What Forces Act on a Particle During Quantum Reflection?
The discussion revolves around the forces acting on a particle during quantum reflection from a one-dimensional finite potential well, as described by the time-independent Schrödinger equation (TISE). The original poster is attempting to calculate the expectation value of the force on a particle incident on the well, questioning the validity of their approach and the implications of their findings.
  • The original poster attempts to calculate the expectation value of force using the wavefunction and the potential well's characteristics, raising concerns about the dimensionality of their result and the interpretation of reflection coefficients. Some participants suggest alternative methods, such as analyzing momentum distributions and applying Ehrenfest's theorem, while others question the applicability of these methods in a time-independent context.
The discussion is ongoing, with participants exploring various interpretations of the problem. The original poster has expressed uncertainty about their calculations and the implications of complex values in their results. Some guidance has been offered regarding the use of different approaches to understand the forces involved, but no consensus has been reached on the best method to apply.
Participants note that the reflection coefficient is not the same as the probability of reflection, which introduces complexity into the calculations. There is also mention of normalization issues affecting the units of the force calculation.
PhysicsandSuch
Hi folks,
So everyone at some point studying QM deals with reflections from 1D finite potential wells using the TISE, but something that I never covered was how to talk about or calculate the forces involved in turning around that particle. I tried to work something out below, but I'm not sure if it's a valid approach and was hoping for some advice.
Consider a 1D finite potential well starting at position ##x=0##, length ##a##, and depth ##-V_0##. A particle is incident on the well from the left with energy ##E>0##. Calculate the expectation of the force on the particle in that region given a reflection coefficient ##R##.
$$V(x) = -V_0 (θ(x)-θ(x-a)) $$
$$F = -∇V$$
$$ψ_{region} = e^{i k x} + R e^{-i k x}$$
[tex] \begin{align}<br /> F &= V_0 ( δ(x)-δ(x-a)) \\<br /> <F> &= ∫_{-∞}^0 ψ^*Fψ dx \\ <br /> &= ∫_{-∞}^0 (e^{- i k x} + R e^{i k x}) V_0 ( δ(x)-δ(x-a)) (e^{i k x} + R e^{-i k x}) dx \\<br /> &\text{Expanding and noting only the unshifted delta function will survive the integral} \\<br /> & =∫_{-∞}^0 V_0 δ(x) (1 + R(e^{2i k x} + e^{-2i k x}) + R^2) dx \\<br /> & =V_0 (R+1)^2<br /> \end{align}[/tex]
If this is right, then at full reflection, can we expect a force of 4 times the potential strength, while at no reflection, the particle still experiences a force equal to the potential? Also, my dimensions seem weird here: after integrating out the delta function, I'm just left with energy, not force...right? It seems proportionally correct, but I can't figure out where am I going wrong...
I'm not sure if it's a calculation error or a conceptual misunderstanding on how to deal with finding this force.
If this is a sound line of thinking or could be massaged into one, could it also be applied to a wavefunction undergoing exponential decay as it tunnels through a finite barrier?
Thanks for the help!
by calculating the expectation value of [itex]F[/itex] from -∞ to [itex]0[/itex] you calculate the average value of the force the particle is likely to experience given it is on the left side of the potential well, and is described by the wavefunction [itex]\Psi(x)[/itex]. This seems like a good way to go if you are interested in measuring the force on the particle.
Alternatively, you could look at how the momentum probability distribution of a Gaussian wave packet traveling to the right changes with time, and by seeing how the mean value of the momentum changes in a reflection, you can infer the force on that particle with Newton's second law and Ehrenfest's theorem.
First off, thanks for the response.
by calculating the expectation value of F from -∞ to 0 you calculate the average value of the force the particle is likely to experience given it is on the left side of the potential well, and is described by the wavefunction Ψ(x). This seems like a good way to go if you are interested in measuring the force on the particle.
Right, so your first comment says what I've already done verbatim, but doesn't actually address any of my questions. Like the remaining force in the case of no reflection or the dimensions of the solution which seem to be off.
In your second comment, we're no longer in a time independent picture if we are looking at the time rate of change of momentum, right? So, not valid here? I understand the use of Newton's second law and Ehrenfest's theorem in other situations, but I don't think it can be used for this scattering state in a time independent picture...
I can Fourier transform the state into the momentum space representation, and find the expectation value of the momentum on this side of the well, but since the representation is still time independent, taking a time derivative of that would be 0. And as I understand it, there wouldn't really be a way to discern the expectation value of the momentum before and after a reflection--there'd only be 1 expectation value.
Also, naively, since the scattering state has the same energy going in as going out after reflection, isn't the momentum change just twice the incoming, defined by the relations $$ \frac{\hbar^2 k^2}{2m} = E$$ $$p = \hbar k$$ $$Δp = \sqrt{8 m E} $$ (Can we look at it that way?) Either way, there's no dependence on the reflection coefficient here, and I don't see how to introduce the 'per unit time' to get a force.
I think the best way to think about the problem is in the energy-gradient picture with time independence, as I've already done, but I still don't have resolve to my questions on that approach.
Maybe I'm wrong or am missing something with the momentum view? Anyone care to throw down some math?
Bump to my questions?
1) Why does my calculation of ##\langle F \rangle## have units of ##V_0##?
2) My analysis of the limits of the force are wobbly, because I forgot that the coefficient ##R## is NOT the probability of reflection, ##|R|^2##. Therefore, the answer for ##\langle F \rangle## actually has imaginary components to it once you expand it out! For reference:
$$R = \frac{(k^2 - q^2) \sin{a q}}{2 i k q \cos{a q} + (k^2 + q^2) \sin{a q}} $$
What does it mean to have a complex valued ## \langle F \rangle## ? Are the imaginary components related to dispersion/dissapative forces or a force-phase?
Plotting it all out in normalized units with respect to the experimental variables ##{E,V_0}## provides some interesting behaviors, but I'm not sure if this is even a valid technique to begin with.
The density plot is ##| \langle F \rangle |## (lighter is larger) as ##E=[0,300]; V_0=[0,100]##;
The line plot is a normalized plot of ##|R|^2## in BLACK, ##| \langle F \rangle |## in RED, ##\Re{ \langle F \rangle }## in GREEN and ##\Im{ \langle F \rangle }## in BLUE
Can someone comment on whether or not you can actually calculate the reflection force this way, and shed some light on the result if valid?
Nevermind, I solved my questions after a discussion with a friend.
1) Units issue comes from the normalization
2) Imaginary issue comes from the fact that I forgot to take the conjugate of R
If anyone comes across this and wants a more detailed explanation, feel free to pm me
