What Does d Represent in Calculus and Physics Equations?
  • Thread starter Thread starter AznBoi
    Mean Symbol
The symbol "d" in calculus and physics equations represents an infinitesimal change, specifically in the context of derivatives. In the equation I = dq/dt, "d" indicates the instantaneous rate of change of charge with respect to time, contrasting with the average current represented by I = Q/t. The concept of "d" is foundational in calculus, where it signifies the limit of a sequence of ratios as the change approaches zero, thus allowing for precise calculations of instantaneous values. Understanding "d" is crucial for grasping the principles of differentiation and the rigorous definition of derivatives.
  • Basic understanding of calculus concepts, particularly derivatives
  • Familiarity with the notation of limits in mathematics
  • Knowledge of physics principles related to current and charge
  • Ability to interpret mathematical symbols and their meanings
  • Study the concept of limits in calculus to understand their role in differentiation
  • Learn about the formal definition of derivatives and their applications
  • Explore the relationship between average and instantaneous rates of change
  • Investigate the use of differential notation in physics and engineering contexts
Students of mathematics and physics, particularly those studying calculus, as well as educators seeking to clarify the concept of differentiation and its applications in real-world scenarios.
AznBoi
What does the symbol "d" mean??
I've seen the symbol "d" many times and in a physics lecture. For example: the professor would write: I = \frac {dq}{dt} instead of: I = \frac {Q}{t} I think I've also seen it in calculus equations such as derivatives and such. I'm only in Pre-calculus so I haven't not yet gone over anything related to calculus. But I'm interested in finding out what the "d" means in the formulas. Thanks. :smile:
"d" means change... in the limit that the change is infinitestimal. in your particular exapmle: I=Q/t really means "average" current because that's total change in charge over total change in time: in fact it means
I_{av.}=\frac{\delta Q}{\delta t}=\frac{Q_f-Q_i}{t_f-t_i}, now when in the limit of very small change... ie. \delta t \rightarrow 0 this becomes \frac{dQ}{dt}, the advantage of this quantity is that you can now specify "I" at any instance.
anyway, calculus means two things in essence: chop things up into small bits or adding small bits togeter.
Oh ok, I knew it was related to delta \Delta thanks!
Yikes, this is not the best way of learning what dq/dt means.
Note that an "infinitesimal change" as a quantity is NOT a well-defined term mathematically. Mjsd's comment about calculus is good as a conceptual way to look at things only. Therefore, although physicists do it all the time, dq and dt really shouldn't be treated as quantities, and dq/dt shouldn't be treated as a ratio. It is the limit of a sequence of such ratios:
\frac{dq}{dt} = \lim_{\Delta t \to 0} \frac{\Delta q}{\Delta t} = \lim_{\Delta t \to 0} \frac{q(t + \Delta t) - q(t)}{(t + \Delta t) - t}​
To reiterate: the derivative of the function q(t) is given by the limit as \Delta t \rightarrow 0 of the above sequence of ratios. A limit IS a well-defined concept in mathematics, and you will learn what it means when you take calculus. It is used to define a derivative rigorously and formally. As a result, d shouldn't be thought of as a symbol, if you want to be mathematically proper. Instead, \frac{d}{dt} should be thought of as a symbol that represents the operation of differentiation. When this d/dt acts on a function, the operation of differentiation with respect to time is carried out on that function to produce the first dervative of the function with respect to time.
\frac{d}{dt}q(t) = i(t)​
In this example, the derivative of the function, denoted by dq/dt, represents the instantaneous rate of change of q(t) (i.e. the instantaneous current, as opposed to the average current over some finite time interval).
  • · Replies 19 ·
