How Does Eisenstein's Criterion Confirm the Irreducibility of a Polynomial?
  • Context: MHB
  • Thread starter Thread starter mathmari
    Relation
The discussion centers around the application of Eisenstein's criterion to confirm the irreducibility of the polynomial $f(x)=x^3-3x-1$ over the rational numbers. Participants explore the implications of this criterion, the roots of the polynomial, and related algebraic expressions. The scope includes theoretical reasoning, mathematical proofs, and inquiries about specific algebraic identities.
  • Some participants demonstrate that $f(x+1)$ satisfies Eisenstein's criterion with prime $p=3$, suggesting that $f(x)$ is irreducible in $\mathbb{Q}[x] based on this transformation.
  • There is a discussion about the roots of the polynomial, particularly examining $a$ and $2-a^2$ as roots and the need to find a third root using the Euclidean algorithm.
  • Participants question the existence of integers $c_0, c_1, c_2$ such that $(3+a-a^2)^n=c_0+c_1a+c_2a^2$ for all positive integers $n$, and propose using the binomial theorem and induction to prove this.
  • Some participants suggest that the relation $(1-a)^n=(c_0+2c_1+4c_2)+c_2a-(c_1+c_2)a^2$ can be shown through the consideration of an automorphism defined on $\mathbb{Q}[a]$.
  • There are discussions about the validity of certain algebraic manipulations and theorems regarding field extensions and isomorphisms, with some participants expressing confusion or seeking clarification on these points.
Participants generally agree on the application of Eisenstein's criterion and the irreducibility of the polynomial, but there are multiple competing views regarding the proofs and implications of certain algebraic identities and theorems. The discussion remains unresolved on some technical points, particularly regarding the automorphism and the validity of certain algebraic statements.
Limitations include potential misunderstandings of theorems related to field extensions and isomorphisms, as well as unresolved questions about the specific algebraic identities being discussed.
mathmari
MHB
Hey! :o
Let $f(x)=x^3-3x-1\in \mathbb{Q}[x]$.
Then $f(x+1)=(x+1)^3-3(x+1)-1=x^3+3x^2+3x+1-3x-3-1=x^3+3x^2-3$.
The prime $p=3$ divides all the coefficients except of the one of the term of the highest degree and $p^2$ doesn't divide the constant term.
So, from Eisenstein's criterion we have that $f(x+1)$ is irreducible in $\mathbb{Q}[x]$, and so is $f(x)$.
Let $a\in \mathbb{C}$ be a root of $f$, $f(a)=0 \Rightarrow a^3=3a+1$.
We have that $f(2-a^2)=(2-a^2)^3-3(2-a^2)-1=8-12 a^2+6 a^4-a^6-6+3a^2-1 \\ =-a^6+6 a^4-9 a^2+1=-(a^3)^2+6 a^3a-9 a^2+1 \\ =-(3a+1)^2+6 (3a+1)a-9 a^2+1=-9a^2-6a-1+18a^2+6a-9a^2+1=0$
so $2-a^2$ is also a root of $f$.
We have that $f$ is of degree $3$ and $a$ and $2-a^2$ are two roots, so we have to find the third root of $f$ by applying the Euclidean algorithm. $f(x)=(x-a)(x-(2-a^2))(x-(a^2-a-2))$
Since $a, 2-a^2, a^2-a-2\in \mathbb{Q}(a)$, i.e., all the roots belong to $\mathbb{Q}(a)$, we have that the extension $\mathbb{Q}(a)/\mathbb{Q}$ is normal.
Is this correct? (Wondering) Let $n$ a positive integer and $c_0, c_1, c_2\in \mathbb{Z}$ such that $(3+a-a^2)^n=c_0+c_1a+c_2a^2$.
Why do for every $n$ exist such $c_0, c_1, c_2$ ? (Wondering)
How could we show the following relation:
? (Wondering)
mathmari said:
Hey! :o
Yes. This much is fine.
You can expand out $(3+a-a^2)^n$ using the binomial theorem in the form $\sum b_ja^j$ for some integers $b_j$. Now since $a^3=3a+1$, an inductive argument shows that $\sum_jb_ja^j = c_0+c_1a+c_2a^2$.
? (Wondering)
For this give me some time.
The formula of the binomial theorem when we have $3$ terms is the following:
$$(3+a-a^2)^n=\sum_{k_1+k_2+k_3=n}\binom{n}{k_1+k_2+k_3}3^{k_1}a^{k_2}(a^2)^{k_3}$$
So, to show that $(3+a-a^2)^n=c_0+c_1a+c_2a^2$, do we use induction in respect to $n$ ?
Base case: For $n=1$ we have that $(3+a-a^2)^1=1+1\cdot a+(-1)\cdot a^2$.
Inductive hypothesis: We assume that $(3+a-a^2)^n=c_0+c_1a+c_2a^2, \forall n\in \mathbb{N}$.
Inductive step: We want to show that it holds for $n+1$:
$$(3+a-a^2)^{n+1}=(3+a-a^2)^n(3+a-a^2)\overset{\text{Ind. Hyp}}{=}(c_0+c_1a+c_2a^2)(3+a-a^2) \\ =3c_0+c_0a-c_0a^2+3c_1a+c_1a^2-c_1a^3+3c_2a^2+c_2a^3-c_2a^4 \\ =3c_0+c_0a-c_0a^2+3c_1a+c_1a^2-c_1(3a+1)+3c_2a^2+c_2(3a+1)-c_2a(3a+1) \\ =(3c_0-c_1+c_2)+(c_0+2c_2)a+(-c_0+c_1+3c_2)a^2$$
So, there are $\tilde{c_0}=(3c_0-c_1+c_2), \tilde{c_1}=(c_0+2c_2), \tilde{c_2}=(-c_0+c_1+3c_2)$ such that $(3+a-a^2)^{n+1}=\tilde{c_0}+\tilde{c_1}a+\tilde{c_2}a^2$.
