What are the principles on which astrology rests?
  • Thread starter Thread starter quantumdude
The discussion centers on the foundational principles of astrology, which are based on the belief that the same forces that govern planetary movements also influence human behavior. Participants assert that astrology serves as a tool to interpret individual strengths, weaknesses, and tendencies through the analysis of planetary aspects. However, the conversation highlights the lack of scientific validation for astrology, with claims being largely anecdotal and subjective. The consensus is that while astrology is not a science, it is viewed by some as a reflective tool for self-awareness.
  • Understanding of astrological terminology, such as "natal chart" and "planetary aspects."
  • Familiarity with the concept of gravitational influence in astronomy.
  • Knowledge of the historical context of astrology and its separation from astronomy.
  • Awareness of the principles of scientific methodology and pseudoscience.
  • Research the historical relationship between astrology and astronomy, particularly during the Renaissance.
  • Explore the psychological effects of astrology on individuals, including the concept of "auto-pilot syndrome."
  • Investigate the methodologies used in astrology, including the calculation of natal charts using birth data.
  • Examine the criticisms of astrology as a pseudoscience and the criteria for scientific validity.
Individuals interested in astrology, psychology enthusiasts, historians of science, and anyone examining the intersection of belief systems and scientific inquiry.
  • #31
FZ...i am unsure of what you want me to do? taking this data and interpreting it is a time consuming process, this last chart took me an hour...i can give a very brief outline if you like..
You see, the problem with tendencies is that it requires bias and opinion to determine them.
exactly, as you stated:
It instead shows the vulnerability of the human psychology
i am not claiming it is science, but it is a study of cycles, human cycles within the rotations of the celestial bodies...
  • #32
Not really. Pretty much all of medicine and psychology are based on "tendancies." The way you deal with that scientifically is through statistical analysis.
There are very different ways of thinking associated with different sciences. I like engineering because it is very "real." A steel cable can support x amount of weight. Put much more on it and it will break. Direct cause and effect. Medicine isn't anywhere near as simple. Thats why to test a drug you need a sample of a thousand cases. Then you analyze statistical probabilities of things like side effects.
Astrology *CAN* be approched in the same way. But it isn't and won't ever be. The reason is that by being vague or describing common human traits (anyone ever meet a person who is NOT curious?) you can achieve a very high degree of accuracy without actually saying anything. The test for this is quite simple. Using the technique chroot did, you rate the accuracy of the readings. Then you randomize the readings and do it again. Then compare.
  • #33
A brief outline would do.
  • #34
Originally posted by Zefram
Maybe this is the wrong place (or time) to ask this but when someone says "I believe in astrology" what exactly are they professing a belief in? That semi-accurate charts describing personality traits can be drawn up based on birth date or location? That the stars or planets or both account for this? Or something else?
the correct term would be to "understand astrology"...i see it as understanding personality traits another invidual may tend to..
  • #35
zefram, i am afraid you are asking me to "scientize" astrology...stronger tendencies to do such-and-such over another individual due to the reflection of aspects of planet xyz to abc...does that clarify?
  • #36
I do not personally ascribe much credence to astrology (at this time), but I will say this; so far in this topic, much has been made of the fact that astrological data is based on "tendencies" and "will always have verying degrees of uncertainty". Am I the only one who finds these descriptions rather familliar-sounding? Is QM psuedoscience? Or is statistical analysis to be discarded as having no validity?
If these are the chief reasons for which astrology is rejected as a science, then that rejection is invalid. Kerrie has stated that this is not a science, but surely there must be better reasons than these for that conclusion.
  • #37
interesting perspective Lurch...for the years i have studied astrology, i have analyzed it, just like scientists would in certain studies...
i say it is not a science because it is not exact like science is, free will of the human being is what makes it not exact and reliabel:wink:
  • #38
Kerrie
Perhaps I don’t quite understand your inference to free will. Are you saying scientists have no free will when they conduct experiments and postulate theories?
BTW – did you get a chance to finish my chart?
  • #39
Originally posted by (Q)
Kerrie
I'm not normally one to speak for others, but I'm fairly confident I see the point of missunderstanding in this case. I think the distinction being made here is that when scientists conduct experiments, the subject which they are observing has no free will.
Even with the HUP, the path of an electron is more predictable than the path a person will take in their personal developement. An electron cannot look at where it is going and "decide" that this is not the way it wishes to go. But predicting the course a person's maturation process will take, or the traits and tendencies they will have is more difficult because the person may become aware that they have these traits or tendencies, and choose to change them.
  • #40
thank you lurch...human free will is not predictable, therefore can be be deemed as "unreliable" for studying it scientifically...
  • #41
great question, after doing some research, i found these words from a well known astrologist, Kevin Burke:
Astrology operates on the Ketheric level of existence, the level of a spritual blueprint.
So, I would say no, astrology does not have an impact on weather, but the spirituality of those with free will.
  • #42
Astrology works!
It is only a question of context. But astrology accurately
predicts:
- the adequate timings for fishing according to sea levels.
- the adequate timings for farming activities.
In some places, it also predicts acurately weather-related
events, such as for instance the rising of the Nile river.
My guesses: the invention of calendars pushed astrology to a secondary role. The accumulated corputs grew out of context trying to do predictions unrelated to their primary goals. It could happen catastrophically or gradually. For instance, trying to predict dayly weather for state activities, battles, demostrations, etc... and then even evolving to try to predict individual events. Or it could be a case for an stablished sicence expanding to illetered hands, as happens with pseudoscience nowadays.
Aside: Liver omen works! It is explained in Vitrubio books. Check it.
