Undergrad Connection Types: Affine vs Non-Affine
  • Thread starter Thread starter kent davidge
    Connection
Affine connections are preferred in General Relativity due to their ease of use and the nature of the tangent spaces involved. Non-affine connections are not forbidden in the theory but are less common and typically relate to more complex structures like general fiber bundles. The distinction lies in how these connections relate different spaces, with affine connections linking affine spaces directly. For those interested in exploring non-affine connections further, engaging with differential geometry resources is recommended. Understanding these concepts is crucial for advanced studies in geometry and physics.
kent davidge
Based on what will you choose a connection to be affine or non-affine?
It seems to me that it's always more easy to work with affine connections, and I've seen only them being used in General Relativity. Are non-affine connections forbidden in the theory?
The "affine" part of the connection refers to the type of data that is being connected. In that case, the tangent spaces (which are affine spaces) at different points on a manifold are connected and thus you get an "affine connection". You can have non-affine connections which identify non-affine spaces with each other - e.g. if you had a more general fiber bundle than the tangent bundle, you might have a non-affine connection that connects fibers with each other in that structure. I don't have too much experience in general fiber bundles, so my knowledge kind of ends here. The connections used in GR is affine connections because the spaces that are important in GR is the base manifold and the tangent bundle (and cotangent bundle). If you want to explore more general connections and structures, you might want to ask in the differential geometry forum.
Likes kent davidge and fresh_42
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
