What does Young's Modulus x 2nd Moment of Area Equal
The discussion focuses on calculating the relative stiffness of I-beams using Young's Modulus and the Second Moment of Area (also known as the Moment of Inertia). The stiffness, represented as the product EI (where E is Young's Modulus and I is the Second Moment of Area), is essential for determining the flexural rigidity of beams in structural analysis. Specific beam sizes mentioned include universal column sections 203x203x60 and 254x254x89, and a universal beam section 406x178x74. The inquiry also touches on the necessity of considering beam length in these calculations.
  • Understanding of Young's Modulus and its application in structural engineering.
  • Knowledge of the Second Moment of Area and its significance in beam stiffness calculations.
  • Familiarity with structural steel sections and their properties.
  • Basic principles of moment distribution method in structural analysis.
  • Research the calculation of the Second Moment of Area for various beam shapes.
  • Learn about the moment distribution method in structural engineering.
  • Explore the relationship between beam length and flexural rigidity.
  • Investigate standard tables for structural steel properties, including Young's Modulus and Second Moment of Area.
Structural engineers, civil engineering students, and professionals involved in beam design and analysis will benefit from this discussion.
kiteboy
Hi all
I need to find the relative stiffnes of certain I beams from here
http://tsbluebook.steel-sci.org/EN/Browsers/Main.htm
Im assuming all I need to do times the Youngs Modulus by the 2nd Moment of Area
In my head I am making it more complicated than it should be so I hope this is all it is
As its all relative units etc don't matter - would that be correct??
Thanks for any info too
Will I also have to divide by the beam length too??
Your post is a little vague. Is there a problem associated with your question? It would help if you could post as much information as you can.
In general, the stiffness of a beam in resisting bending is usually determined by its moment of inertia, or the second moment of area. The quantity EI is also called the 'bending stiffness' or the 'flexural rigidity'.
There is a problem regarding a frame and the moment distribution method and I need to find the force that that will cause first yield to take place on the fram. It seems a bit involved to put the whole question here so thought Id ask a basic question and the first I think is to get the relative flextural rigidity of the beams of the frames
the beams for example are the following sizes
It is made from structural steel sections of mild steel as follows:
Column AB: universal column section 203x203x60, see section b-b for orientation.
Beam BC: universal beam section 406x178x74, see section a-a for orientation
Column CD: universal column section 254x254x89, see section b-b for orientation
So to start the calcs off and moment distribution the relative stiffness is needed hence me asking the above - sorry if vaugue
Apparently, there is some sort of figure associated with this problem. Can you post it?
These
These are british sections. Do you have standard tables giving you the 2nd M of A for each one?
18K
15K
19K