Therefore, we have that for each $n$ there are $c_0, c_1, c_2\in \mathbb{Z}$ such that $(3+a-a^2)^n=c_0+c_1a+c_2a^2$.
Yes this is good. In fact there is no need to invoke the binomial theorem as your solution makes clear.
? (Wondering)
To show this relation we have to consider the automorphism $\tau : \mathbb{Q}[a]\rightarrow \mathbb{Q}[a]$ that is defined as follows:
$\tau (1) = 1 \\ \tau (a) = a^2 − a − 2$
How do we know that such an automorphism exists? (Wondering)
Right. I forgot about this problem.
In general, if $f(x)$ is an irreducible polynomial over a field $F$ and $K$ is an extension of $F$, and if $a$ and $b$ are two roots of $f$ in $K$, then there is an isomorphism $F(a)\to F(b)$ which takes $a$ to $b$ and fixes $F$ pointwise.
Now we have $a$ and $b:=a^2-a-2$ are both roots (in some extension of $\mathbf Q$, namely $\mathbf Q(a)$) of an irreducible polynomial $f$ over $\mathbf Q$, we have an isomorphism $\mathbf Q(a)\to \mathbf Q(b)$ which takes $a$ to $b$. Since $\mathbf Q(b)$ is contained in $\mathbf Q(a)$, it follows from this isomorphism that $\mathbf Q(b)=\mathbf Q(a)$ and we are done.
We have that $K=F[x]/\langle f(x)\rangle$ is a field that contains $F$ and inside of which $f(x)$ has a root.
From a theorem we have that there is a field $K$, an extenion of $F$ such that $a\in K$ wih $f(a)=0$ and $K=F[a]$.
Therefore, we have that $F[x]/\langle f(x)\rangle=F[a]$.
Applying the same for $b$ instead of $a$, we get $F[x]/\langle f(x)\rangle=F$. Is everything correct so far? (Wondering)
Do we get from that that there is an isomorphism $F(a)\to F(b)$ which takes $a$ to $b$ and fixes $F$ pointwise? Or do we prove it in an other way? (Wondering)
It seems that you do not understand the theorem I stated. Writing $F[x]/\langle f(x)\rangle = F(a)$ is not even valid if $a$ is not contained in $F[x]/\langle f(x)\rangle$. What you probably meant is that $F[x]/\langle f(x)\rangle \cong F(a)$. You also have $F[x]/\langle f(x)\rangle \cong F(b)$. But this does not tell us that there is an isomorphism $F(a)\to F(b)$ which takes $a$ to $b$.
I suggest you think about this theorem more carefully and try to come up with a proof. If you are unable to supply a proof then tell me and I will help you.
I thought the following:
When $F[x]/\langle f(x)\rangle \cong F[a]$ and $F[x]/\langle f(x)\rangle \cong F$ we get that $F[a]\cong F $ and so there is an isomorphism $F[a]\to F$.
Why does it not hold? (Wondering)
It is true that $F[x]/\langle f(x)\rangle F(a), F(b)$ and thus $F(a)\cong F(b)$. But this does not mean that there is an isomorphism $F(a)\to F(b)$ which takes $a$ to $b$ and fixes $F$ pointwise.
Could you give me a hint for the proof? (Wondering)
So we have that one irreducible polynomial of $\mathbb{Q}$ that has a root in $\mathbb{Q}(a)$ has all the roots there.
To conclude that the extension is normal do we not have to show that all the irreducible polynomials of $\mathbb{Q}$ that have a root in $\mathbb{Q}(a)$ have all the roots there? (Wondering)
This is a separate question. It is true that to show normality of an extension $K:F$, one has to show that each irreducible polynomial in $f$ that has a root in $K$ splits in $K$. But there is a theorem which states that if $K:F$ is the splitting field for a polynomial $f$ over $F$ then $K:F$ is normal. Using this theorem allows us to say that $\mathbf Q(a):\mathbf Q$ is a normal extension.
Okay. Here is the thing.
Theorem. Let $F$ be a field and $f(x)$ be an irreducible polynomial over $F$. Let $L:F$ and $K:F$ be extensions of $F$. Suppose $K$ has a root $a$ of $f$ and $L$ has a root $b$ of $F$. Then there is an isomorphism $F(a)\to F(b)$ which takes $a$ to $b$ and fixes $F$ pointwise.
Proof. (Sketch). Let $:\varphi: F[x]\to F(a)\subseteq K$ be the map which sends $p(x)$ to $p(a)$. Then $\varphi$ is a ring homomorphism with kernel $\langle f(x)\rangle$ (this uses the irreducibility of $f$ over $F$). Thus we have an isomorphism $\bar \varphi: F[x]\langle f(x)\rangle \to F(a)$. Similarly we have a a ring homomorphism $\psi: F[x]\to F(b)$ inducing an isomorphism $\bar \psi:F[x]/\langle f(x)\rangle \to F(b)$. Can you see that $\bar \psi\circ \bar \varphi^{-1}:F(a)\to F(b)$ has the required properties.
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 21 ·
