Weight Density and Mass Density
The discussion centers on the calculation of weight density and mass density for various objects, utilizing the formulas Weight Density = weight/volume and Mass Density = mass/volume. The user confirmed that weight density is measured in Newtons per cubic meter (N/m³) and mass density in kilograms per cubic meter (kg/m³). The calculations provided indicate a weight density of approximately 78431 N/m³ and a mass density of 8000 kg/m³ for a stainless steel object. Participants emphasized the importance of verifying calculations and considering significant digits in results.
  • Understanding of basic physics concepts, specifically weight and mass
  • Familiarity with density calculations
  • Knowledge of units of measurement in the International System of Units (SI)
  • Basic proficiency in using calculators for scientific calculations
  • Research the properties of stainless steel and its typical density values
  • Learn about significant figures and their importance in scientific calculations
  • Explore the differences between weight and mass in physics
  • Investigate the effects of gravitational acceleration on weight calculations
Students studying physics, educators teaching density concepts, and anyone involved in material science or engineering applications related to weight and mass measurements.
GreenEyedGal3
I measured the weight(in Newtons), mass(in Kilograms), and volume(in cubic meters) of some objects. Then I tried to calculate the mass density and the weight density of the objects.
ex. weight density of object one ... 2.00 N / 2.55x10-5 m3 = 78431 ??
mass density of object one ... .204kg / 2.55x10-5 m3 = 8000 ??
I have found my numeric answers but i do not know what units the weight density and mass density are measured in. Would the weight density be measured in Newtons/ cubic meters and the mass density in kg/ cubic meters?
Yes, those would be the unit's to use. However, you may want to re-check your calculations.
I keep getting the same thing on my calculations. Should i round to the right number of significant digits or should i change my calculator from degrees to radians?
The calculations look fine. Are you hinting about the numbers? It looks to me like the OP was using stainless steel.
What makes you think that this will make any difference?
I was referring to the disparity between the weight of the object and the given mass multiplied by g:
(0.204*9.81)/(2.55*10-5) = 78480
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 18 ·
