What does it mean to say a battery is however many volts?
A battery labeled as 9V indicates a potential difference of 9 joules per coulomb (J/C) between its terminals. When a 1C charge is moved from the negative to the positive terminal, its potential energy increases by 9J. This potential energy gain requires external work to be done on the charge, as a positive charge does not spontaneously move from the negative to the positive terminal. The analogy of voltage as 'height' effectively illustrates how potential energy is gained and lost in a circuit.
  • Understanding of electric potential and potential energy
  • Familiarity with the formula V = Kq/r
  • Knowledge of charge movement in electric circuits
  • Basic concepts of work and energy in physics
  • Study the relationship between electric potential and work done on charges
  • Explore the concept of electric fields and their influence on charge movement
  • Learn about the principles of circuit design and resistance
  • Investigate the implications of charging and discharging batteries in practical applications
Physics students, electrical engineers, and anyone interested in understanding the principles of voltage, electric potential, and energy transfer in circuits.
kostoglotov
For instance, at a point 1 meter from a 1 nC charge the voltage (potential difference) from the formula V = Kq/r, is given as 9 volts, 9 J/C.
So what does it then mean to call a battery 9V, 9 J/C? Is this a battery capable of taking a 1 C charge from infinity and pushing to within 1m of a 1 nC source of some electric field?
It means that if you move a 1C charge from the negative terminal to the positive terminal, its potential energy increases by 9J. The battery already defines the potential difference of 9V between its positive and negative terminals, so we don't use the point at infinity as the zero potential reference.
And so a circuit that connects those terminals is a pathway across which a charge could gain PE by moving from the negative terminal to the positive terminal? And if that circuit is more than just a (theoretically) resistance-less why, then as that charge is picking up PE, some of that PE will be doing work in the circuit before it reaches the other terminal?
So could we think of voltage as 'height'?
A [positive] charge will not spontaneously move from negative terminal to positive terminal. It takes work to move it in that direction. Its gain in PE corresponds to the external work that must be supplied to get it to move.
The PE that is gained by a charge does not do work as it is gained. It is the other way around. You must do work on the charge to get it to gain PE.
As a [positive] charge is released from the positive terminal and allowed to flow to the negative terminal, its potential energy is released. The PE that it loses is a source of work or heat in the circuit.
Yes. That analogy works.
So when Chandra Prayaga said above
"It means that if you move a 1C charge from the negative terminal to the positive terminal, its potential energy increases by 9J."
They were describing something more akin to a battery being charged than a battery being used?
Yes.
jbriggs444 said:
Yes.
Thanks, jbriggs444. Yes. The electric potential energy increases by 9J. That energy needs to be provided by the hand or whatever moves the positive charge. In the motion of any charge q from point A to point B, any number of forces could be acting on the charge, but the change in electric potential energy is UB - UA = q(VB - VA), where V stands for electric potential and U stands for electric potential energy.
  • · Replies 58 ·
  • · Replies 21 ·
  • · Replies 17 ·
