What force is needed to produce a constant speed?
The problem involves a wagon with a mass of 10 kg being pulled at a constant speed by a force of 75 N, while rain collects in the wagon at a specified rate. The questions focus on determining the force required to maintain this speed over a period of time, the average force exerted, and the impulse experienced by the wagon.
  • Participants discuss the balance of forces when the wagon is moving at a constant speed and question whether additional force is needed as mass increases due to rain accumulation.
  • Some participants inquire about the relationship between friction force and mass, and whether the friction force remains constant as water accumulates.
  • There are considerations regarding the assumptions made about the horizontal speed of raindrops and their impact on the wagon's momentum.
The discussion is ongoing, with various interpretations being explored regarding the effects of increasing mass on friction and the implications of raindrop dynamics. Participants are questioning assumptions and clarifying concepts without reaching a consensus.
There are concerns about the assumptions regarding the horizontal speed of raindrops and how they interact with the wagon, as well as the accuracy of the given density of water.
tjhero123
An empty wagon with mass 10 kg is pulled by a force of 75 N at a constant speed. Rain falls collecting in the wagon at a rate of 375mm^3/s. The density of water is 1g/mm^3.
A) Make a table showing how much force must be exerted on the wagon to keep it moving at a constant speed for 10 seconds. Graph it.
B)Find the average force exerted on the wagon over this 10 second period.
C)What is the impulse over these 10 seconds?
mass of wagon at time t (seconds) in kg=10+0.375t
F(net)=ma
If the wagon is moving at a constant speed, then all forces must be balanced. So the 75 N force must be balanced by a friction force also of 75 N. The equation for mass of the wagon was simple enough to derive but I am stuck at this part. Is this a trick question? Because the way i see it is that no aditional force is required to keep it moving at a constant speed. As long as the 75 N force was continued and balanced by the friction force, wouldn't the cart continue to move at a constant speed forever no matter how much mass was gained from the rain? So the average force exerted on the wagon would just be 75 for 10 seconds and therefore the impulse would be 750. Or does the 75 N force not even count as an exerted force since its balanced and the actual answer is 0?
Are you sure that the friction force doesn't depend on the mass of the cart? Do you know any equations for the friction force due to rolling friction?
Does the friction force stay constant as water accumulates on the wagon?
The friction force is dependent upon the Normal force and coeffeiciant of friction. Is that correct? So would i calculate the coefficiant first with the normal force being = to 10(9.81) and the friction force equal to 75 N? Then as the mass increases the Fn will increase and i can multiply that by the coefficiant of friction that i get in the first part to get my new Friction force?
Replace the question marks with full stops, and you should be fine :)
Pardon my poking my nose in here, but is it being assumed that the raindrops have the same horizontal speed as the cart when they land? Seems a bit of a stretch... how do the raindrops "know" how fast they should be traveling in order to not affect the momentum of the cart? If the drops are falling vertically they will need to be accelerated to cart speed when they land.
Seems to me that the problem is more complicated than just dealing with an increase in friction...
That is a valid concern, but given the nature of the questions and the fact that the constant speed is not given, the problem apparently wants us to ignore that.
Yes, I suppose it does. But it's a pretty vague way to make it known.
What would the pressure be :-)
The density of water is not 1 g/mm^3
  • · Replies 24 ·
