What Does a Constant Velocity Graph Look Like?
7 replies · 2K views · last reply
_Reza_
Identify the motion that the different sections of the graph describe
t=0-2 is accelerating
t=2-4 is stationary
t=4-5 accelerating
t=5-9 decelerating/slowing down
Options which are given: Constant speed, moving back to the start position and the above. Is my solution correct?
thank in advance
  • Displacement-time graph with Time (s) on the horizontal axis from 0 to 9 and Displacement (m) on the vertical axis. The line rises straight from (0, 0) to (2, 3), stays flat at 3 m from 2 s to 4 s, rises steeply to (5, 9), then rises more gently to about (9, 12).
First things first: On such a diagram, what would a constant speed motion look like? What aspect of the diagram tells you the speed? Then: What would acceleration look like?
well since the distance is changing over time, that must imply that the object is moving hence for t= 0-2 it is accelerating. Now for t=2-4 distance is not changing therefore it must be stationary. for t=4-5 and t=5-9 the object is accelerating but the first interval (t=4-5) is accelerating faster than the other (t=5-9) . My confusion is that they had provided other possible answers which i have stated, but i can not see any constant acceleration in that diagram
Yes, during that time the object is moving. But moving does not mean accelerating. What's the definition of acceleration?
the rate of change of velocity over time, does that mean the object is moving in constant speed?
Exactly!
So what would a graph of constant velocity look like?
Doc Al said:
Exactly!
Graph that shows distance and time, so distance/time= constant speed. so the different intervals were the distance is changing, is the objects always at constant speed?
Tell me what such a displacement vs time graph looks like. Would it be straight lines, curved lines, flat lines, what?
How would you draw a graph of the motion of an object moving at constant speed?
