What Causes Thunder? New Research Answers
  • Context: Undergrad
  • Thread starter Thread starter gary350
    thunder
The latest research indicates that thunder is primarily caused by the rapid expansion of air due to the intense heat generated by lightning strikes, which can reach temperatures between 20,000 K and 30,000 K. A significant factor in the intensity of thunder is the amount of rainwater present in the lightning's path, as demonstrated by experiments showing that a 300 megawatt capacitor bank can convert just two tablespoons of water into 1800 volumes of steam in less than 1/1000 of a second, creating explosive effects comparable to dynamite. The speed of lightning is approximately 220,000,000 miles per hour, and the length of the lightning strike also contributes to the sound characteristics of thunder. Observations confirm that thunder can occur even in dry conditions, challenging previous assumptions about its dependence on rain.
  • Understanding of basic physics principles, particularly thermodynamics.
  • Familiarity with electrical discharge phenomena, such as lightning.
  • Knowledge of the properties of water and steam under rapid heating conditions.
  • Awareness of sound wave propagation and acoustic phenomena.
  • Research the physics of lightning and its interaction with atmospheric conditions.
  • Study the thermodynamic properties of water and steam, particularly in explosive scenarios.
  • Explore the relationship between lightning strikes and sound wave characteristics, including the factors affecting thunder.
  • Investigate experimental setups similar to those used at Oak Ridge National Lab for studying high-voltage discharges.
Scientists, meteorologists, electrical engineers, and anyone interested in atmospheric phenomena and the physics of lightning and thunder.
gary350
The newest research information about what causes thunder makes more sense then the old theories.
Tests show a capacitor bank discharged into a measured water volume turns into steam instantly producing 1800 volume of steam, producing more power than some explosives.
A 300 mega watt capacitor bank was discharged into 2 tablespoons of water. The water turns to 1800 volumes of steam in less than 1/1000 of a second producing 36000 volumes of steam. Water has the explosive power of dynamite it blasted a hole through 3/4" plywood large enough to drop a basket ball through the hole. The explosion was so powerful that 99% of the wood from the hole was turned to dust.
Thunder is directly proportional to the power of the lightning strike, the length of the lightning strike, and the amount of rain water in the path of the lightning strike. Lightning strikes are about 220,000,000 miles per hour (about 1/3 the speed of light). Lightning initial temperature is about 20,000 K to about 30,000 K. Several gallons of rain water can be turned to steam instantly producing a powerful explosion = to several 100 lbs of explosives.
Science news on Phys.org
Link please. We would like to see what you have been reading.
gary350 said:
Thunder is directly proportional to ... the amount of rain water in the path of the lightning strike.
Can we have lightning through dry air with little water content? If yes, is there no thunder? That should be testable.
Likes Charles Link
You know, or it's the shock wave that occurs when lightning superheats air instantly.
Water is a highly polar molecule which perhaps could have something to do with the heating process that occurs from the electric discharge, but I would like to see some calculations and experiments where someone has done a thorough study of the process.
I get zapped by static electricity ( a small lightning strike ).
I don't witness any steam being produced, yet I hear a noise.
Likes Asymptotic, davenn and Charles Link
Likes davenn
Van de Graaf so what? I don't associate that crackle sound with thunder.
YES, I don't associate spark sounds with thunder either. The sound of a spark is different than thunder. Oak Ridge National Lab TN has 10 Van de Graafs stacked to a height of 150 ft they can make sparks 150 ft long. If you watch the sparks at the observation window there is a loud snap sound from the sparks but no thunder.
That's very cool. I would love to see that the next time I pass through Oak Ridge. Is it open to the public?
p.s. 50 years ago I met Dr. Van de Graaf at High Voltage Engineering Co. on RT 128 near Boston. They were busily building accelerators to be use in the manufacture of heat shrinkable plastic film.
Likes russ_watters
I don't think I would agree with those comments
we are talking about a huge difference in discharge size, voltage and surrounding conditions
150 ft ? peanuts !
the avg lightning discharge is around 2km ... some a little shorter ~ 1km, many much longer upwards of 5km or so
The very much higher voltages and currents and in the open air rather than strongly controlled lab conditions all add up to
a major increase in the level of sound heard when the air is converted to plasma.
OK found a comment
https://en.m.wikipedia.org/wiki/Lightning#Thunder
ThunderEdit
Main article: Thunder
Because the electrostatic discharge of terrestrial lightning superheats the air to plasma temperatures along the length of the discharge channel in a short duration, kinetic theory dictates gaseous molecules undergo a rapid increase in pressure and thus expand outward from the lightning creating a shock wave audible as thunder. Since the sound waves propagate not from a single point source but along the length of the lightning's path, the sound origin's varying distances from the observer can generate a rolling or rumbling effect. Perception of the sonic characteristics is further complicated by factors such as the irregular and possibly branching geometry of the lightning channel, by acoustic echoing from terrain, and by the typically multiple-stroke characteristic of the lightning strike.A portion of your original comments,
and note you have shown NO LINKS to back up your claims...
I don't believe for a second that is the main cause for the thunder. It may contribute a little as some water molecules are ionised. But that accounts for only a tiny proportion of lightning strikes.
Being an avid storm chaser and photographer for many years. I can categorically state that I have seen 100's, probably 1000's of lightning strikes where there was no rain. There is ALWAYS thunder !
Dave
Likes nasu, russ_watters and boneh3ad
The scientific rigor in this thread is staggering.
Likes rbelli1, cjl, russ_watters and 1 other person
150 ft ? peanuts !
