Weight & Buoyancy: Will the Measured Weight Be Less?
  • Thread starter Thread starter krayziemuzick
    Bouyancy Weight
The discussion revolves around the concept of buoyancy and weight measurement in a scenario involving a block of wood floating in water. Participants explore whether the measured weight of the system (beaker, water, and block) would be less than the sum of the individual weights due to the buoyant force acting on the block.
  • Exploratory, Assumption checking
  • Participants consider the implications of Archimedes' principle and the effect of buoyant forces on weight measurements. Some question whether the buoyant force should be subtracted from the total weight, while others explore different scenarios involving the placement of objects in a medium.
The discussion is ongoing, with various interpretations being explored. Some participants express uncertainty about the effects of buoyancy on weight, while others provide insights into the relationship between density and weight. There is no explicit consensus, but productive questioning is evident.
Participants are navigating assumptions about buoyancy and weight measurement without definitive conclusions. The original poster expresses a desire for clarification over the weekend, indicating a time constraint in the discussion.
krayziemuzick
A block of wood floats in a beaker of water. According to Archimedes' principle, the block experiences, an upward buoyant force. If the beaker wit the water and floating block were weighted, would the measured weight be less than the sum of the weights of the individual components? Explain.
So here is what I am thinking, I think the weight would be less. If weight is mg but there is a negative force acting through the bouyancy force this should be subtracted, making it less than the sum of the individuals. If my thinking right? Its the weekend and I didn't want to wait until monday :)
Thanks for any help!
What if you had a bucket full of rice? Do you think it will weigh differently if you place a block on top of the rice or bury it in the rice or weight the bucket and the block separately?
I suppose then it wouldn't matter at all. So then even though there is a force pushing the block up keeping it a float, the mass of the block is still being pushed down making the whole thing weight the same as the sum of the individuals..
The reason the block floats is a property of the matter - density. But the total matter is not determined by the density.
The total matter does however determine the weight. Since you are not creating or destroying matter between the two weighings ...
makes sense, I suppose I was trying to think too much about the question tricking me. Thank you for the help.
