What does probability amplitude mean
The discussion centers on the concept of probability amplitude in quantum mechanics, specifically the wave function ψ(x,t) and its role in determining the probability density of finding a particle at a given position x and time t. To obtain the probability density, one must multiply the wave function by its complex conjugate, resulting in P(x,t) = ψ*(x,t)ψ(x,t). The conversation also touches on the interpretation of quantum states, highlighting the distinction between viewing them as physical properties versus statistical distributions.
  • Understanding of wave functions in quantum mechanics
  • Familiarity with complex numbers and their conjugates
  • Knowledge of the Schrödinger equation and its components
  • Basic grasp of probability theory as applied to quantum states
  • Study the mathematical formulation of the Schrödinger equation
  • Explore the concept of quantum states and their interpretations
  • Learn about the role of complex conjugates in quantum mechanics
  • Investigate probability density functions in quantum systems
Students and professionals in physics, particularly those focusing on quantum mechanics, as well as anyone interested in the mathematical foundations of probability theory in relation to quantum states.
latnoa
I'm not exactly sure what it means when my book says that the wave function ψ(x,t) is a probability amplitude of knowing where the particle is in position x at time t.
It's simply a definition of the term "probability amplitude." In order to get the actual probability density, you have to multiply the probability amplitude by its complex conjugate:
$$P(x,t)= \Psi^*(x,t) \Psi(x,t)$$
"Probability amplitude" is more general than ##\Psi## because it also applies to other functions. For example, there is a momentum-space probability amplitude ##\phi(x,t)##, for which ##\phi^*(x,t) \phi(x,t)## gives you the probability density for the particle's momentum.
You can treat it as a field.
Or you can multiply it with electronic charge of electron,than the result is the distribution of charge in the space.
It means that if you attempt to locate the particle at position x at time t, the value of the wave function tells you the probability that you will actually find it there.
More specifically, the wave function multiplied by its complex conjugate gives you this probability directly. So if the value of the wave function is 1/2 at some location at some time, then the interpretation is that if one out of every four times you repeat the experiment and look at that location, you should find the particle there.
latnoa: welcome to the club...beyond the mathematical descriptions lots of people have
had that problem...Post #2 has the math definition if that's what you were after.
If you are looking for interpretations of that matematics:
Try here for some good discussion and animations...
http://en.wikipedia.org/wiki/Wavefunction
but how a 'real' particle is represented by 'complex' numbers is where it gets really interesting.
Another view is this:
...Quantum states are the key mathematical objects in quantum theory. It is therefore surprising that physicists have been unable to agree on what a quantum state represents. There are at least two opposing schools of thought, each almost as old as quantum theory itself. One is that a pure state is a physical property of system, much like position and momentum in classical mechanics. Another is that even a pure state has only a statistical significance, akin to a probability distribution in statistical mechanics...
https://www.physicsforums.com/showthread.php?t=551554&page=2
I could be wrong, but is your question why use a "probability amplitude", when it's not the actual probability? In other words, what is it actually good for?
The OP needs to come back and explain what he means by the word "means". :biggrin:
Thank you everyone. I've read more in detail this section but I will tell you my own way of explaining this and tell me if I'm wrong.
The wave function depends both on its position (x) and time (t). We can split the wave function into two parts, one that represents the time and the other one that represents the position.
ψ(x,t)= \psi(x) * f(t)
Furthermore if we split the Schrödinger equation into it's time independent part we see that a function of time is equation to a function of position which also means that these functions equal a constant. If we set the function equal to that constant we get a differential equation and once we solve the differential equation we get
f(t) =e-iEt/h
Where E is the the constant. Furthermore if we can replace f(t) into the wave function.
ψ(x,t)= \psi(x) * e-iEt/h
We know that if we try to find where the particle is in a certain time we can do so by finding the integral of the wave function times its complex conjugate. Then we can say that the probability of finding the particle from negative infinity to infinity has to be 1
\intψ(x,t)*ψ(x,t)= 1
Where we integrate from negative infinity to infinity. Then by integrating the f(t) cancels out( I don't know how) so we are just left with
\int|\psi(x)|2= 1
Which means that the probability of the position for the particle is time independent.
Edit: Sorry I didn't understand what complex conjugates were or how we can use them to find the probability but I posted this to make sure I actually understand it now.
"Complex conjugate" means replace i with -i everywhere.
The f(t) cancels out even before you take the integral:
$$\Psi(x,t) = \psi(x)e^{-iEt/\hbar}$$
$$\Psi^*(x,t) = \psi^*(x)e^{+iEt/\hbar}$$
$$\Psi^*\Psi = \psi^*\psi e^{+iEt/\hbar}e^{-iEt/\hbar} = \psi^*\psi e^{+iEt/\hbar-iEt/\hbar} = \psi^*\psi e^0 = \psi^*\psi$$
  • · Replies 32 ·