OK found a comment
ThunderEdit
Dave
Listen to a hot summer day no rain lightning strike it makes a crackling sound there is no BOOM thunder sound that echos across the country side for 10 seconds like a dynamite explosion. When I lived in Arizona we use to get heat lightning July & Aug 114 degrees with 4% humidity that came from no where in the sky with no clouds if you look very close you see a long skinny lightning spark & a tiny crackling spark sound. Several people on the electronic form made videos of discharging a large capacitor bank into a spoon of water instant steam produces an extremely power explosion = to dynamite. 1 lb stick of dynamite contains 3.2 oz of nitro = to about 3.5 tablespoons of water vaporized in less than 1/1000 of a second with 300 meg watts of power from a capacitor bank. A very powerful 1/2 mile long lightning strike will travel through many times more water than 3.5 tablespoons.
Did you actually bother to calculate the density of liquid water in a rainstorm and the effect of heating it vs heating the air? It should be easy to take a hypothetical 1 square foot by 10,000 foot column of air and rain, calculate how much air and rain are in it and calculate how much each expands if their temperature is raised by a certain amount. I think you will find that the actual density of water is quite small, so the expansion of the air is a bigger factor.
Edit: I'm impatient. By my calculation, 10,000 cubic feet of a medium hard rainstorm contains about 3 ounces of liquid water and 750 lb of air.
Likes boneh3ad and davenn
We beat that, although it was a plasma arc rather than puny sparks from a van de Graaf generator. :-)
https://phys.org/news/2011-11-extra-long-electrical-arcs-energy.html
Cheers
Likes davenn
You are not understanding the process ... Did you even read what I quoted a few posts ago ?
The sound the thunder makes is based on a number of variables ...
1) distance to the strike ... very close ones are the very common intense crack sounds with almost no longer period ( drawn out) rumbling
2) whether the strike was a single discharge or multiple ones down the same path
3) whether it was a multi path across the sky discharge ... produces multiple sets of sound shock waves that radiate out
4) the terrain and or clouds also have a distinct effect on lengthening out the rumbling ... aka echoes
as the sound bounces between cloud and ground and back up again, as well as between the cloud masses
There are probably other causal effects but above would be the main ones
and all those effects interactDave
Cuz you hear all of the sound at the same time ( no time lag ), with very little reflections, so it is a snap.Also, some more notes on effects of lightning, oxygen molecule splitting and ozone production., as well as NOx production.
The oddly sweet, pungent smell that sometimes precedes a storm is that of ozone. Lightning strikes split diatomic oxygen molecules in the atmosphere into individual oxygen atoms. These can then combine with other oxygen molecules to form ozone
https://www.compoundchem.com/2018/07/31/thunderstorms/
so, even that tiny little spark, as well as sparks from electric motor cummutator produce ozone.
In essence that little spark is a very similar to the lightning associated with a train storm, though on a much smaller scale.
Likes davenn and russ_watters
It's also a short spark (in distance more than time), so the sound has a short duration. For lightning that isn't parallel to you, the slow speed of sound stretches the duration of the thunder.
Likes 256bits and davenn
@gary350 : you were asked, way in the beginning, for a link or a source to back up your first post. You have not done this, and I'm surprised the Mentors are letting you get away with it.
I want to know what is this "... newest research information ... "
Zz.
Likes davenn
@256bits I thought the noise like you describe is from the breakdown strength of the air at/around a conductor. Not the physical humming of a transformer, but like touching 2 leads together and 'hearing' the spark. Oddly, water increases the conductivity of the air and so increases the intensity of the discharge you hear. We were always taught in electronics school that the clap from lightning was from the created vacuum (or close enough) from the lightning collapsing under atmospheric pressure after the bolt.
I would hazard that part of the thunder is from the conductive channel collapsing after the discharge. Although not lightning, I was once in a store when an oil tanker blew up in the harbor about six miles away. The noise from the explosion was accompanied by the door swinging open outward.
I am a little confused about why this has become such a debate. Lightning dumps a lot of energy into a relatively small region over a very short period of time. It's pretty standard that heat being dumped that rapidly into air causes a rapid expansion and shock wave that behaves much like a sonic boom. There are certainly other compounding factors, but that seems to almost certainly be the O(1) effect here.
Likes davenn, Bystander and DrClaude
I didn't say anything about a transformer, only about sparks that do not vaporize liquid water, and yet there is a noise to be heard.
If you go back to the original post number #1, it I mentioned,
I am assuming, but did not check the numbers, that the 1800 volume change speaks of liquid water turning into a gas, and the 36000 volume speaks of the gas ( water vapour ) expansion due to a rise in temperature.
Due to the liquid water being "doubly" expanded, the premise would be the thunder is "different" under different conditions.
In #2 @anorlunda mentions a test of the situation should be testable - such as dry air vs humid air vs wet air ( with water droplets ).
The small spark that people are familiar with, and the giant sparks from a high voltage Van de Graff generator should be a test of, at least, the situation of the spark through air that has some water vapour within.
And so on through the postings...
I think that's the old theory.
I think it has been updated to that as mentioned in post #3 by @boneh3ad
No one has mentioned the rumbling, crunching sound from cavitation - maybe there is a similarity to some extent as to what you refer, and thunder from lightning due to oscillations of the air around the lightning path.
Is there a effects from the cavitation via ultrasound, or sonoluminescence, applicable to lightning - well maybe that is going to far and off course,
But see, if you are interested, especially about shrimp claws at the bottom of the page,
https://en.wikipedia.org/wiki/Sonoluminescence
@gary350 has ignored two requests to post a link to the source of the assertions in the OP.
Thread closed.
  • · Replies 16 ·
  • · Replies 16 ·
