What are Lorentz Factors? | Definition & Explanation
  • Context: High School
  • Thread starter Thread starter Fuinne
    Factors Lorentz
The Lorentz factor, denoted as ##\gamma##, is defined as the ratio between the clock rates of an observer at rest in an inertial frame and an observer moving at constant speed. It is mathematically expressed as ##1/\sqrt{1-\frac{v^2}{c^2}}##, where 'v' is the velocity of the moving observer and 'c' is the speed of light. The discussion emphasizes the importance of distinguishing between Ludwig Lorenz and Hendrik Lorentz, as well as the relevance of the Lorentz factor in special relativity, particularly in relation to the concepts of time dilation and length contraction.
  • Understanding of special relativity principles
  • Familiarity with the speed of light (c)
  • Basic knowledge of trigonometric functions and their applications
  • Ability to interpret mathematical expressions involving square roots and ratios
  • Research the derivation of the Lorentz transforms using Pythagoras' Theorem
  • Study the implications of time dilation and length contraction in special relativity
  • Explore the concept of the "light clock" as a practical illustration of the Lorentz factor
  • Examine the historical contributions of Hendrik Lorentz to physics
Students of physics, educators teaching special relativity, and anyone interested in the mathematical foundations of relativistic effects.
Fuinne
Hi, I was wondering what Lorenz Factors are. Can someone give me a simple definition?
The ratio between the clock rates of an observer at rest in an inertial frame and an observer moving at constant speed. Also the ratio of ruler lengths, if the rulers are pointing in the direction of motion.
Here is the Euclidean analogue: cos(theta).
Given two unit vectors, cos(theta) is the dot product of those two vectors. What it means is that, generally you don't get all of a vector pointing along one of your coordinate axes... You get components... And they involve that cosine factor. In special relativity, that is the hyperbolic cosine... which is often called ##\gamma## (and hyperbolic sine is ##\beta\gamma##).
"Lorentz" not "Lorenz"... Not all spelling mistakes matter but this one does because Ludwig Lorenz and Hendrik Lorentz are different people.
You'll often see the Lorentz factor represented with the symbol ##\gamma##, a convenient shorthand for the longer ##1/\sqrt{1-\frac{v^2}{c^2}}##.
The wikipedia article is worth reading if you haven't https://en.wikipedia.org/wiki/Lorentz_factor
Also, Google for "light clock". You can derive the Lorentz transforms (including the Lorentz factor, ##\gamma##) with no maths beyond Pythagoras' Theorem.
I spent the summer after high school trying to figure that out from scratch. I finally got it, but doing the whole thing with just a generic linear transformation (x = ax' + bt', t = ft' + gx') a year later was much more satisfying.
There was also Edward Lorenz, a mathematician and meteorologist, famous for his pioneering contributions to chaos theory.
  • · Replies 18 ·
  • · Replies 72 ·
  • · Replies 23 ·
  • · Replies 31 ·
