Undergrad What do the wave functions of real particles look like?
The discussion centers on the complexities of wave functions in quantum mechanics, particularly regarding real particles like electrons. Participants clarify that while planar waves have infinite wave fronts and cannot be normalized, wave packets provide a more accurate representation of particles with finite momentum and energy spreads. The interaction of electrons with narrow slits leads to diffraction patterns, indicating a superposition of wave functions. The De Broglie wavelength is described as a useful conceptual tool, representing the "carrier frequency" of wave packets, though its application in modern quantum mechanics is debated. Ultimately, the nature of wave functions and their interpretations remains a nuanced topic, reflecting the strangeness of quantum theory.
AlbinoAlpacca
TL;DR
The wave function of a particle cannot really be a planar wave packet. What is it instead?
Hi,
We just started studying wave-particle dualism and there is a basic thing I do not understand. Usually we use a planar wave packet to describe particles (an electron for example). This seems confusing to me because planar waves have infinitely extended wave fronts, which first of all means that the wave function cannot be normalized and secondly would imply that the electron is not at all spacially constrained, we could find it in our labaratory just as well as on the moon. So what does it look like instead? For example, if an electron is freed during a collision of two atoms, one option I could imagine would be a cone-like sector of a spherical wave packet. Is this correct? How would you calculate that?
The wavefunction of a free electron is often thought of as a 3D Gaussian function. This entails an uncertainty in position and an uncertainty in momentum. If the electron interacts with something small enough -like a very narrow slit - then a sharply peaked Gaussian may look similar to a plane wave.
But a 3D Gaussian has just one peak, does this change when it interacts with a slit for example?
Yes, the electron diffracts. On the far side of the slit you have a superposition of spatially separate wave-functions. This is what causes the single-slit diffraction pattern.
The slit acts as a temporary infinite square well.
What about the case of an electron that collides with another particle, what does the wave function look like afterwards? Also, what about the momentum vector of the electron after the diffraction? For a planar wave, we used h bar * k, but this doesn't work for any non-planar waves, right?
I doubt there is a generic answer to that. The thing to remember is that the UP (Uncertainty Principle) even for an electron allows much classical-like behaviour. The precise form of the wavefunction is not critical in all expweriments. Generally unless the precise wave-function changes the observed phenomena, it's a) hard to calculate; and b) not of any practical use once you've calculated it.
You can contrast this with an electron in an atom, where the precise harmonic wave-functions form the basis for absorption and emission spectra.
Or, for the electron's behaviour at a potential barrier. In this case, you might treat an electron as a Gaussian wave-packet, in order to calculate reflection and transmission coefficients.
Likes Delta Prime and javisot20
Another thing I was wondering, if a free electron is associated with a 3D gaussian, what meaning does the De Broglie wave length have? Is it just the wavelength of the wave function of the particle that it would get after an interaction with a slit for example?
I don't know much about the De Broglie matter-wave theory. AFAIK, it's not part of modern QM.
Thanks for taking the time to respond to my questions anyway. Maybe things will become clearer for me after studying more modern approaches to QM.
As previously mentioned, the De Broglie wavelength is just a hand-waving rule of thumb that was developed at the beginning of quantum science. But it is still very useful in getting an intuitive feeling for what is happening. How it fits into the 3D Gaussian can be thought of in the following way: The De Broglie wavelength (lambda = h/p) is the "carrier frequency" of the wave-packet. In analogy to light, it is the "color" of the wave.
Likes dextercioby
I'm not sure I fully understand what you mean by carrier frequency. In the case of light, the wavelength can be found simply by looking at the fields, for particles in a potential well we can sample the probability of the particle being at certain positions and get our wavelength that way. Where is the wavelength in the case of an electron whose probability of presence does not give us a hint? In the drawings that were shown in the class, free electrons were usually depicted as wave-packets and I assumed that it meant that their wave function looked something like that, but this does not seem to be the case.
AlbinoAlpacca said:
planar waves
These are two different things.
A single plane wave has infinitely extended wave fronts. A wave packet does not.
A single plane wave describes an idealized "particle" traveling in a specific direction with a specific exact momentum and energy. In other words, something that never actually exists.
A wave packet describes something closer to what a real source of particles would emit, with a finite spread in momentum and energy and a finite range of directions in which the particle travels.
As others have said, de Broglie wave theory is not a good way to grasp our modern understanding of this. You need to look at a modern textbook, such as Ballentine.
The word real has philosophical connotations, which we do not discuss (by forum rules) here.
Anyway, the answer is interpretation dependant.
Some, like me, think the wave function is just a calculational device aiding in calculating the probability of observations. Others believe it is real. Indeed, some experts in this area (e.g. Tim Mauldin) always tacitly assume it is real; it is so natural. But to be clear, the math allows either view.
Gleason's theorem, to me, suggests it is just a calculational device.
So one can say they look different in different physical situations (if you graph it like a 3d plot), reflecting it is the solution to Schrodingers equation e.g. for the electrons in a hydrogen atom:
This raises the question of whether electrons are real - the observations in our commonsensical world are, but are the particles? Again, it is interpretation-dependent, but as excitations of a quantum field and quantum fields have energy, most would say yes (e = mc^2 and all that).
Now, that raises the question of whether the wavefunction is the limiting case of a quantum field? Interesting question examined here:
https://arxiv.org/abs/1712.06605
I have learned that QM is not only strange but stranger than many think. By this, I mean it is mathematically defined but has surprise after surprise.
After digesting this, the natural question is, must we go to something even more profound to explain QFT, like with QT? Interestingly, what Wienberg calls a folk theorem says that any theory will look like a QFT at large enough distances. So it would seem the answer to that question will not be found without much effort - as we know only too well these days.
But who knows - as I pen this, someone labouring away as a patent clerk may have the answer :DD:DD:DD:DD
Thanks
Bill
Likes Delta Prime
To me, wave-particle dualism is an attempt to relate quantum objects to familiar things. I think the conclusion of physicists over the last century is that this cannot be done and that trying just gets in the way. Accept the quantum world as completely weird, don't expect anything, and go from there.
Likes weirdoguy and martinbn
  • · Replies 36 ·
  • · Replies 16 ·
  • · Replies 17 ·
