What are the Corresponding Reaction Forces in a Suspended Bowling Ball System?
The discussion centers on the reaction forces in a suspended bowling ball system, specifically analyzing the forces exerted by the rope and the bowling ball. The tension force exerted by the rope on the bowling ball is 65 N, acting upwards. According to Newton's Third Law of Motion, the bowling ball exerts an equal and opposite force of 65 N downwards on the rope. The forces are exerted between the bowling ball and the rope, with the rope pulling the ball upwards and the ball pulling the rope downwards.
  • Understanding of Newton's Third Law of Motion
  • Basic knowledge of force and tension concepts
  • Familiarity with vector direction in physics
  • Ability to analyze static equilibrium systems
  • Study the implications of Newton's Third Law in different physical systems
  • Explore static equilibrium conditions in mechanics
  • Learn about tension forces in various applications, such as pulleys
  • Investigate the role of forces in dynamic systems and motion
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of forces and motion in static systems.
physicsnobrain
A bowling ball is suspended from a ceiling hook using a thin piece of rope. If the rope is
exerting a 65 N force upward on the ball, describe the corresponding reaction force in
terms of:
(a) its magnitude
(b) its direction
(c) on what object it is exerted
(d) by which object it is exerted
A) The magnitude corresponds to the force of tension in the rope, and the ball isn't moving anywhere.
B) direction corresponds to the force of gravity because this is where the ball will go if it is released from the rope.
C) Force is exerted on the rope
D) Force is exerted by bowling ball because of F = ma
Am I right?
thanks
Or is A) the normal force
Or it is
A) The magnitude is upwards to the cieling hook
B) The direction of the bowling ball is south
C) The force is exerted onto the hook
D) The force is exerted by the bowling ball
physicsnobrain said:
Or it is
D) is certainly correct.
I'm not quite sure that C) is right. It's true the hook feels a force, but the rope is what pulls down on the hook. What pulls on the rope? (Hint: reaction forces occur between two objects only. So if object X exerts a force on Y, the reaction force must be exerted by Y onto X)
For B), I would simply say down because the problem doesn't mention north, south, east, or west. You certainly have the right idea, though. Why is it that the answer to B) is down, though? Can you perhaps think of a physical law that might explain why that's true?
And as for A), magnitude refers to a number. So, for instance, the magnitude of the force the rope is exerting on the ball is 65 N. So, do you know what the magnitude of the force the rope is exerting on the ball is?
I think that that C and D are now:
C) The force is exerted onto the bowling ball
D) The force is exerted by the rope
You said the magnitude of the force the rope is exerting on the ball is 65N, then you asked what is the magnitude of the force the rope is exerting on the ball.
What?
What?
You're right, I'm sorry, that was a typo. You know the magnitude of the force the rope exerts on the ball is 65 N. What is the magnitude of the force the ball exerts on the rope?
also 65N
also 65N
Exactly! That comes from Newton's Third Law of Motion, which says that the force that X exerts on Y is equal and magnitude and opposite in direction of the force Y exerts on X. So that's A), now what about B)?
The direction is then upwards, in the same direction as the tension force.
Not quite. The reaction force is equal in magnitude, but opposite in direction. So if the rope (the tension force) is pulling the ball up, then the ball should be pulling the rope in which direction?
downward
And C is the force is exerted onto the bowling ball
and D it is exerted by the rope
  • · Replies 33 ·
