What determines the speed of two balls on a rotating disk?
The discussion revolves around the dynamics of two balls on a rotating disk, focusing on the relationship between angular velocity and linear velocity. Participants explore how these concepts affect the speed of the balls as they move towards the wall.
  • Participants discuss the implications of moment of inertia and angular momentum, questioning how these relate to the speeds of the balls. Some express confusion about the relationship between angular and linear velocities, while others consider geometric factors affecting the balls' travel distances.
The conversation is active, with participants offering insights into the differences between angular and linear velocities. There is recognition of the complexity introduced by rotation, and various interpretations of the problem are being explored without a clear consensus.
Participants are navigating assumptions about the motion of the balls and the effects of their positions on the disk. There is an acknowledgment of the need for clarity regarding the definitions of angular and linear velocities.
november1992
I=m[itex]r^{2}[/itex]
L=ωI
ω=[itex]\frac{L}{I}[/itex]
I thought that since the moment of inertia was larger for the ball on the outside its angular speed would be slower. So then it would take longer to hit the wall.
You're missing something important in this question which is the difference between angular velocity (rad/s) and linear velocity (m/s). You don't need to be using angular momentum/moment of inertia.
Using ω is right while the girls are holding the ball, but when it is let go when it hits the wall depends on v, which is related to ω by some geometric considerations. If you notice, the two girls are sitting in a straight line with each other, one further out than the other, and they are always in that straight line, meaning that the girl further out has to travel further than the girl on the inside in the same amount of time. What can you figure from that?
I was thinking about that before, but I thought it would be strange if the ball on the outside traveled faster than the ball on the inside. So, I assumed they were traveling at the same speed.
Their ω is no doubt equal, they're both going through the same amount of radians as the other in the same time.
The problem is with arc lengths though--which is equal to θr (make sure θ is in radians). The girl on the outside moves further in the same amount of time, so the ball is actually moving faster.
Physics gets weird when things start rotating.
