What Force Acts Between Hemispheres of a Charged Soap Bubble?
14 replies · 5K views · last reply
Buffu
There is a total of ##Q## charge on soap bubble of radius ##R##. What force is acting on one hemisphere by the other ?
Electrostatic pressure is ##P_e = 2\pi \sigma^2## for a spherical shell.
##P_e = F/A##
therefore ##F = AP_e = 2{A\over 2}\pi\sigma^2 = A \pi {Q^2 \over A^2} = {\pi Q^2 \over A} = {\pi Q^2 \over 4 \pi R^2} = {Q^2 \over 4\pi} ##
Given answer is ##{Q^2 \over \color{red}{8}\pi}##.
Where did I go wrong ?
First, your expression for electrostatic pressure is incorrect. It has the wrong dimensions. I suggest considering the force per unit area on the bubble which is, because the E field only has a radial component, $$F_r=E_r\sigma$$
By Gauss' Law, the R field just outside the surface is,$$E=\frac{Q}{4\pi\epsilon_0 R^2}$$
and the field inside the surface is zero. If you integrate the z component of force per unit area over one hemisphere you'll get the total force acting on it I.e.$$F=\left (\frac{Q}{4\pi \epsilon_0 R^2}\right )\sigma\left (2\pi R^2\right )\int_0^{\frac{\pi}{2}}cos\left (\theta\right )sin\left (\theta\right )d\theta= \frac{Q^2}{8\pi\epsilon_0 R^2}$$
Fred Wright said:
It has the wrong dimensions. I suggest considering the force per unit area on the bubble which is,because the E field only has a radial component,
Fr=Erσ​
Can you explain how you got this ?
Think you did,
Force per unit area is ##F/A = qE/A = \sigma E ##
Am I correct ?
What happened to x, y component ?
Yes, the force per unit area on the bubble is the E field multiplied by the change density. The total force between the two hemispheres is in the z direction.
I made a mistake in the integration by dropping a factor of 1/2. The answer I get is$$\frac{Q^2}{16\pi \epsilon_0 R^2}$$
Sorry:)
Sorry:)
SInce you gave the expression for total then the answer should be ##\displaystyle {Q^2 \over 4R^2}## but this does not match the given answer ?
I took ##k=1## since the unit used in the book is cgs.
Sorry:)
From your integral I get $$\frac{Q^2}{4\pi \epsilon_0 R^2}$$
The force per unit area is ##\frac{1}{2}E_r\sigma##, where ##E_r## is the field at the outer surface of the bubble. The reason for the factor of 1/2 takes some thought.
For a derivation see http://phys.columbia.edu/~nicolis/Surface_Force.pdf The result is given in equations (13) and (14) of this link. For the bubble, Ebelow of equation (14) is zero.
A different (somewhat hand-wavy) derivation is given in http://www.physicspages.com/2011/10/31/electrostatic-pressure/
##F = {1\over 2}E\pi \sigma = {1\over 2}4\pi\sigma^2 = 2\pi\sigma^2##
I used this and I got wrong answer :(.
Oh I need to integrate over the hemisphere with this to get the answer but why can't I just multiple with this with the area ?
The forces on different patches of area point in different directions.
It is possible to show that the answer can be obtained by multiplying the pressure by the area of a circle of radius equal to the radius of the hemisphere. Consider a solid, uncharged hemisphere acted on all sides by a uniform atmospheric pressure. We know that the hemisphere does not accelerate off in some direction. So, the force of the pressure on the curved surface of the hemisphere must be equal and opposite to the force of the pressure on the flat surface of the hemisphere.
I got ##dF = 2\pi \sigma^2 \cos \theta dA##
Changing to spherical coordinate,
##\displaystyle F = 2\pi\sigma^2R^2 \int^{2\pi}_{0}\int^{\pi/2}_{0}\cos \theta \sin \theta d\theta d\phi = {Q^2 \over 8R^2}##
But I want to do this without change to spherical coordinates, how can I do that ?
My issue is I am not able to express ##dA## into something useful.
OK
OK
Spherical coordinates are the natural coordinates for doing the integration. However, you can avoid having to do any integration by giving a geometrical interpretation to ##dA\cos \theta##. The figure below shows how to interpret this as a projection of a patch of area of the sphere onto a horizontal surface. So, summing all the ##dA\cos \theta## for the hemisphere is the same as summing all the horizontally projected areas. The sum of the projected areas is seen by inspection without having to perform an integration.
Two hand-drawn sketches. Left: a hemisphere with a vertical z axis, a small patch dA on its curved surface at angle theta from the axis, and a projected patch dA cos theta drawn below it. Right: a tilted patch dA projected onto a horizontal plane as dA cos theta, with angle theta marked.
TSny said:
OK
OK
Yes Thank you for the answer and the diagram really explains the thing.
The limits for the integration would be ##0 \to \pi/2## right ?
Yes, that would be the limits for ##\theta##.
