Vibrations of a Stretched String: Finding Harmonic, Frequency & Wave Speed
The discussion focuses on a 7-meter long string fixed between two walls, vibrating with a displacement described by the equation y = 0.023sin(xpi)cos(0.714 pi t. Participants analyze the harmonic number, frequency, and wave speed of the string. It is determined that the vibration corresponds to the 7th harmonic, as N equals 7. The frequency can be derived from the term "0.714 pi t," while the wave speed can be calculated by comparing the given equation to the standard wave equation format. The conversation emphasizes using the relationships in wave mechanics to solve for the required parameters.
Fusilli_Jerry89
A 7 metre long string is stretched between 2 walls so that its ends are fixed. It is made to vibrate and it is found that the displacement, y is given by: y = 0.023sin(xpi)cos(0.714 pi t) where x and y are in metres and t is in milliseconds.
a) to which harmonic, N, does the vibrtion correspond?
b) What is the frequency of the sound emitted by the string?
c) What is the speed of waves in the string?
y(N) = 2y sin((Npix)/L)cos((vNtpi)/L)
To get part a, can u use the formula and see that L must equal N in order to get the equation in the question, or no? I'm lost.
Yes, you're right. N must equal L to get the equation you have:
So N = 7.
Another way to look at it... Find the angle at the end of the standing wave... The angle is xpi... that's coming from 0.023sin(xpi)cos(0.714 pi t)
So what's the angle you get when you plug in x = 7 (end of the standing wave since the walls are 7m apart). you get 7pi. That means the 7th harmonic.
Solve b using "0.714 pi t"
You should be able to solve c, in the same way as a... by comparing: y = 0.023sin(xpi)cos(0.714 pi t) to y(N) = 2y sin((Npix)/L)cos((vNtpi)/L)
what does v need to be...
