Terilien
- 140
- 0
i was curious as to what exactly this is and more importantly, what motivates it. what are its applications?
Well, as its name suggests, it's a derivative. Directional derivatives were very useful in calculus, weren't they? So you can surely appreciate that a notion of directional derivative would be useful when doing calculus on a manifold.Terilien said:i was curious as to what exactly this is and more importantly, what motivates it. what are its applications?
ObsessiveMathsFreak said:I should have clarified that the Lie derivative is a second derivative of "functions" on the manifold, not of vectors. It is a first derivate of vector fields, which are themselves first derivatives of functions.
garrett said:
If vectors are considered to be derivatives, then surely the derivative of a vector is in some sense a second derivative. It's construction is such that it lies in the tangent plane, and therefore is itself "only" a first derivative. But you did have to take a second derivative to get it, so it is in some sense a degenerate second derivative.Chris Hillman said:OMF, this is still misleading IMO. By definition, the Lie derivative takes a vector fields to a new vector field. A vector field takes a function to a new function. Levels of structure are well explained in textbooks like Boothby or Lee, and should not be confused.
The maintainer of that site is undergoing an attempt to fix differential geometry notation, which is admittedly broken. Wish him well.explain said:nice site design - but extremely complicated notation...
ObsessiveMathsFreak said:As my appeal to authority for the day, In Mathematical Methods of Classical Physics, Arnold originally constructs the Lie Derivative as the second order ,mixed, partial derivative of a function on the manifold. He does later point out that it is a first order operator though, and goes on from this to point out that because of this Lie differentiation as an operator turns vector fields into a group. But what use all this is, I'm not sure.
The fact that the second derivative terms canceled out in the Lie derivative did not escape me. Nevertheless, the fact remains that second derivatives were taken in order to compute it. The higher derivatives canceled to leave only first order terms, which was the whole point of the operation, but nonetheless the derivative can be regarded as one of second order, albiet a degenerate case. If your functions are once but not twice differentiable, you will not be able to obtain the Lie derivative, despite being able to obtain the vector derivative.Chris Hillman said:That's because you entirely missed the point of what Arnold was trying to tell you, which is the same thing I am trying to tell you: yes, prima facie you'd expect [A, \, B] to give a second order operator, which would prevent it from being a vector field, since vector fields are first order linear homogeneous operators.
Huh? The Lie derivative of a scalar field exists for any once-differentiable function. The Lie derivative of a tangent vector field doesn't involve scalar fields at all. So just what do you mean?ObsessiveMathsFreak said:If your functions are once but not twice differentiable, you will not be able to obtain the Lie derivative, despite being able to obtain the vector derivative.
It's a directional derivative. You think directional derivatives are pointless? And what is this "opaqueness" of which you speak? And why is it a bad thing, as you seem to imply?If the Lie derivative is simply just another first order vector field, there seems to be little point to it beyond the usual opaqueness.
That's not my understanding from the derivation. As derived aboveHurkyl said:Huh? The Lie derivative of a scalar field exists for any once-differentiable function. The Lie derivative of a tangent vector field doesn't involve scalar fields at all. So just what do you mean?
The second derivatives ordinarily cancel. But if the second derivative does not exist, then there is no defined way to cancel the terms. For example letChris Hillman said:[A, \, B] \, f = A \, B \, f - B \, A \, f = a \, \partial_x \left( b \, f_x \right) - b \, \partial_x <br /> \left(a \, f_x \right)
<br /> \hspace{2cm} <br /> = a \, b_x \, f_x + a \, b \, f_{xx} - b \, a_x \, f_x - a \, b \, f_{xx} <br /> = \left( a \, b_x - b \, a_x \right) f_x<br />
Introducing news ones would be if they are serving no purpose. To be honest I've never come across a differential geometry text that actually uses the Lie derivative as anything other than notational compression, so I'm not sure exactly what use it is in practice. As to the opaqueness, I'm referring to the usual listing of properties, Jacobi identity,etc , which while interesting to know, offer no insight into what this derivative actually does, or what it is used for, which is probably why the original question was asked in the first place.Hurkyl said:It's a directional derivative. You think directional derivatives are pointless? And what is this "opaqueness" of which you speak? And why is it a bad thing, as you seem to imply?
ObsessiveMathsFreak said:...To be honest I've never come across a differential geometry text that actually uses the Lie derivative as anything other than notational compression, so I'm not sure exactly what use it is in practice...
ObsessiveMathsFreak said:If the Lie derivative is simply just another first order vector field, there seems to be little point to it beyond the usual opaqueness. I looked at it as a the "best worst choice" for an intrinsic second derivative, because it seemed to serve little other function besides notational convienience. This may be a matter of complete pedantics, but it makes sense to me to regard it as such.
explain said:...A vector field on a manifold generates a flow (a diffeomorphism) ...
Doodle Bob said:Careful: a flow is a path of local diffeomorphisms.
mathwonk said:so if the vector field is zero at p, it does not mean the flow is contant at p?
mathwonk said:explain seems to be arguing that even though the flow fixes the origin that it does not induce the identity on the tangent space there.
mathwonk said:explain, this is one of the few times in all the years i have been posting here that i have learned something on a somewhat advanced topic in geometry from a new poster, who clearly understands it better than I do. your post has the authority of someone who understands what he is doing.
you not only are correct in your assertions, but they are elementary and intuitive. moreover you have no axe to grind. welcome to the forum. i think you have a lot to offer.
if you are not yet a mathematician, you can be. indeed you seem to be one
already. if not let me explicitly encourage you.
mathwonk said:anyway i think when a physicist takes it upon himself to understand math concepts he has an advantage because of knowing how they are used and where they arose oftentimes.
also I am a pure mathematician, so to me it was not always acceptable to assume a drop of water is a geometric point, or that the wind moves along a smoothly differentiable curve. to me physics deals with discrete concepts, and it takes a certain knack to reason correctly from erroneous premises!
Try this thread: https://www.physicsforums.com/showthread.php?t=150200Terilien said:i was curious as to what exactly this is and more importantly, what motivates it. what are its applications?
