Webassign - Dropping a Package From a Helicopter
  • Thread starter Thread starter berenmacbowma
    Helicopter
The discussion focuses on calculating the time it takes for a package dropped from a helicopter ascending at 2.00 m/s from a height of 160 m to reach the ground. The initial attempts incorrectly included the time for the helicopter's ascent, leading to erroneous total time calculations. The correct approach involves determining the additional height gained by the package after being released and then calculating the time to fall using kinematic equations, specifically accounting for the acceleration due to gravity at 9.8 m/s². The final solution requires summing the time for both the upward motion and the subsequent fall.
  • Understanding of kinematic equations in physics
  • Knowledge of uniformly accelerated motion
  • Familiarity with the concept of gravitational acceleration (9.8 m/s²)
  • Ability to perform basic algebraic manipulations
  • Review kinematic equations for uniformly accelerated motion
  • Learn how to calculate the time of flight for objects under gravity
  • Explore the effects of initial velocity on projectile motion
  • Practice similar physics problems involving vertical motion and acceleration
Students studying physics, educators teaching kinematics, and anyone interested in solving problems related to projectile motion and gravitational effects.
berenmacbowma
Q: A helicopter is ascending vertically with a speed of 2.00 m/s. At a height of 160 m above the Earth, a package is dropped from a window. How much time does it take for the package to reach the ground?
Attempt:
[how long it takes to reach the height]
v=delta d/time
2=160/time
2(time)=160
time=80 seconds
[how long it takes to fall]
v=delta d/time
9.8=160/time
9.8(time)=160
time=16.326
80+16.326
96.3 s (which is wrong.)
berenmacbowma said:
Attempt:
v=delta d/time
2=160/time
2(time)=160
time=80 seconds
The time it takes for the helicopter to reach the given height is irrelevant. They just want the time it takes for the package to fall to the ground, starting from the moment it is dropped.
v=delta d/time
9.8=160/time
9.8(time)=160
time=16.326
9.8 m/s^2 is the acceleration of the falling package, not the speed.
How can you express the position of the package as a function of time? It is uniformly accelerated motion. (You'll need to review your kinematic equations. Here's a list: Basic Equations of 1-D Kinematics)
Attempt:
v=delta d/time
2=160/time
2(time)=160
time=80 seconds
Read the question again. When the package is released at 160m it is traveling upwards at same speed as the helicopter. It will carry on upwards for a bit. You need to work out how much higher it goes and add that to the 160m. Also calculate the time that phase takes.
Hint: Use one of the equations of motion to account the deceleration due to gravity.
v=delta d/time
9.8=160/time
9.8(time)=160
time=16.326
80+16.326
Having worked out the height it reaches in part one you can then work out how long it takes to fall.
Then add the time for each phase together.
Hint: use one of the equations of motion to take into account the acceleration due to gravity.
the upward motion the package will have will be rather insignificant because the 2m/s speed isn't fast enough to make a difference in the problem, keep in mind this is a basic physics homework, the person that made the exercise wasn't probably thinking of the upward motion, since this is probably a high school exercise.
The difference is about 7%.
I suspect that the author of the problem was well aware of the upward motion--that's part of the point of the exercise. Such problems are standard fare.
