What Experiments Can I Conduct to Investigate Light Sensitive Devices?
  • Thread starter Thread starter Taksehasam
    Light
The discussion revolves around investigating light-sensitive devices, specifically focusing on light-dependent resistors (LDRs) and potential experiments that could be conducted to explore their properties and responses to different light conditions. Participants are considering various experimental setups and the effects of light frequency on these devices.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss potential experiments, including the use of light filters and the relationship between light intensity and distance from the device. There are inquiries about the classification of human pupils as light-sensitive devices and the implications of light frequency on device response.
Some participants have provided hints and suggestions for experiments, such as demonstrating linear response and considering the frequency of light. There is an acknowledgment of the need for the original poster to clarify their thoughts and efforts before receiving more detailed guidance. Multiple interpretations of the assignment are being explored.
There is a mention of imposed homework rules requiring the original poster to show their efforts before receiving help. The original poster expresses some uncertainty about the experiments and the types of light-sensitive devices to compare, indicating a need for further clarification and direction.
Taksehasam
New poster has been reminded to show the Relevant Equations and their work on the solution
Summary:: Need help with LDR's, experiments/ investigations
I need to do an Investigation on Light Sensitive Devices, what 3 experiments could I do with similar aims that are somehow related, also does anyone know how different filters on light - frequency changes affect LDR's or where I could find more information on this?
Welcome to the PF. :smile:
We need you to show your efforts on your homework question before we can offer much tutorial help. What are your thoughts so far?
Also, is a human pupil considered a "light sensitive device" for this assignment?
This isn't a homework question it's my Investigation for Advanced Higher Physics, little help is given by the teacher in regard to the aim and how to do the experiment. I was considering doing light filters with a Light Sensitive Devices for one experiment. The other two I'm not sure yet but I've thought about doing a simple light intensity and distance away frkm the Device. What kind of Light Sensitive Devices could I compare in these and what convulsions would be drawn? I also got a hint regarding the frequency of the light and how fast the device reacts to different frequencies as something I should do in the Investigation.Any other ideas are welcome.
Sorry for posting in the wrong place, it's my first post :)
P.s a human eye would not be considered a Light Sensitive Device
The electronic frequency response is generally wavelength independent, and can be measured by modulating the incident light with a high speed chopper or other device. The wavelength response is found alternatively by seeing how the device responds to light of different wavelengths. This experiment requires optical filters and also a power meter with a flat spectral response that can measure the input power. Suggest you begin with something simpler than these two experiments. Building an op-amp photocurrent amplifier would be a good starting point.
Suggestion @berkeman would be to move this thread to the DIY section. It is a lot different than a typical homework problem.
See https://en.wikipedia.org/wiki/Photodiode
If you look at the I-V curve in this "link", you can see you get a linear response if you measure the photocurrent at or near zero voltage, as opposed to measuring the output voltage of the device. The op-amp current amplifier circuit is ideal for this purpose.
To give you a little background info, individual photodiodes should still be commercially available that have areas nearly 1.0 cm^2. In many cases, they are now also manufacturing focal plane arrays for cell phone cameras etc. where they may put more than a million pixels inside an area of 1.0 cm^2. I think you would do well to work with a single photodiode before experimenting with focal plane arrays.
  • · Replies 33 ·
  • · Replies 18 ·
