Subrata Paul
- 7
- 0
how antigravity force is created before supernova explosion? why it is not created in a body less than chandrashekhar limit?
Subrata Paul said:how antigravity force is created before supernova explosion? why it is not created in a body less than chandrashekhar limit?
It really depends on what kind of supernova explosion takes place. In general, supernovae release huge amounts of x-rays and gamma rays, and these could significantly damage the ozone layer in the atmosphere when they reach the Earth. A depletion of the ozone layer could have catastrophic effects for the biosphere, as primary producers would significantly be affected after exposure UV radiation from the Sun, which could lead to a collapse in food webs globally.harshith_cs said:A Hypothetical question: What would happen to our solar system if there is a supernovae exploding at a distance of our closest star Proxima Centauri at approx 4.2 light years away? What would be the consequences?
The blast from a supernova can be somewhat directional, so the exact consequences for Earth could vary because of that,harshith_cs said:A Hypothetical question: What would happen to our solar system if there is a supernovae exploding at a distance of our closest star Proxima Centauri at approx 4.2 light years away? What would be the consequences?
wabbit said:What do you mean by "antigravity force" ?
Subrata Paul said:the outward force that is created during supernova explosion is antigravity force.. at that time gravity collapses.
You were misinformed somewhere. Gravity doesn't "collapse" during the microseconds preceding the supernova event.Subrata Paul said:the outward force that is created during supernova explosion is antigravity force.. at that time gravity collapses.
That Wiki entry promotes some common misconceptions. I knew it would, it's not alone there-- textbooks say similarly misleading things. But it's worth pointing them out to try to set the record straight. For example, the Wiki says "As there is no fusion to further raise the star's temperature to support it against collapse, it is supported only by degeneracy pressure of electrons." This is incorrect, it is never necessary to raise temperature to support against collapse, what you actually need to support against collapse is to maintain the temperature-- you need to replace lost heat. When lost heat is not replaced, what actually happens is temperature rises, so we can see that a constant temperature is a sign of something that is being supported, and a rising temperature is a sign of something that is not being supported. Worse, the Wiki goes on to say "In this state, matter is so dense that further compaction would require electrons to occupy the same energy states."SteamKing said:
Ken G said:When lost heat is not replaced, what actually happens is temperature rises, so we can see that a constant temperature is a sign of something that is being supported, and a rising temperature is a sign of something that is not being supported.
That is certainly a standard way to describe the situation, but I am pointing out the potential for that language to lead to misconceptions. In strict terms, the only gross macroscopic effect of degeneracy is the inhibition of heat loss, and as such it does not "cause" an outward force. (It also inhibits internal collisions, so it conducts heat very efficiently, but that just redistributes excess heat, most of the internal kinetic energy is still insulated against any heat loss.)AgentSmith said:The "outward force" is caused by electron degeneracy. It can resist further compression by the gravity of the star. Bigger stars could overcome even that and create black holes.
As the fusion process continues, the concentration of Fe increases in the core of the star, the core contracts, and the temperature increases again. When the temperature reaches a point where Fe can undergo nuclear reactions, the resulting reactions are different than the ones that have previously taken place. Fe nuclei are the most stable of all atomic nuclei. Because of this, when they undergo nuclear reactions, they don't release energy, but absorb it. Therefore, there is no release of energy to balance the force of gravity. In fact, there is actually a decrease in the internal pressure that works with gravity to make the collapse of the core more intense. In this collapse, the Fe nuclei in the central portion of the core are broken down into alpha particles, protons, and neutrons and are compressed even further. However, they cannot be infinitely compressed. Eventually, the outer layers of material rebound off the compressed core and are thrown outward. This situation can be likened to a rubber ball on the ground that is struck with a hammer. Initially the hammer can compress the rubber ball because of its force, but eventually it is stopped by the density and pressure of the rubber ball reaching its limit, and is thrown back violently by the recoiling rubber ball, which itself will bounce off the surface because of this recoil. In the star, the outer layers of the core are like the hammer, and the core is the rubber ball. Following the collapse of the inner core, the outer layers of the star are pulled toward the center. This sets the stage for a tremendous collision between the recoiling core layers and the collapsing outermost layers. Under the extreme conditions of this collision, two things happen that lead to the formation of the heaviest elements. First, the temperature reaches levels that cannot be attained by even the most massive stars. This gives the nuclei present large kinetic energies, making them very reactive. Second, because of the breaking apart of the iron nuclei in the central core, there is a high concentration of neutrons (called the neutron flux) that are ejected from the core during the supernova. These neutrons are captured by surrounding nuclei, and then decay to a proton by emitting an electron and an antineutrino. Each captured neutron will cause the atomic number of that nucleus to go up by one upon its decay.
That kind of depends on what you mean. If you took a white dwarf, and instantly tagged every electron such that they were no longer indistinguishable and did not obey the Pauli exclusion principle (let's not worry about the impossibility of actually doing that!), you might think that the star would instantly lose its support, and be crushed by gravity, if you think that degeneracy is responsible for the pressure. But this is just the misconception I was alluding to, that isn't true-- the star will still remain quite close to force balance, all that will happen is it will be able to lose heat. So it will start losing heat, and will start contracting, but the contraction will be gradual on the free-fall timescale because the heat transport timescale is still much longer than that. Indeed, over a single free-fall timescale, you might not notice much at all about the white dwarf, when you turn off its degeneracy. I'm not sayinig you claimed otherwise, merely that it is an important clarification to make because we often see language that might be interpreted differently.AgentSmith said:But gravity is countered, and if not for the degeneracy, it wouldn't be.