  • #43
okay, to be objective in my assertion of the validity of astrology, can you provide links or any kind of other reference to show proof that astrology has an impact on fishing and farming? this is news to me as an avid student for 12 years...
  • #44
I presume he means the "moon sign books" used by some farmers and fisherment. But to assert "accuracy" he should be able to site specific controlled experiments showing them to be accurate. For example give fake moon sign books - with different numbers - to a random sample of fishermen, and the regular books to another random sample of the same size. Then see of there was any statistically meaningful difference between the fishing success (defined by some objective criterion) of the two groups.
I'll bet he can't do that. It's just the usual phony spin.
  • #45
I almost forgot!
Tom, in your initial post in this topic, you asked about the reasons for astrology being dismissed as "pseudoscience". The main reason that I have heard relates to the zodiac. For example, I am an Aries. This means that, back when the Egyptians (?) Charted the first zodiac calendar, the sun rose into the constellation Aries on the day that I was born.
Due to gyroscopic precession, and the Earth's "wobble" by axis, the sun no longer rises into that same constellation on that day. In fact, all of the zodiacal signs are off by approximately one month. Many astrologers claim that, in spite of this fact, astrological predictions made for an Aries back then would still apply to me, today. Their reasoning for this is that the sun is still rising into "the same area of space", even though the constellation Aries has moved. This presupposes some supernatural or intangible quality of space that can somehow make location absolute, in spite of the motions of the natural, physical objects in the universe.
This, however, sounds like a very different kind of astrology from that which Kerrie describes.
  • #46
exactly so lurch, IF you use the actual constellations (only needed for rising signs:wink: ...it is the Earth's ecliptic (360 degreee circumference divided by 12 suns) that are what are referred to as "sun signs"...
there are actually 13 constellations in the zodiac ban, one is between scorpio and sagittarius called ophiuchus...but because astrologists do not base the "signs" on the actual zodiac ban in the sky, it doesn't apply...
  • #47
Interesting. Does the facr that our position in the Galaxy has altered over 2,000 years also have bearing. That is, the shapes of the constellations have altered subtly in 2,000+ years. what affect does this have in say, 10,000 years when the constellations have altered a lot. Plus due to precession the zodiacal constellations will have altered again.
  • #48
Originally posted by Tom
This stems from the threadThe purpose of pseudoscience. Astrology was referred to as being dismisses as pseudoscience. Is it unscientific? Or is it just getting a bad rep from its identification with the daily paper horoscopes?
I have no idea, as I have never looked into the matter. So let me ask:
1. What are the foundational principles on which astrology rests?
In other words, what are its axioms?
2. What are the claims of astrology? In other words, what does one mean when one says that "astrology works"?
3. How is #2 deduced from #3? Or are the axioms identical to the claims?
Thanks,
I see astrology as explainable by way of the mechanics noted in Chaos theory.
You know... like when a bird is startled and beats its wings in Kuala Lumpur there is a hurrican in Jamaca. That kind of synergistic progression. Only in this case, its a planet(s) and its relation to a constellation and the Earth and a person on the Earth and the positioning of these and other factors.
If astrology is considered a psuedoscience then I would imagine that psychology could be considered as being one as well... since there are as many correlations and confirmations calculated in astrology, if not more, as there are found in psychology... yet neither is considered (by some) a proven, exact science.
  • #49
Important information to break a common myth of astrology!
Originally posted by LURCH
I almost forgot!
constellations do not matter with sun signs...it is the Earth's ecliptic-this is the plane of the sun's apparent orbit around the sun...the equator is tilted approximately 23.5 degrees to the ecliptic and astrologists measure the relative positions of the planets based on where they appear along this ecliptic...
so you see, as i stated previously, the constellations have nothing to do with interpretation, but it is the earth's relation to our planets, sun moon, (and some planetoids) that is interpreted...this is the most subjective part of astrology-interpretation of these aspects on human psychology...
one thing all skeptics should know as a fact is when planet such-and-such is conjunct/trine/in opposition to planet so-and-so, this is factual information...it is clearly objective the positions of the planets in relation to our earth...so i can say that astrology is based on facts:wink:
  • #50
Ok, ok, let me to clarify: there are an evident impact, from the positions of Sun and Moon. It is just that modernly this impact is fully understood, thus it is labeled astronomy. So it is not rare for you to miss it. The position of Sun against the fixed stars tell us of the year station, the relative position of Sun and Moon tell us of tides.
Secondly there is a minor impact from the visibility of known stars. It relates to weather prediction, as it informs of the humidity conditions in the atmosphere. Note that this prediction is not only important to farming, but also to other activities, for instance to decide if engaging or not in a battle.
Thirdly it comes a pseudoscience degenerating from all the previous, it still perdures as "farming calendars", and surely it is the origin of astrology as pseudoscience, before to be applyed to persons.
  • #51
I am sure of that, but the problem is that a good "moon sign book" actually takes real facts into account, as for instance to consider the rain fallen in an area during winter or the quantity of snow accumulated. This mix of science and pseudoscience is a most difficoultous thing to debunk.
  • #52
Oh and for those wanting references for the study and other critiques go here:
http://www.astrosociety.org/education/resources/pseudobib.html#1 [/B]
wanted to bump this up again...i checked this link, and again, another astronomer misinformed...the article claims that the planets affect us, when astrologists do not make that claim whatsoever...
also, the article claims that the sun passes through the constellations and this is a part of astrology-not so, it is the Earth's ecliptic passing through 12 houses and the position of the planets in relation to this 12 sections that is analyzed...
this information provided by astronomers who haven't taken the time to truly understand astrology dooms it automatically...
  • · Replies 19 ·
  • · Replies 75 ·
9K
  • · Replies 84 ·
