What are the forces acting on a hinge?
  • Thread starter Thread starter drkidd22
    Forces Hinge
18 replies · 12K views
drkidd22
In the figure below, the bar is 3.4 meters long and has a mass of 100 kg.
what is the magnitude of the hinge force?
cosβ=2/sqrt(2^2+3.4^2)
cosβ=0.51
0.51T=mg/2
T= 100*9.8/(2*0.51)=960.8
I'm not 100% sure if I did this right.
Any assistance will be appreciated.
cosβ=0.51
0.51T=mg/2
Looks like you took a short cut (not a good idea) to correctly solve for T, the cable tension force. But the problem wants the hinge force; try Newton 1 to solve for the x and y components of the force at the hinge.
cosβ=0.51
0.51T=mg/2
I think you got the tension right. Draw a free body diagram of the beam, label all the forces on the bar. The hinge applies a force on the beam in the x and y directions.
well yeah, you are both right, but that's were I'm stuck.
The beam has three forces acting on it. The tension force of the wire, the weight force of the beam and the force of the hinge which can be thought of as a sum of two forces, a force acting in the vertical direction on the beam and a force acting to the right on the beam.
drkidd22 said:
so Fhx=Tsinβ= 489.95N?
Draw a picture roughly to scale. Fhx is considerably more then half T.
More like T*sin(60degrees)
I'm completely lost. I give up. Will try again tomorrow
PhanthomJay said:
If cos B =0.51, then sin B =?
= 59.34 degrees
sinB = 0.86
drkidd22 said:
= 59.34 degrees
sinB = 0.86
Yes, that is correct. So if Fhx = T sinB, as you correctly noted, then Fhx =? Now you still need to calculate Fhy.
Fhx = 826.3N
drkidd22 said:
Fhx = 826.3N
Yes, in which direction? And Fhy =??, and in which direction?? Once you get both components of the hinge force, the magnitude of the resultant hinge force is what the problem is asking.
I think there is something wrong with the Tension. I still don't think I got it right.
Except for some round off/sig figure errors, why do you think the tension is wrong? Your initial calculation for it is correct, although I question how you arrived at that formula.
Well I think there is something wrong with the tension I found because I'm working on a similar problem with just a different length for the Bar and I use the same formula the results is not right. I get 1485N as the wire tension, but the book says the tension is 1095.
Don't believe everything you read, your answer is correct. But you should be summing moments and forces = 0 to calculate these values, do not blindly use formulas.
Are you familiar with the 3 basic equations of equilibrium (for objects at rest) which comes from Newton's 1st law:
Sum of all forces acting in the x direction = 0
Sum of all forces acting in the y direction = 0
Sum of all moments (torques) of forces about any point =0?
Break up the unknown force F (let's call it P instead of F, to avoid confusion of letter designations) into 2 components, P_x and P_y, where P_x = P cos30 and P_y = P sin30 (don't forget the direction of those force components). Now sum moments about the hinge end to solve for P_y; note that there is no moment from P_x, or from the wall forces, when you choose the hinge as your point of reference for determining moments. So for moments, you have the moment from P_y and the moment from the board weight (the board weight force acts at the center of the board). Add them up, set them equal to zero, and solve for P_y. Then you can get P_x and P from trig.
