What Causes Eddy Currents in a Copper Tube?
  • Context: Undergrad
  • Thread starter Thread starter clark84
    Electromagnetic
6 replies · 2K views
clark84
What are the three forces responsible for a neodymium magnet to fall slowly down through a heavy copper tube?
Welcome to PF;
That's a good question - what have you come up with so far?
i.e. have you listed the forces that are available to the universe? There are only four - but I feel the question may be treating one of them as two.
Hi clark
its a good experiment, as Simon has said, have a think about what is happening
A hint ... a moving magnetic field and a conductor :wink:
also it could be any magnet and it works just as well with an aluminium tube
I use this action to produce dampening in a seismometer ( earthquake detector)
but rather than an aluminium tube, I use a moving strip of aluminium between 2 fixed magnets
Dave
Simon Bridge said:
Welcome to PF;
Well I can think of the two obvious, Gravity and Electromagnetic force.
1. gravitation
2. electrical
3. magnetic
ruling out the strong and weak nuclear forces.
But - it may be that the question is thinking in terms of a free body diagram?
It really depends on where you are up to in your course.
Have you tried davenn's suggestion?
davenn said:
Hi clark
Dave
I know that an electric current is generated when the magnet moves through the conductor. I looked it up and found something called "Eddy's Current" that i will need to look into so i can better understand exactly what occurs.
clark84 said:
I know that an electric current is generated when the magnetic field moves through the conductor. I looked it up and found something called "Eddy's Current" that i will need to look into so i can better understand exactly what occurs.
That's a good start :smile:
Now think or research about what those eddy currents that are set up in the pipe do/causeDave
PS, note the little highlighted correction I did in your quoted text :smile:
