Weight of water from molecular mass to grams per cubic centimeter
The density of water is approximately one gram per cubic centimeter at 1 atm pressure and 4 degrees Celsius due to its molecular mass of 18.015 g/mol. The discussion highlights a misapplication of the ideal gas law to a liquid, resulting in an incorrect density calculation of 792.56 grams per cubic meter instead of the expected one gram per cubic centimeter. The error was attributed to neglecting the cohesive properties of water molecules and a transcription mistake involving a factor of 10^6. Understanding these principles clarifies why liquid water's density deviates from ideal gas predictions.
  • Understanding of molecular mass and density concepts
  • Familiarity with the ideal gas law and its applications
  • Knowledge of the properties of liquids versus gases
  • Basic proficiency in unit conversions (e.g., grams per cubic meter to grams per cubic centimeter)
  • Study the properties of liquids and how they differ from gases
  • Learn about the cohesive forces in water and their impact on density
  • Explore the implications of the ideal gas law in various states of matter
  • Investigate common transcription errors in scientific calculations
Students in chemistry, physicists, and anyone interested in understanding the physical properties of water and the principles of density calculations.
engine123
I’ve been scratching my head (and working in ms excel) about the following for about 6 hours and would greatly appreciate it if somebody could help me.
Basically, I am trying to figure out WHY the density of water is approximately one gram per cubic centimeter (at 1 atm pressure and 4 degrees Celsius).
Note the following conversions:
1 atm = 101,325.01 Pa = 14.7 psi
4 C = 39.2 F = 277 K
Also:
Gas Law Constant = 8.3145
Starting at the molecular level, water has a molecular mass of 18.015 g/mol.
Using the ideal gas law:
density = (pressure) (molar mass) / ((temp) (8.3145))
g/m^3 = (Pa) (g/mol) / ((K) (8.3145))
This is what I come up with:
density = (101,325 Pa) (18.015 g/mol) / ((277 K) (8.3145))
density = 792.56 grams per cubic meter
792.56 grams per cubic cm does NOT equal 1 gram per cubic centimeter.
Why?
Where did I go wrong?
Any guidance is greatly appreciated.
Why did you apply the ideal gas law for a liquid?
Why?
As Vanadium 50 has pointed out, liquid water is not an ideal gas. The density of liquid water is [much] higher than Boyle's law would predict. The molecules of water stick together and thus exert less pressure on their surroundings than would otherwise be the case.
You also dropped a factor of 10^6, in what appears to be a transcription error. 792.56 grams per cubic cm is incorrect. 792.56 grams per cubic meter is right for an ideal gas with a molecular weight of 18.
I sanity-checked your computation by taking 1200 grams per cubic meter (density of air, according to Google) and multiplying by 18/28 (air is mostly nitrogen with a molecular weight of 28). That comes to 771 grams per cubic meter -- close enough for back-of-the-envelope work.
  • · Replies 24 ·
  • · Replies 24 ·
  • · Replies 26 ·