I can agree it is macroscopic, but I'm not sure what significance you are implying. It is also quantum mechanical, so we have a granddaddy of an example of a phenomenon that is both macroscopic and quantum mechanical (even better is white dwarfs).And I might assert(insist, demand, have a hissy fit over) that the formation of say, a neutron star is rather macroscopic.
Chronos said:The general consensus among scientists is the minimum safe distance for a supernova is in the range of 50-100 light years as noted here - http://Earth'sky.org/space/supernove-distance.
PWiz said:It really depends on what kind of supernova explosion takes place. In general, supernovae release huge amounts of x-rays and gamma rays, and these could significantly damage the ozone layer in the atmosphere when they reach the Earth. A depletion of the ozone layer could have catastrophic effects for the biosphere, as primary producers would significantly be affected after exposure UV radiation from the Sun, which could lead to a collapse in food webs globally.
I'm not 100% sure, but IMO the radiation should affect human satellites near Earth as well.
rootone said:The blast from a supernova can be somewhat directional, so the exact consequences for Earth could vary because of that,
However even if Earth were located well away from the regions of maximum blast, I'm pretty sure that the amount of gamma radiation received from a supernova that close to Earth would likely sterilize all life, and probably fry the atmosphere into a highly ionized state.
I stated that the effects are dependent on the type of supernova explosion.phyzguy said:Chronos, PWiz, and rootone have all claimed that a supernova at the distance of 4.3 light-years would be catastrophic for life on Earth. I'd like to examine how you came to this conclusion. I discount the link Chronos posted, since it is full of obvious errors. First, it confuses years and light-years, an elementary mistake. Second, it states that, if the sun were to go supernova, the side of the Earth facing the sun would be boiled away. This is silly; since supernova explosions last for weeks, all of the Earth's surface would be impacted. Third, it states that, "The sudden decrease in the sun’s mass might free the planet to wander off into space." This is also nonsense. So ignore that article. What are the facts? A typical supernova has an absolute magnitude of about -18, and this luminosity lasts for a few weeks. At a distance of 4.3 light years, this would be an apparent magnitude of about -27.5, as compared to the sun at -26.7. So the Earth would have a second sun for a couple of weeks. This would clearly wreak havoc with the weather, but it wouldn't be a sterilizing event, and I think we would clearly survive. As far as X-ray and Gamma-ray emission, the articles I could find indicate that these emissions are far less than the emission of visible light. We are not talking a gamma ray burst, which would clearly be catastrophic at this distance if it were pointed at us, but an ordinary supernova. Gamma ray bursts are very rare events, and the odds of one happening nearby are extremely small. All of this is a long-winded way of asking whether anyone can back up the statement that a supernova 4.3 light-years away would be a sterilizing event.
phyzguy said:At a distance of 4.3 light years, this would be an apparent magnitude of about -27.5, as compared to the sun at -26.7. So the Earth would have a second sun for a couple of weeks. This would clearly wreak havoc with the weather, but it wouldn't be a sterilizing event, and I think we would clearly survive.
K. Doc Holiday said:I have been informed that all our discussions have to accept current theories as gospel truth and we cannot mention anything other than that gospel, even if that gospel clearly violates the laws of logic and common sense. I didn't realize that when i joined this forum. I wish all of you the best! I am out of here. :)
So, how does EDM prevent heat loss if it is a thermal conductor?Ken G said:Right. That mechanism says that if there is net heat loss, gravity will slightly exceed pressure. It is a misconception to say that the heat loss ever causes temperature drop, however-- the temperature can rise monotonically everywhere, throughout the process. The key is that the slight excess of gravity is always causing contraction, allowing gravity to do work that pumps kinetic energy into the system-- usually at a rate twice as large as the net heat loss that is driving the whole business. Thus the excess kinetic energy piles up and causes the continuing temperature rise, but even though the temperature is steadily rising, the rising gravity continues to slightly exceed the pressure.
Anything that short-circuits the net heat loss will stop this process, and either fusion or degeneracy can do that-- fusion by replacing lost heat, degeneracy by preventing heat loss in the first place.
(It [EDM] also inhibits internal collisions, so it conducts heat very efficiently, but that just redistributes excess heat, most of the internal kinetic energy is still insulated against any heat loss.)
nikkkom said:That is more like three Suns.
Venus insolation is "only" 190% of Earth's.
Having 3x insolation for weeks would cause air temperature to quickly rise well above 100 Celsius.
Looks sterilizing to me.
willem2 said:I agree that it would kill off most of the humans. A tripling of the incoming radiation would mean a rise in the absolute tempererature of the 4th root of 3, so 288k * 1.316 = 379K, so about 106C.
nikkkom said:Venus is only x1.9, yet its surface temp is in excess of 450 C!
Evidently, your model is grossly oversimplified.
Not true, gamma ray burst come from the collapse of supermassive stars.K. Doc Holiday said:Gamma Ray Bursts occur in the early formation of a galaxy (nature of the beast). The Milky Way has long ago past the point where our galaxy will host such an event.
It is a perfect conductor with no heat to lose, like a superconductor at absolute zero. Exactly like that, in the limit of complete degeneracy.Hornbein said:So, how does EDM prevent heat loss if it is a thermal conductor?
