WaveLengths of Light Waves and their respective photons
The discussion revolves around the emission of photons from a light source with a specified wavelength of 2 meters, particularly focusing on the implications of turning the source on and off alternately. Participants explore the nature of photon emission, the effects of timing on photon detection, and the relationship between wavelength and the mechanisms of photon production. The conversation touches on both classical and quantum perspectives.
  • Some participants assert that photons can be modeled as point particles, suggesting that photons will be detected regardless of the timing of the device's operation.
  • Others argue that the nature of photon emission is discrete and that the wavelength of emitted photons is fixed, implying that shorter time intervals do not produce shorter wavelengths.
  • A participant introduces the concept of the time-bandwidth theorem, indicating that the operation of a chopper will increase the bandwidth of the emitted radiation.
  • There is a discussion about the efficiency of the device used to switch the light source on and off, with some suggesting that the placement of the device (inside or outside a laser cavity) affects photon detection.
  • One participant mentions that a photon does not need to have a definite frequency, challenging the conventional understanding encapsulated in the equation E = hf.
  • Another participant elaborates on the idea of superposition, explaining that photons can exist in a state that is a combination of different frequencies, which may not be monochromatic.
Participants express differing views on the implications of the device's operation on photon detection and the nature of photons themselves. There is no consensus on whether the timing of the device affects the emission or detection of photons, and the discussion remains unresolved regarding the relationship between photon frequency and energy.
Participants highlight various assumptions about the nature of light and photon emission, including the dependence on the device's configuration and the implications of classical versus quantum models. The discussion also reflects on the limitations of understanding photon behavior in terms of discrete emissions versus continuous waveforms.
user3
Suppose you have a source of light that emits light with a wavelength of 2 meters, and you set the device to be turned on and switched off alternately. You also set it so that each interval the device is turned on is only long enough for 1 meter to be emitted (1/2 a wavelength). Do you ever observe any photons?
Since photons can be modeled as point particles ... the answer is yes.
And if your detector provides an energy spectrum, it will always give the energy for one of these photons.
This question is absurd, if the photons emitted have wavelength of 2 meters, then we assume that source can emit only 2meters(wavelegth) photons. Its not like in shorter time shorter wavelengths come out and in longer time longer one`s come out, radiation is discreet!
We must also understand how photons are produced, they are generally through de-excitation of electrons in energy levels, however only visible photons can be produced that way, for wavelengths of 2 meters(VHF-range), they use other methods, but photons are discreet and the wavelength output does not depend on the on/off time. The delta-t, will affect only the spectral width.
I hope it helped.
How does the alternate switching affect photon density? If it has no effect, can it be used to reduce power consumption at transmission antennas?
I hope it helped.
I did not say shorter time intervals produce shorter wavelengths. Instead, I said it they will produce fractions of a wavelength.
For a wavelength of λ the time for a complete cycle is Δt=λ/c=1/frequency.
Your device has a shutter that cycles open-close twice during Δt.
You must first check your assumptions-start with classical electromagnetic radiation: if the wavelength/frequency is fixed then the emitter must be running continuously - you understand why this is true?
Your "chopper" will then increase the bandwidth of the system - this is a consequence of the time-bandwidth theorem, which is a very general result for classical waves. The details of how it does so varies with the physical setup, but it always takes place.
As you increase the speed of the chopper the bandwidth continues to increase; if the emitter is inside a cavity (enclosed space) the radiation that does not escape will accumulate ("rattle around") inside the cavity. Eventually it will reach some equilibrium state - and your device will approach that of a black body.
You can actually build a small radio transmitter (or buy one) and test this. If it was a laser experiment I would use an electrooptic shutter; you will have to find something else for radio waves.
With this classical description in mind, a quantum optical model can be built.
What should we expect? For a system which is periodically excited and then emits a single photon - I think your detector will sometimes click, and sometimes not.
In my opinion, this depends on what kind of device you are using to make system shut down and switch on. if this device is in the laser cavity, well, your laser-system must very efficient to observe the light, because the photon only passes the gain medium once and then should be blocked by your device. If it is put outside the cavity, you device is just a chopper. and yes, you will observe the laser coming out, just the number of the photon is small, and the bandwidth is very large.
DrDu said:
And, btw, a photon does not need to have a definite frequency.
It's the first time that I have been told that. How is that? What about this E = h f ?
Please elaborate
Please elaborate
That is a consequence of the superposition principle. If a photon can exist as red or green monochromatic light, also a superposition of the two is a valid (but time dependent) quantum state for a photon.
E.g. a photon emitted by an atom is never monochromatic but a wavepacket formed from different frequencies so that the energetic width of the packet is inversely proportional to the lifetime of the excited atom.
  • · Replies 16 ·
  • · Replies 33 ·
  • · Replies 19 ·
  • · Replies 0 ·
