What Are the Probabilities of Getting Specific Hands from a Deck of Cards?
  • Thread starter Thread starter Pizzerer
    Cards Probability
The discussion revolves around calculating probabilities related to card hands drawn from a standard deck. The original poster presents multiple questions regarding the likelihood of specific outcomes, such as the probability of having at least two cards of the same rank, the probability of drawing a royal flush in a five-card hand, and the probability of a royal flush in a seven-card hand.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore various methods for calculating probabilities, including complementary counting and direct probability calculations. Some question the assumptions made in the original poster's approach, particularly regarding the uniqueness of card ranks in the first problem.
There are multiple interpretations of the problems being discussed, with some participants providing alternative calculations and methods. Guidance has been offered regarding the use of probability trees and the need for clarity in the assumptions of the problems. The conversation reflects a mix of attempts to clarify misunderstandings and to explore different probability strategies.
Participants note the importance of specifying conditions such as whether cards are distinct or if suits are to be considered. There is also mention of the potential confusion arising from the use of combinations in certain calculations.
Pizzerer
I'm not very good at probability and I'm just having trouble interpreting and calculating what the questions actually want me to do. Could someone please help to explain this simply?
1.Five cards are dealt at random from a standard pack. Ignoring suit, what is the probability that at least two of them are the same?
For this question I thought it was 1 - 13c5/52c5 = answer, but I'm not sure.
2. In a poker hand consisting of five cards dealt at random, what is the probability of a royal flush (Ten, Jack, Queen, King and Ace of the same suit)?
No idea how to incorporate the different picture cards into this calculation.
3. In a variant of poker each player has seven cards. What is the probability
of a royal flush in this case?
I thought here it would just be 52c7 instead of 52c5 for all the possible samples, but I don't know where to go from there.
I would really appreciate any help that can be given.
For 1. I get 1 - (48/51)(45/50)(42/49)(39/48)
For 2. I get (20/52)(4/51)(3/50)(2/49)(1/48)
3. requires more work.
Could you explain to me how you got those figures?
For 1, I would have gotten something different. The logic is: find the probability that all 5 cards are different. Well, after drawing the first card, the second must be different from it, and there are 48 cards that are different, in a remaining deck of 51 cards. The third card must be different from the first two, and there are 44 such in a deck of 50. The fourth must be different from the first three, and there are 40 such in a deck of 49, etc.
RGV
Hey Pizzerer and welcome to the forums.
Are you familiar with probability trees?
The basic idea is to use different branches to represent events. You can represent each layer of the tree as an independent event and then to find the probability of all the events you multiply each element from the root to some leaf event and that becomes your probability.
This method is a common one that is used and will help you build up intuition for probability.
problem 1.
you need to specify that all card are different and singular. i.e (13c1 * 4c1) (12c1 * 4c1) ... denominator is good and so is (1 - .. )
problem 2.
choose a suit (4c1), now you need 5 specific cards. (13c1)*(12c1)*(11c1)*(10c1)*(9c1).. denominator is still (52c5). should get a really small probability.
problem 3.
like problem 2, except in the numerator you should include a (47c2) => choose any 2 cards beyond the 5 needed (47 left), and denominator should be (52c7).
hope this helps
byrnesj1 said:
problem 1.
problem 2.
problem 3.
hope this helps
Nope! Your computation for P{all different} in (1) is (13*4 * 12*4 * 11*4 * 10*4)/C(52,5) = 1408/833 > 1!
Basically, in this problem, combinations have nothing to offer and just confuse the issue.
For (2): your answer is wrong. You get P = 4*13*12*11*10*9/C(52,5) = 198/833 ≈ 0.2377. However, the exact answer is obtained: For a Royal Flush of Spades, what is the probability? We have 5 'good' cards (the Royal Flush Spade cards) and 52-5 = 47 "bad' cards. We want to draw 5 good cards. So, P{RFSpades} = 5/52*4/51*3/50*2/49*1/48 = 1/2,598,960, and P{RF} = 4*P{RFSpades} = 4/2,598,960 = 1/649,740 ≈ 0.1539e-05. Note: we could have gotten this from the Hypergeometric distribution: P{RFSpades} = P{draw 5 good cards and 0 bad cards from a deck having 5 good and 47 bad cards} = C(5,5)C(47,0)/C(52,5) = 1/C(52,5) = 1/2,598,960.
For (3): P{RFSpades} = P{draw 5 good and 2 bad cards from a deck of 5 good and 47 bad} = C(5,5)*C(47,2)/C(52,5).
Then P{RF} = 4*C(5,5)*C(47,2)/C(52,7) = 1/30940 ≈ 0.3232e-04.
RGV
  • · Replies 32 ·
