What Force Allows a Balloon to Float in the Air?
9 replies · 4K views
isyang94
As the balloon rises, the force of gravity pulls on the balloon, but which force is strong enough to pull the balloon up so that it floats in the air?
thanks
jarednjames,
I love the quote from Archosaur that you have started using in your signature ... that's classic :)
Dave
DaleSpam said:
Air pressure
Correct. More specifically, the air pressure is higher at the bottom of the balloon than at it's top, since air pressure decreases as height increases. This gives a net upward force, that we call buoyancy, which can be greater that the downward gravitational force.
Another way of looking at it is using Archimedes principle. The balloon (filled with Helium) has a lower density than air.
Also one thing that might help you is to remember that air pressure pushes in all directions. And since the lower down one goes the greater the air pressure becomes; there is always a greater pressure from air pushing up than there is pushing down.
thanks
Gravity allso pulls on the air around the balloon(which is air pressure) but because the air is more dense(it weighs more) than the helium in the balloon, the balloon rises.
Redbelly, I apologize, I did not see earlier that you had already wrote what I said.
