin, etc. For more complicated systems there may be more, e.g., the Runge-Lenz vector for Kepler/Hydrogen.)
I'd phrase it more strongly: such "objects" are merely in your imagination, with no correspondence to reality.
plazprestige said:
If there exists some normalized wavefunction ψ\psi that is not a solution to the Schrödinger equation (1D), what does this mean?
A somewhat less abstract answer:
The word "normalized" is very important here. The normalization condition (in 1D, for example) is \int_{-\infty}^{\infty}{|\psi|^2 dx}=1Functions that fulfill this condition are called square integrable, or L^2, and the set of all such functions forms a vector space (this vector space has particular properties, for which it gets a special designation as a "Hilbert space," but that's not terribly important for us right now). A vector space is a lot like ordinary 3D space, except it can have an arbitrary number of dimensions (even infinite), and whereas each point in 3D space represents a position, each point in the L^2 vector space represents a function (how about we call it \psi?).
One important property of vector spaces, which might be familiar to you from linear algebra, is that every vector space is spanned by a basis. Every point in 3D can be represented as a vector of the form x \mathbf{\hat{i}} +y \mathbf{\hat{j}}+z \mathbf{\hat{k}}, so we can say that \mathbf{\hat{i}}, \mathbf{\hat{j}}, and \mathbf{\hat{k}} form a basis which spans 3D space. In exactly the same way, we can choose a basis set \phi_i, i \in \mathbb{N} that spans L^2 space, such that an arbitrary square integrable function \psi can be represented as a vector of the form \psi =\sum_i{a_i \phi_i}The above framework is important because the Schrödinger equation is linear in each of its variables. This means that any linear combination of solutions is also itself a solution to the Schrödinger equation. So if you have a set of eigenfunctions \phi_i that solve the Schrödinger equation for an arbitrary potential V(x), then any function \psi =\sum_i{a_i \phi_i}also solves the Schrödinger equation for that potential. It also just so happens that any set of eigenfunctions which solve the Schrödinger equation also span the relevant vector space.
So to sum up, if you have a normalized wavefunction, it must be a solution to the Schrödinger equation, with arbitrary potential. It likely won't be an eigensolution, but it will definitely be a linear combination of them.
[Technical note: I'm not a mathematician, so I don't know if these statements are true everywhere, or merely almost everywhere (everywhere except a set of measure zero). I expect the latter is true, but I don't know enough about measure theory to speak to it.]
I feel like there's a few points that have been missed or glossed over so far.
1) Which "Schroedinger equation" are you talking about? The time-independent SE or the time-dependent SE?
2) The time-independent SE is really just an eigenvalue equation. The solutions of this equation, using the normal terminology, usually means the eigenfunctions. We solve for the eigenfunctions in order to make solving the time-dependent SE easier. That's the entire point of the time-independent SE. A wave function which is not "a solution" (i.e. not an eigenfunction) of the TISE, as TeethWhitener points out, can be represented by linear superpositions of the eigenfunctions. This is because, as mentioned, the eigenfunctions span the space (a proof of this; however, is non-trivial).
3) The time-dependent SE is where the physics actually lies. Solving the TDSE is the goal of quantum mechanics. A solution of the TDSE is a wave function which evolves in time according to the TDSE. In other words, given some initial wave function, the wave function at any subsequent time must be found by solving the TDSE forward in time. Therefore, a wave function which does not evolve in time as the TDSE dictates is not a solution of the TDSE. Such a wave function would be unphysical. The Schroedinger equation is a postulate of quantum mechanics, so if you work with wave functions which are not solutions of the (TD) Schroedinger equation, then you are not doing quantum mechanics.
"Not a mathematician"? Close enough.
  • · Replies 143 ·
12K
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 128 ·
15K
