What Are the Final Velocities After an Elastic Collision Between Two Particles?
The discussion centers on calculating the final velocities of two particles after an elastic collision, where particle 1 has a mass of 2m and an initial velocity v, while particle 2 has a mass of m and is initially stationary. The conservation of momentum and energy equations are established, leading to a quadratic equation for v1: 3v1^2 - 4vv1 + v^2 = 0. The solution for v1 is derived as (1/3)v, with v2 subsequently calculated using the momentum equation. Participants emphasize the importance of correctly applying the quadratic formula and factoring techniques to solve for the final velocities.
  • Understanding of elastic collisions in physics
  • Familiarity with conservation of momentum and energy principles
  • Knowledge of quadratic equations and their solutions
  • Basic algebraic manipulation skills
  • Study the derivation of elastic collision equations in detail
  • Learn how to apply the quadratic formula effectively
  • Explore examples of one-dimensional elastic collisions
  • Investigate the impact of varying masses on collision outcomes
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of elastic collisions and their mathematical representations.
ph123
Let two particles collide. Particle 1 has initial velocity v, directed to the right, and particle 2 is initially stationary. Now assume that the mass of particle 1 is 2m, while the mass of particle 2 remains m. If the collision is elastic, what are the final velocities v1 and v2 of particles 1 and 2?
Express answer in terms of the initial velocity, v.
My conservation of energy equation for the two particles is (I already canceled out the masses):
v1^1 + 0.5v2^2 = v^2
My conservation of momentum equation is (masses already cancelled):
2v1 + v2 = 2v
Thus,
v2 = 2v-2v1
v1 = (2v-v2)/2
I tried plugging these values for v1 and v2 into the conservation of energy formula to try and isolate v for each variable. For v1, I ran into difficulty because of the middle term of the binomial equation, -8vv1.
v1^2 + 0.5[(2v-2v1)(2v-2v1)] = v^2
v1^2 + 0.5[4v^2 - 8vv1 + 4v1^2] = v^2
-v^2 = v1^2 - 4vv1 + 2v1^2
3v1^2 - 4vv1 = -v^2
From here I spent like 10 lines trying to rearrange terms to separate v from that middle term (now -4vv1), but am unable to do so. Any ideas? Thanks!
Recognize that you have a quadratic equation for v1. Solve it!
Well, there are two different terms in the quadratic. How can you solve for two terms?
Actually, there are three terms if you put it into standard form:
ax^2 + bx + c = 0
Can you solve that for x? If so, you can solve for v1 in terms of v.
You lost me. I assume you mean:
[-b +/- sqrt(b^2 - 4ac)]/2a = v1
[4v +/- sqrt([-4v]^2 - 4(3v)(v^2))]/2(3v)
[4v +/- sqrt(16v^2 - 12v^3)]/6v
But now I'm left with
(2/3)v +/- [sqrt(16v^2 - 12v^3)/6v]
I can't combine terms in the square root because they have different exponents, so this doesn't seem like it makes much sense.
Those "v"s in red shouldn't be there. There is no v in the coefficient of your "a" term. Fix that up and it will be much easier to work with.
By the way, you don't necessarily have to use the quadratic equation. You could just factor it.
Are you certain that all the information is given? Because the way I see it, you have three variables (v, v1, v2) and only two equations (conservation of momentum and conservation of KE).
two unknowns right? since the question asks for Vf's in terms of Vi.
all the info is given. i derived v1 and v2 from conservation of momentum. i have to do each individually, so really there are only two unknowns with two equations.
i see what you mean, hage, about the extra v's i put in. ill try that.
that works. i got (1/3)v = v1. Thanks everyone for all of your help
  • · Replies 16 ·
